07-24-2023, 10:29 AM | #1 |
Rep 140
spacers
Hey all,
I just recently purchased some future classic spacers for my G80. I purchased 12mm and 15mm. I’ve seen people do 15mm in the front and 12mm in the back, i have also seen the reversed. What the best setup which should I put in the front and back? I don’t want to adversely affect handling negatively. |
07-24-2023, 11:54 AM | #2 |
Rep 191,503
15mm in the front will rub. You can only do it if you get the RKP fender clearance in the front
PipeM3200.50 |
07-24-2023, 01:51 PM | #3 | |
Sith Lord
3460
Rep 893
Drives: G80X, Mazda 3 6MT (daily)
Whether you rub or not, it's not a huge deal - you can modify the fender liners in many ways.
Always two there are.
07-27-2023, 09:36 AM | #5 | |
Rep 191,503
15mm wont clear without modifying the fender
07-27-2023, 09:50 AM | #6 | |
Sith Lord
3460
Rep 893
Regardless, modifying the fenders is pretty easy and there are endless ways to fix the rubbing. See my thread as one example https://g80.bimmerpost.com/forums/sh...php?p=30130055
Sp2pilot173.00 |
07-27-2023, 11:15 AM | #7 | |
Rep 191,503
MMM.PWR3459.50 |
07-27-2023, 09:45 PM | #8 |
Rep 5,097
Nope that's fine. We have them in stock if you need a set.
07-28-2023, 04:31 PM | #9 |
Rep 17,400
Interesting replies. I’m on ps4s and I’m running 15mm all around with no rubbing at all. That’s before and after installing my v3’s. I guess results vary quite a bit.
Needsdecaf6948.00 provenflipper105.50 |
07-31-2023, 10:26 AM | #11 |
Rep 6,840
07-31-2023, 11:03 AM | #12 | |
Rep 191,503
Mine was happening when turning and reversing. it did not rub at any other time
08-01-2023, 12:00 PM | #15 |
Rep 191,503
09-03-2023, 07:23 PM | #16 |
Rep 405
15mm all around with no rubbing. I used a heat gun to make the vent fins in question pliable then pushed them forward a little bit. No cutting. I just did this when I installed the spacers so don’t know if I would have rubbed had I not. It was easy enough to do while I already had the wheels off. Super happy with the results.
09-04-2023, 12:16 AM | #17 | |
Rep 755
09-04-2023, 12:21 PM | #18 | |
Rep 191,503
09-04-2023, 04:26 PM | #20 |
Rep 2,392
I had Michelin tires with 15mm spacers all around and it was a minimal rub in reverse. I switched to 20 all around with a 285/295 combo BC Forged wheels and +11 front and +12 rear for offset. Same as running 15 front, 13 rear spacers. It looks the same because I'm running wider tires and wheels.
Formerly Wyndi335I
Pool Shark527.00 |
09-04-2023, 04:32 PM | #21 | |
Rep 405
JDUNITNOW3595.50 |
09-04-2023, 05:41 PM | #22 |
Rep 2,392
Formerly Wyndi335I
