09-01-2021, 12:58 PM | #45 |
Rep 1,083
09-03-2021, 09:51 AM | #48 |
Rep 630
Drives: 2021 G80 M3
11-30-2021, 12:51 PM | #51 | ||
Rep 33
12-16-2021, 04:08 PM | #54 |
Rep 2,538
12-16-2021, 07:18 PM | #55 |
Rep 897
Here's mine using 10/10 at stock height. Even 10's in the rear look a bit poked to me, I might go no spacer in back. Fronts def benefit from a spacer of at least 10.
12-16-2021, 07:20 PM | #56 |
Rep 897
12-16-2021, 08:09 PM | #58 | |
Rep 2,538
Jonahk doesn’t have any problems with 15mm but I’ll have a problem with 12mm? There is that big of a difference between Michelin‘s and Pzero??? |
12-16-2021, 08:59 PM | #59 |
Rep 897
Theres about 20 threads about the wheel well liner fins rubbing and potential solutions. And yeah the P0s have a very prominent sidewall that creates issues. 10s alleviated the issue for me and i kept them when switching tires to Michelin, even though 12s or slightly more would likely work.
12-16-2021, 09:02 PM | #60 | |
Rep 2,538
12-17-2021, 07:59 AM | #61 |
Rep 897
Ha no prob bud, I read through them all before putting mine on. 10's all around are def rub free with either tire, if a bit conservative. Some people like to get them perfectly flush but im not that anal.
12-17-2021, 08:02 AM | #62 |
Rep 2,538
Excellent. I’m sure psi can give me 10’s for all four wheels. Either that or tens upfront and 12s outback.
12-17-2021, 08:54 AM | #63 |
Rep 1,255
You just cut the fins if you have the pzeros, it's 2 pieces of plastic, complete non issue and solves it 100%. I have 13/10 but the front could use a little bit more to be flush, probably would go 15/10 if I was doing it again. I don't think the rear needs any more than 10.
12-17-2021, 09:02 AM | #64 | |
Rep 1,751
I'm also lowered on ASTs. No issues whatsoever. If you go larger than 10s on the front with p zeros, it is confirmed you will rub. Reach out to tom @ eas and he'll get you set up. |
12-17-2021, 09:11 AM | #65 | |
Rep 2,538
