01-29-2023, 08:18 PM | #67 | |
Rep 3,391
DM5PAV375.00 |
01-31-2023, 11:05 AM | #69 | |
Senior 1Addict
5161
Rep 2,426
Drives: BMW iX, Porsche GT4 RS
So it was no different from an announcement perspective, and you can find threads on here where everyone ripped it as a bunch of carbon bits and some gold trim. Only after test drivers was the software tuning of the dampers and transmission acknowledged as standout points. The CS models have always been about software changes with minimal mechanical changes, M5 CS was no different than the M3 CS. |
TJR_///M3640.00 Bimmerfun827157.00 |
02-03-2023, 12:47 AM | #70 | |
Rep 308
The software changes are important, but it's the sum mechanical and software changes that have made good CS models. IMO, it's a mistake for BMW to make a CS model that is nothing but a software flashed Comp. There should be some mechanical changes that are not cost effective to manually add to a Comp. Even if not everyone cares about the mechanical changes, they should still be there. |
Emtoo370.50 |
02-03-2023, 05:56 PM | #71 | |
Senior 1Addict
5161
Rep 2,426
Its not "0 hardware changes" it was "no significant hardware changes". And that question was asked to compare to the M4 CSL, which had a completely different chassis set-up to the M4C (for both front and back). |
02-07-2023, 05:06 AM | #73 | |
Rep 128
The chassis has been completely overhauled (even if BMW doesn't make a big deal out of it), new programming for the gearbox as well (faster shift times), stiffer engine/gearbox mounts, improved cooling for engine/gearbox (not sure how but I guess we'll find out soon) and the weight reduction may not be significant but BMW certainly optimized and tweaked a few parameters in the ECU, so this isn't only about a bit more boost but also a slightly different drive feel (more direct, sportier). And this is just the stuff we know about because the M3 CS is a 2024 model and BMW improved a lot of things but they don't brag about it. |
02-07-2023, 05:28 AM | #74 | |
Rep 3,391
Did you even read my post where I said “they change a whole bunch of things about the car”? I was being sarcastic - the OP was about the silly paint etc Get off your soapbox |
