08-30-2021, 01:48 AM | #1 |
Rep 97
Struggling to get comfortable in the m3
Odd Question to be sure .. just curious what seating position you guys use for daily driving ? For most of my life I've had the seat all the way back and the back portion reclined gangster style . In this car it just doesn't feel right , I struggle to find the most comfortable position . Anyone with feedback ?
08-30-2021, 02:42 AM | #2 |
Rep 98
I guess the easier question to ask would be what do you find uncomfortable about the seating position? And then go from there.
'21 M3 Base - Brooklyn Grey
CA -> NJ |
08-30-2021, 03:13 AM | #3 |
Rep 1,758
Is this post serious? Who drives a M car with the seat all reclined
25
JTO245246.50 Tall Tom Cruise996.00 _E90S65_736.00 BBm310.50 themnmd1687.00 Encanto1161.00 RaylanGivens12.00 suffer101.50 Digitalfujjjrel186.00 M3ANSPEC393.00 Forzanerazzurri6884.00 playswcars3612.50 montrokc346.50 GrannyShiftG801278.50 DriveWithDray2174.00 BMWRacer5232519.00 Multimodal2857.00 g80z672.00 NorCalAthlete3166.00 TheObviousChild322.00 SpinalTap109.50 Jobe10176.50 ch3k_m855.50 kgelfen3602141.50 vmoney89108.50 |
08-30-2021, 03:35 AM | #5 |
Rep 97
M3exDeo188.50 gtotheq54.00 heavyD^23684.00 Salespunk1741.00 Capt Canuck704.00 DriveWithDray2174.00 VooDooM455.50 |
08-30-2021, 04:21 AM | #6 |
Rep 430
Do you wear a seatbelt? If you are driving aggressively and the seat is reclined, the car will try to throw you into the backseat. You recline the seat all the way back in an Impala or a Monte Carlo, not an M3. This is hilarious.
2022 M3 xDrive - BSM/Tartufo
BBm310.50 themnmd1687.00 bwoodahl235.00 Forzanerazzurri6884.00 Vorsteinerm394.50 TheObviousChild322.00 Jobe10176.50 mathys196.50 |
08-30-2021, 04:33 AM | #7 |
Rep 1,654
Ok, OP, try this (but be forewarned, I’m 6’6”, so my options may be more limited than yours). Adjust the seat fore/aft until your legs are still slightly bent when you fully press the pedals. Adjust the front of the seat cushion upward, if desired, to provide more thigh support. Adjust the back cushion, such that you have two fingers’ width between your head and the roof AND you can reach the top of the steering wheel with the palm of your hand and still have your arm slightly bent. Move your seat forward if necessary to help reach the steering wheel, then adjust the tilt of the seat cushion to restore a degree of legroom. You will also want to adjust the steering wheel reach and rake so that you can see the gauges and reach a comfortable balance of reach (with your arms) and room (with your legs and head).
All the above aims to achieve a SAFE driving position (I’m also a former HPDE instructor), but you will likely find it comfortable as well. Then you can adjust lumbar support and backrest width to suit. |
14
jailonacs99484.00 Geektechlive1187.50 akkando5860.00 larrylam646370.50 BMWRacer5232519.00 NorCalAthlete3166.00 AtholtM3Comp220.00 Llarry14494.00 Tag17929.50 SpinalTap109.50 1209582789.00 davidmct-M3232.50 blackbeard3149.50 Mamba279.00 |
08-30-2021, 05:27 AM | #8 |
Rep 1,653
I think you answered your own question. You are trying to drive a sports car "gangster style"…
08-30-2021, 05:32 AM | #9 | |
Rep 793
Solid. This is the kind of seating position I go for. It's a sports car, so even though I DD it, I always set up my driving position for optimum sport driving + control w/two hands on the wheel and visibility of the cluster. That results in the kind of seat height and slight bends in the arms and legs described here, although for sure a bit lower since I'm not this tall. Allows for the optimum amount of pressure "feel" when using the pedals, turning the wheel, and using negative pressure from both to feel planted in the seat. That's also why I got the driver assistance packages; on long road trips or stop and go traffic having the various cruise control features really helps to give my limbs a rest. You may not be used to that kind of positioning yet OP with the driving positions you used to use, but I'll bet you get used to it over time. |
