05-23-2022, 09:52 AM | #24 | |
1919
Rep 1,889
Drives: E92 M3
My owner's manual doesn't talk about center jack points so it'll take someone's trial and error to confirm it.
05-24-2022, 09:25 PM | #25 |
Beware of cheap bait!
709
Rep 715
05-25-2022, 08:22 AM | #26 |
Rep 264
03-12-2023, 12:53 AM | #27 | |
Rep 22
04-26-2023, 09:28 AM | #28 |
Rep 264
Anyone lifted the rear of an M3 xDrive via the fins on the differential in order to lift the entire rear of the car at once, in order to place jack stands under the rear lift pucks?
04-26-2023, 11:36 AM | #29 |
Rep 880
My car is a manual but same as the xDrive on the rear fins of diff. I just used a 2x4 and jacked the whole rear up using the diff. No issues.
Make today your best day!
Team Tonka132.50 |
04-26-2023, 01:46 PM | #30 |
1919
Rep 1,889
Drives: E92 M3
Too sketchy using the differential cover. I have four Jackpoint jack stands if I ever need to get all four corners up. Let me know if you'd like to borrow a pair for a bit.
Track season is starting and I use those quite a bit for brake fluid changes and inspections.
04-26-2023, 01:59 PM | #31 |
6918
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
I would never, ever jack using the diff fins. That's crazy talk.
04-27-2023, 09:32 AM | #32 |
Rep 542
Drives: 2022 G83 M4
Here's the actual official bmw procedure where they specifically state to use the rear diff. I just used a piece of plywood between the jackpad and differential to better distribute the force.
04-27-2023, 11:08 AM | #33 |
6918
Rep 3,277
04-27-2023, 03:20 PM | #34 |
Rep 880
Thanks for posting.
05-17-2023, 05:32 PM | #35 | |
Rep 13
Been looking for this information for M3 G80 AWD. Closest to official BMW instruction set I found for centre jack points. There are a few threads on this subject, none were conclusive for AWD models. |
02-19-2024, 08:44 PM | #36 |
Rep 5
Drives: '24 BMW M3 Comp xDrive
We have a couple people saying it's fine to jack from the rear diff (maybe use a 2x4 to distribute weight) and a couple people saying that is a terrible idea (PDF indicates it's fine). Another person mentioned jacking from the rear frame immediately behind the rear diff.
It's been some time since this thread was created. Is there a consensus on where to place the jack in the rear so that jack stands can be placed correctly on either side? I'm sure one hundred people have found a solution. Just curious to hear from some of them ! Thanks! Last edited by Breilly217; 02-20-2024 at 07:58 AM.. |
02-20-2024, 12:20 AM | #37 | |
Rep 2,617
There's a jack point for the front that's a circle right behind the lower plastic cover. I've used that point multiple times and it works fine. |
02-22-2024, 06:48 AM | #38 | |
Rep 248
02-23-2024, 02:49 PM | #39 | |
Rep 5
02-23-2024, 03:00 PM | #40 |
Rep 2,617
If you want to be extra careful, you can get a couple of jack stands w/ BMW adapters, jack the car up on the diff, then put the jack stands under at the two side jack points, and let it down. That way the car isn't jacked up on the diff the entire time.
kgelfen3602217.00 |
02-23-2024, 08:20 PM | #41 | |
Rep 1,929
They look a bit sus to me for a jack stand.
02-23-2024, 08:58 PM | #42 | |
Rep 477
I went with these and so far have worked great. Made of solid billet aluminum and cheaper than the rubber ones you posted. Jack Pad Adapter Anodized Black... https://www.amazon.com/dp/B0725GCJ6T...p_mob_ap_share |
02-23-2024, 09:25 PM | #43 | |
You got my money?
3158
Rep 4,646
Drives: Ice Cream Truck
I like the other guys jack stand way more.
02-23-2024, 09:31 PM | #44 | |
Rep 2,617
