      03-10-2024, 10:22 PM   #1
m4ml
Drives: 2022 M4CX BSM (Xpel Stealth)
Rear suspension components (Carbahn vs SPL)
I'm wanting to upgrade my rear suspension toe links and trailing arms. I'm considering both Carbahn and SPL. I've got a history with the Dinan toe links and traction links on my F82 and was pleased with them, so I lean toward Carbahn. I'm also leaning Carbahn because of the sealed rubber boots.
But, I didn't track my F82. I am tracking my G82.
I've heard good things about SPL, so I'm cross shopping:
SPL Toe Links with Eccentric Lockout
and
SPL Rear Traction Links
versus
Carbahn Toe Link/Traction Link Kit
with
Carbahn Eccentric Bolt Locker
Cost really isn't an issue, they're close enough that it doesn't matter to me.
Does anybody have any insights/opinions that might sway be toward SPL over Carbahn?
Susp: Turner Skid Plate/Strut Brace, KW v4, F-L Monoball, MS: Camber Plates, Spacers, SPL Rear
Cosmetic: MPerf: Splitter, Side Vents, Sill Plates, Door Projectors; IND CF Roundels/Float Center Caps, Vorsteiner Grill, Xpel: Stealth PPF, Fusion Plus Ceramic, XR Plus 5/20/70
      03-12-2024, 02:42 PM   #2
BrendanZ0402
BrendanZ0402's Avatar
Drives: G80 M3 GTP 6MT
2023 BMW M3  [0.00]
I say go for SPL. The adjustment mechanism of SPL is a big plus. On the carbahn arms it seems like they are still using the dual jam nuts. On the SPL you just deal with the set screw. And with a proper rod end like the FK rod ends that SPL is using, you don't need a rubber boot. Unless maybe you will encounter salt? The FK rod ends are teflon lined so they're very robust. I have the full SPL catalog on my car and its a great daily driver. Feel free to ask any questions about my setup!
m4ml1834.00
Hit_Apex2370.50
