06-08-2021, 01:49 PM | #1 |
Rep 10,875
IND | KW Suspensions G8X M3 / M4 Height Adjustable Spring Kit
KW Suspensions GmbH was founded in 1992 in Murrhardt Germany and has grown to become a leading suspension tuner for European and Japanese cars. KW suspension is developed thoroughly by KW's engineers to have an extremely long service life and create a balance between great handling and a comfortable ride quality. KW has equipped winning race teams for over a decade, and is a supplier to AMG as well as BMW in the M3 GTS. KW's facility is one of only 15 facilities worldwide to be equipped with a 7 post suspension test rig, giving regular M3 enthusiasts access to Formula 1 technology. KW's sleeve kit for the G8X M3/M4 allows a large range of height adjustment while retaining the factory electronic damping control. The factory spring perches are removed from the front dampers, and KW's own threaded height-adjustable perches are installed. The kit includes progressive rate lowering springs for each corner of the car, height adjustable spring perches for the front and rear, strengthened and shortened bump stops and KW shock sleeves to protect the OE BMW dampers. The KW H.A.S. kit is EDC compatible! Lowering Range: G80 Front Lowering 0.4-1.0" G80 Rear Lowering 0.2-0.8" G82 Front Lowering 0.6-1.2" G82 Rear Lowering 0.2-0.8" The KW Suspensions G8X M3 / M4 Height Adjustable Spring Kit may be viewed at the following links to our online store: https://ind-distribution.com/product...ble-spring-kit Please contact IND by phone or email for more information or to place your order. 866.963.4520 | info@ind-distribution.com
06-08-2021, 05:06 PM | #3 |
Rep 1,379
06-14-2021, 04:38 PM | #4 |
Rep 10,875
As a HAS kit, KW tried to focus on also keeping the travel and rates within the OE damper range, and to avoid prematurely wearing them.
Our car hasn't had too much time to settle, but the rear was all the way down; I can't recall if the front was raised ever-so-slightly during corner-balance.
06-25-2021, 12:36 PM | #6 |
Rep 10,875
Not just yet but we do have a pre-order list going.
08-02-2021, 03:06 PM | #7 |
Rep 46
Any update on when these will be released?
Limegrntaln13430.50 |
08-02-2021, 10:05 PM | #8 |
Rep 6,945
"The KW H.A.S. kit is EDC compatible!"
The most important sentence in this post.
YT: G Dubyou |
IND-Distribution9581.00 |
09-28-2021, 12:31 PM | #9 |
Rep 10,875
We have 3 available that can ship today.
05-16-2022, 04:47 PM | #10 |
Rep 10,875
Plenty of kits in stock at IND!
A couple shots on our G80 M3 xDrive:
