05-12-2022, 04:34 PM | #1 |
Rep 264
How best to jack up the M3 xDrive with jack stands and a hydraulic jack?
I think this has been slightly discussed before, but how does one appropriately jack up the entire front, or just the rear with the use of a low profile hydraulic jack and a couple of jack stands? Is it possible? Dealer says the only way to jack it up is using the jack points on the car (see photos). I was hoping to find a single safe point up front (or the rear) to jack it up and slide the jack stands under the cars jack points. Dealer suggests that is not possible.
If dealer is correct (I'm going to assume they are), then I believe the only option is one of the below solutions? Jackpoint jackstands: Home (jackpointjackstands.com) Rennstand: https://rennstand.com/ Suggestions/input/thoughts/solutions? |
05-12-2022, 09:48 PM | #3 |
Rep 264
05-12-2022, 11:16 PM | #4 |
Sith Lord
3452
Rep 893
Drives: G80X, Mazda 3 6MT (daily)
Let's see how many jacks I use in this sentence.. you can use two jacks, jack up the car on one side until you can jack up from the front / rear center jack point with another jack.
This thread may help, https://g80.bimmerpost.com/forums/sh...1872373&page=2
Always two there are.
05-12-2022, 11:40 PM | #5 |
Rep 742
Drives: 22 M4c vert
05-13-2022, 10:00 PM | #6 |
salty cowboys fan
6159
Rep 3,408
05-14-2022, 09:36 AM | #7 |
Rep 926
Use the center jack points front and rear. Front looks like a metal donut right behind the engine tray, and the rear you jack up using the differential fins. You're not gonna break them
2023 F90 M5
05-14-2022, 01:15 PM | #8 |
Rep 3,341
Drives: 2022 M3, 2022 X5 40i;
05-14-2022, 02:52 PM | #10 | |
Rep 3,341
05-14-2022, 03:05 PM | #11 | ||
Rep 926
Weird washing like this cause the car is about 8" higher than on wheels.
2023 F90 M5
M4Tejas788.00 |
05-15-2022, 09:17 PM | #12 |
Beware of cheap bait!
709
Rep 715
Front puck behind the oil cooler, rear I use the center of the rear subframe right behind the diff. When lowered the front puck is hard to get to, I built ramps to lift the car 3 inches for floor jack clearance. I place stands not on the outboard jacking points but on the front skid plate right around the mounting bolts just inside of the front wheels. Rear is a toss up of subframe or the jacking points. Jacking points are already coming apart from use though, but I don't use the fancy jack pad adapters because I can't be assed.
05-15-2022, 11:18 PM | #13 |
1919
Rep 1,889
Drives: E92 M3
I have 4 of these and highly recommend them. I have a heavy duty jack so can't reach the center jacking point on the cars.
Parking all four wheels on something like stacks of wood to increase ground clearance helps get the car on all four stands with the jackpad adapters. The adapter increases stability and the stands themselves are very wide, so I don't worry at all about bumping into the car while working on it.
calbearz2434.00 |
05-16-2022, 08:24 AM | #14 | |
Rep 264
Front Puck is only on RWD cars I believe?
05-17-2022, 07:27 AM | #15 | |
Rep 926
2023 F90 M5
M4Tejas788.00 |
05-17-2022, 08:21 AM | #16 |
Rep 2,135
05-19-2022, 07:16 AM | #17 |
Rep 264
Got my M3 xDrive up on some ramps. Isn't this the front center jackpoint?
If so, what type of puck/adapter do I need for a low profile hydraulic jack? |
05-19-2022, 09:07 AM | #18 |
709
Rep 715
05-19-2022, 10:06 AM | #20 |
709
Rep 715
05-19-2022, 10:17 AM | #22 |
Rep 264
2.5 Ton low profile trolley type floor jack....
I'd use just to jack up the front high enough so I can use floor stands up front to hold the front up. |
