03-12-2024, 12:56 AM | #925 |
Rep 18
Awesome! I have dravit and some of your options were ones I was considering and wanted to visualize but never found! You just helped me out a lot! Do you have any spacers? I wanted those wheels in black
Limegrntaln13475.00 |
03-12-2024, 12:57 AM | #926 |
Rep 18
03-12-2024, 01:21 AM | #927 | |
Rep 6,962
I’m not sure what other options you were considering, but all of the carbon is OEM with the exception of the front grille, which is Project Gamma. The tires that come pre-installed on these wheels, are Yokohama V107Star. Which are surprisingly good tires, and ranked higher in some tire tests, than the PS4s. But, take into consideration that the Michelins is a 10 year old tire.
YT: G Dubyou |
03-12-2024, 09:03 AM | #928 | |
Rep 6
Pabloshky10.50 Limegrntaln13475.00 |
03-12-2024, 12:45 PM | #929 |
Rep 590
03-13-2024, 03:13 AM | #930 |
Rep 6,962
I dont. I was already lowered, but, Im going to guess it does, at least on the xDrive. The RWD, I think you have a little better steering angle, and dont have to worry about it.
YT: G Dubyou |
03-14-2024, 02:37 AM | #931 |
Rep 2
I did a full drop in the front and matched the back. Still space in the front. Not too low at all imo. Will post pictures soon.
03-14-2024, 02:41 AM | #932 |
Rep 6,962
It takes a few hundred miles to settle. So, after that, it will be a little lower. The pic in the driveway, was after about 150-200 miles.
YT: G Dubyou |
T0RM3NT3642.00 |
03-15-2024, 01:50 PM | #933 |
Rep 72
Although I am having troubles with my car I installed recently the MPhas
Before that the car had eibach fronts only and it was not OK for me. Harsh front and unbalanced in some scenarios. So to make me happy I installed the mp has at the recommended height I was ready to order something really expensive BUT I think I am going to hold back. I really can't believe how much of an improvement this made. I also have milway camber plates and front arm bushings . I am going to upload the cs software also for the shocks and then see how it will go. I may have to think really hard before spending 10k++ for suspension |
Limegrntaln13475.00 TopJimmy5463.00 |
03-26-2024, 06:15 PM | #934 |
Rep 122
Had mine installed that port not sure what setting they’re at. Is there anyway to find out I want them to be a BMW spec thank you.
03-26-2024, 06:31 PM | #935 | |
Rep 6,962
There are measurements in the fitting instructions if you want an exact figure. See attached. Page 3 of this thread. The pdf is attached to this post. https://g80.bimmerpost.com/forums/sh...6&postcount=52
YT: G Dubyou |
03-26-2024, 09:15 PM | #936 | |
Rep 122
03-26-2024, 09:52 PM | #937 |
Rep 6,962
The measurements in green on your sheet is this measurement. (Ride height)
YT: G Dubyou |
03-26-2024, 11:26 PM | #938 |
Rep 122
03-27-2024, 09:10 AM | #939 | |
Rep 497
Here's the alignment specs that were left in my car at delivery: Last edited by dtronics; 03-27-2024 at 09:19 AM.. |
03-27-2024, 04:10 PM | #940 |
Rep 122
03-27-2024, 08:06 PM | #941 |
Rep 497
It’s subjective. I have mine on max low F/R. I have no problems with how it handles and don’t rub with spacers (15mm/ 12mm). I prefer the looks at max low too. I really like how the car handles and I prefer it over my previous F82 on KW V3’s.
Debtm3205.00 |
03-28-2024, 12:05 PM | #942 |
Rep 590
Here's my alignment specs with me sitting in the car. Also full low (10mm spacers F+R).
03-29-2024, 12:14 PM | #943 |
Rep 18
So what I’m seeing is that if you want the car on the lowest setting. Plus spacers in front and back. It WILL rub on the liner? I saw some company made special liners so you don’t rub but I remember them being crazy expensive, is there any other solution to where I wouldn’t have to cut my liner for it not to rub?
03-29-2024, 01:19 PM | #944 | |
Rep 497
The OEM liners are pretty cheap so you can replace them as needed down the line. https://www.getbmwparts.com/oem-part...er-51718070503 |
03-30-2024, 11:11 AM | #945 |
Rep 590
It all depends on how aggressive you go. I have 10mm spacers front and rear, Pirellis, max low, and zero rubbing. On Michelins, 12mm seems to be max with no rubbing.
03-30-2024, 10:38 PM | #946 | |
Rep 6,962
YT: G Dubyou |
Tags |
g80 lowering springs, m performance accessories, m performance has, m performance suspension |
