10-28-2021, 07:41 PM | #45 |
Rep 2,538
10-28-2021, 08:52 PM | #46 | |
Rep 647
11-25-2021, 02:56 PM | #48 | |
Rep 1,773
Simply spoken, M Traction Control is a slip control mechanism that controls rear wheel slip in 10 stages when DSC is switched off. Level 0 is OFF and allows for unlimited wheel spin. The higher levels allow for very limited slip. The slip is controlled using the engine‘s rpm as the only parameter. The vehicle’s yaw rate is not a controlled parameter here. In contrast to M Traction Control, MDM is a part of the DSC mechanism and actively controls the vehicle‘s yaw rate. DSC/MDM use engine power controls as well as brake interventions to stabilize the vehicle dynamics on the road. MDM uses M Traction Control levels 4 to 7 depending on yaw rate behaviour." https://www.bmw-m.com/en/topics/maga...n-control.html |
kjx3197.00 |
11-26-2021, 10:59 AM | #50 |
Rep 1,286
Question for those with M Drive Professional package.
If you must have DSC off to engage 4WD Sport, does that basically mean you have absolutely no chassis stabilization intervention in this mode? No MDM and no DSC?
11-26-2021, 11:26 AM | #51 |
Rep 69
I run 4WD Sport in MDM mode as my M2 button. 10 stage traction control is only available for AWD if DSC is fully off and transmission set for 2WD, I believe.
BMWRacer5232519.00 |
11-27-2021, 08:52 AM | #52 |
Rep 1,107
I thought the 10 stage traction control only had to do with varying stages of traction in RWD mode….and had nothing to do with either of the AWD modes (4WD and 4WD Sport). No? In other words….if I don't care at all about going full RWD….will M Sport Professional make any difference to me whatsoever?
11-27-2021, 10:01 AM | #53 | |
Rep 1,286
This is what I'm trying to figure out because I need to decide whether to add this option to my car or not.
11-27-2021, 10:07 AM | #54 | ||
Rep 2,302
4WD: no requirement 4WD Sport: requires DSC to be off, but you can have MDM on. RWD: DSC off, MDM off M Traction control (0 - 10): must be in RWD (which means DSC and MDM are off)
2001 330Ci (sold)
11-27-2021, 10:40 AM | #55 | |||
Rep 1,107
11-27-2021, 01:54 PM | #56 | |||
Rep 1,286
jimbethesda1856.00 Seedster2274.00 |
11-29-2021, 09:15 AM | #57 |
Rep 550
Not precisely relevant but a question relating anyways.
Does this seem like something most tuners will "throw in" in the future (whenever everyone breaks the ECU open) like Euro MDM on the E92? |
11-29-2021, 04:06 PM | #58 | |
Rep 744
Unless you want to do donuts? |
11-29-2021, 04:33 PM | #59 | ||
Rep 2,302
2001 330Ci (sold)
11-30-2021, 10:07 PM | #61 | |
Rep 2,302
Just my $.02.
2001 330Ci (sold)
11-30-2021, 10:23 PM | #62 | |||
Rep 744
12-15-2021, 04:27 PM | #63 |
Rep 5,728
Drives: '24 iX50; '23 i4 M50
12-15-2021, 05:43 PM | #64 | |
Rep 2,302
To summarize: If you have a RWD car, M Drive Professional is probably only worth it for drifting. If you have xdrive, it's good for drifting AND if you want to put it in RWD mode sometimes and still have traction control. Stage 7 is close to what MDM is.
2001 330Ci (sold)
12-15-2021, 11:26 PM | #65 | |
Rep 19