08-30-2021, 07:26 AM | #10 | |
Rep 97
90 the better control of the car , but the less comfortable I am . |
08-30-2021, 08:39 AM | #11 | |
Rep 149
Drives: 2022 F97 X3M, 2011 E90 M3
I'd start with leg distance from pedals, then lower seat tilt. Seat height next for best visibility. Last, adjust seat back so arms are bent, not stiff arm. 90° seat is uncomfortable. I lean mine back enough for comfort but arms still bent to the steering wheel |
NorCalAthlete3166.00 |
08-30-2021, 09:33 AM | #12 | ||
Rep 97
08-30-2021, 10:09 AM | #14 | |
Rep 334
I must admit Ive been trying for a month to find the most comfortable position in the carbon buckets. Its my legs that I have the issue with. To be most comfortable, I need to have my legs straight. slight upward bend (as mentioned earlier) otherwise the side bolster digs in to my thigh. However, I cant quite get by palms on the top of the wheel so I need to move closer....then its uncomfortable, then I try raising the seat...its a vicious circle... |
08-30-2021, 10:17 AM | #15 | ||
Rep 97
08-30-2021, 01:39 PM | #16 |
Rep 3,056
Do a few track days (serious advice). You'll find your seating position in much faster and understand why reclining is very...impractical to be kind haha.
SMB M3 CS (gone) YMB F80 6MT (gone) |
08-30-2021, 02:59 PM | #17 |
Rep 1,697
First off to the OP, welcome to the other side. Appreciate that you are trying to figure things out. My process is to find a starting point then store it in Memory 1. From there I make small adjustments and then store them in Memory 2. If I make another adjustment then it gets stored in Memory 1. This allows me to toggle between my last known good position and the new updated position.
That being said I never got along with the old luxury seats that came in the 7 and 5 series cars. Sharing this because sometimes seats may not fit your body type. On those cars I could not get the seat back flat enough. There was always too much lumbar in them which aggravated my lower back. Good luck and hope you are enjoying the car. |
davidmct-M3232.50 |
08-30-2021, 06:00 PM | #18 | |
Rep 239
Watch Adjusting your driving position demonstrated in an M6. One Day M School which has basic coverage on the seating position and 360 visibility. Unlearning old/bad habits is hard, but "gangster style" reclining can be crippling or fatal if/when sh1t hits the fan. Besides, your ///M peeps won't think you're a noob when they see you following correct protocol and the Porche guys will think twice before messing with you!
'13 E92 M3 ZCP | Interlagos Blue | 6MT | Speed Cloth | Stripper | MPE | 65K miles
'07 E90 335i | Sonora Metallic | 6MT | Premium | N54 Perf Power Kit | Perf Suspension | 18" BMW MotorSport Wheels | 90K miles/145K Km Last edited by Yeru; 08-30-2021 at 06:09 PM.. |
09-02-2021, 10:12 AM | #19 |
Rep 334
One final point to add to the OCD....have you even noticed that you get int he car in the morning and when you look in the rearview is seems tilted slightly down? Then you move it....
Then in the evening it somehow seems to be tilted a little high so you have to sit up in your seat a little, or move the mirror again. Then the vicious circle begins. I googled it - apparently we are, on average, around 1cm taller in the morning. |
Stockholmarn433.50 |
09-02-2021, 12:54 PM | #20 |
Rep 2,699
Drives: 23 X5MC
09-02-2021, 06:52 PM | #21 | |
Rep 1,654
I drive a dozen or more BMWs during a typical week. Sometimes, like you, I find a seat where I cannot dial out the lumbar support completely. On those occasions, I’ll leverage my legs against the floorboard to apply extra pressure against the seatback as I’m holding the lumbar adjustment. After 10-15 seconds of this, I usually have found satisfaction. |
Salespunk1741.00 |
09-02-2021, 07:00 PM | #22 | |
Rep 1,654
As suggested elsewhere, use your seat memory to ‘dial in’ the setting that ultimately works best for you. I find myself slightly adjusting my seat from time to time, even after driving it nearly 3 years. |
