02-19-2022, 04:17 PM | #1 |
Rep 711
Door projector lights?
Saw the projector door lights and want to get some but quick question. The door on the g8x already has a light in it, correct? So can’t I just buy the slides? Or for the slides to work do I need to buy the full light insert? The slides are like $35 and the full light insert was like $135? Sorry just a bit confused.
02-19-2022, 04:55 PM | #2 | |
Rep 585
IG: Adaptiive_M
E46 M3 (Sold) E92 M3 2022 G82 M4C Xdrive |
Limegrntaln13536.50 |
02-20-2022, 08:39 AM | #3 |
Rep 711
Got it. Do you have any idea how to install them? I tried a search on here but couldn’t find anything.
02-20-2022, 09:09 AM | #4 |
Rep 1,682
M_Adaptive1769.00 |
02-20-2022, 01:13 PM | #5 |
Rep 585
It’s pretty easy to install yourself. Pop out the light under the door with a tool. Unplug it. Plug in the new light. Insert slide. Pop back in. Tons of YouTube videos on this.
IG: Adaptiive_M
02-20-2022, 01:27 PM | #6 |
Rep 1,534
Drives: '22 Mexico Blue G80 xDrive, '2
Before I dropped off my car for ppf I attempted install…
I was able to pop out the existing light using a flat head screw driver as instructed. Very easy. That's when I stopped. I couldn't get the connection undone without feeling like I was going to break it. Any tips? I hate when something so seemingly simplistic doesn't work and is so damn hard. |
02-21-2022, 12:41 AM | #7 | |
Rep 6,998
YT: G Dubyou |
RockinPA4855.50 |
02-21-2022, 09:57 AM | #8 | ||
Rep 1,534
To be honest, I may have dealer just do it next week when I take it in to have my MP steering wheel put in. How much time could they possibly bill for putting those in? Lol. Even if they just remove them for me. I'll put them in. |
02-21-2022, 02:37 PM | #9 | |||
Rep 6,998
YT: G Dubyou |
RockinPA4855.50 |
02-21-2022, 03:01 PM | #10 | ||||
Rep 1,534
Thanks dude |
02-21-2022, 05:21 PM | #11 |
Rep 200
the short version 50mm for G82 is harder to install then the earlier version. And one door is definitely easier for me to unplug the connector. I am not sure if its because of the interlock. But you don't really need BMW help...even I can do it myself and I am not the most technical person. I didn't bother to adjust the projection and it all depending on how wide you want to open your car door and for the logo to look right.
vitipr171.00 |
02-21-2022, 10:52 PM | #12 | |
Rep 300
02-22-2022, 07:04 PM | #13 |
Rep 1,661
I'm mechanically inept, and I was able to install the projectors in a matter of minutes. Most of the time is spent adjusting the slides so they're angled correctly when the door is open. For me that meant taking apart the passenger-side slide holder to flip the slide, plus iteratively removing and reinserting the projector to access the thumbwheel to fine-tune the angle. Then end result was worth the effort (looks great on snow or our epoxy garage floor) ...
02-23-2022, 07:23 AM | #14 | |
Vitipr
171
Rep 352
https://ind-distribution.com/product...ctor-light-kit |
02-23-2022, 11:59 AM | #16 |
Rep 14,122
Drives: G82 M4C X-Drive
It doesn't help that all the parts are small and black including the + and 0 and marks you have to line up.
02-23-2022, 07:35 PM | #17 |
Rep 1,661
Wearing a headlamp was a huge help in replacing the slides and adjusting the projectors once plugged in (i.e., lying on my back underneath the open door).
02-23-2022, 08:17 PM | #18 |
Rep 161
Watch the video and take your time disconnecting the projector from the plug. I did it in 15 minutes and im not mechanically inclined. Unless the dealer is willing to do it for free, it's a complete waste of time and money. You will inevitably want to adjust the direction yourself and that requires popping it out again.
02-25-2022, 10:25 AM | #19 |
Rep 1,738
Found these if anyone is interested. A lot less cheaper too.
https://www.carledlogo.com/ghost-sha...MaAikmEALw_wcB |
02-27-2022, 02:19 AM | #20 |
Rep 14,122
Installed. Took about 10 minutes. Hardest part was swapping the slides lol. I used a plastic trim removal tool to take out the factory lights.
02-27-2022, 11:44 AM | #21 | |
"Salud"
13925
Rep 4,686
Drives: F01 & F15 / Mineral White
02-27-2022, 07:56 PM | #22 |
Rep 1,661
There's a 3-slide set that's available separately from the slides that come with the projectors themselves.
BMW M PERFORMANCE LED DOOR PROJECTORS EXTRA SLIDES - BMW (63-31-2-469-631) Last edited by luckylingy; 03-02-2022 at 08:04 PM.. Reason: added BMW part number and description |
