      10-05-2023, 03:03 PM   #1
arulm3cx
arulm3cx's Avatar
Drives: 2023 BMW M3 Comp Xdrive
CR-S V2 Nankang
I'm planning to run 295/30/19 CRS - V2 Square set up for HPDE and TT.
Any Hints on cold PSI and target PSI and Temp.
Family '21 Honda Passport EX-L AWD
Sold '23 M3 C Xdrive
Sold '18 Audi RS3 - stage 2
www.gowithaci.com
      10-06-2023, 12:14 AM   #2
BrendanZ0402
BrendanZ0402's Avatar
Drives: G80 M3 GTP 6MT
2023 BMW M3  [0.00]
Looking forward to your feedback. How wide are your wheels? I’m currently running 285/35/19 RE71RS on a 10.5 and for my next set I’m thinking 275/35/19 CRS, 295/30/19 CRS or 285/35/19 G3R (Unobtainium!!!
      10-06-2023, 12:31 PM   #3
arulm3cx
arulm3cx's Avatar
19x10.5 et 14. And 19x11 et 22.
Camber front -3.1 and rear -2.0
Probably will run 3mm spacer in front more struct clearance.
www.gowithaci.com
      10-06-2023, 12:42 PM   #4
BrendanZ0402
2023 BMW M3  [0.00]
Great setup! Does the tires bulge at all or are they flush? Since their stated tread width is like 11 something inch I just wonder how wide they actually are.
      10-06-2023, 01:04 PM   #5
arulm3cx
arulm3cx's Avatar
on 10.5" wheel it looks a bit of bulge (very tiny bulge at least to my eyes) . Since it's 26" tall it's time to lower the car
www.gowithaci.com
      10-06-2023, 06:59 PM   #6
BrendanZ0402
2023 BMW M3  [0.00]
Time for some MCS goodies haha. Looking forward to how these 295 does on the 10.5 wheels. Tiny bulge sounds fine
      10-24-2023, 01:49 PM   #7
arulm3cx
arulm3cx's Avatar
First track day on this setup complete. 295 in front probably the best front end grip to have.(atleast to me ) CRS-V2 slip angle compared to GYSC3R is little less (I could see this in GRM tire review as well) so rear fighting for grip in sweeper turns. Also, one more thing I saw is grippy tire with stiff suspension issue. (may be). Planning to try Sport settings for suspension next time. Very flat track so used sport+. Tire is fast for sure.
www.gowithaci.com
somer966.00
      10-25-2023, 03:41 PM   #8
GT3M2
GT3M2's Avatar
174
Drives: G87 M2, 996 Turbo, 1290 SDR
Doing Road Atlanta in December?
I think I am going to aim for around 35 hot, on an m2 but running 295 35 18 square.
-GT3M2
      10-25-2023, 04:57 PM   #9
arulm3cx
arulm3cx's Avatar
-GT3M2
RA probably not this year. VIR next with track advantage and done for the season.
Nice. 36 hot what I aimed for. Probably need to aim for 35.
www.gowithaci.com
      10-30-2023, 11:17 AM   #10
sly1types
Drives: F80M3 and E46M3
I would love to see some pics to see how they look on a 10.5" and 11".
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104
E46 M3
F85 X5M
https://www.instagram.com/fastmacm3/
      10-31-2023, 10:10 PM   #11
ZPD
Drives: 2022 M850i GC, 2023 G87
I have run these tires for 3 track days. 37 psi hot felt pretty stable. YMMV
2022 M850i
2023 M2; MCS 3-way coilover, Vorshlag Camber plates, 19" Apex VS-5RS, 305 Nankang CR-S, Adro wing, IRL exhaust, Racechip, Mishi Skidplate, KG Splitter; IG:g87_43
      11-06-2023, 08:16 PM   #12
BlueBeamer
Drives: 23 M4 Comp xdrive
Curious on how these perform as now in stock sizes. Debating them or cups or AD009s
      11-06-2023, 08:43 PM   #13
shwayne5
shwayne5's Avatar
Drives: BMW M3 G80 RWD
My only experience is with cup2s. They’re sticky but tend to drop off relatively fast after both pressure and temperature build. The fronts will go over 40psi on hot days after 10 minutes. You can build 10+lbs of pressure and it’s prudent to pit and let some air out.
One major caveat I’ll issue is that each situation is highly variable. How hard your running your car, track temps, starting pressure, and the track you’re running on will all change what I said above. These cars are heavy (dead horse) and the fronts are what you’ll need to keep a close eye on.
      12-18-2023, 04:51 PM   #14
BlueBeamer
Any further insights on these tires? Anyone drive on them daily?
      12-18-2023, 07:54 PM   #15
arulm3cx
arulm3cx's Avatar
Daily 200 TW is not a good idea in a prefect world. Nankang doesn’t do well in wet. Definitely can handle short distance daily commute when weather is right. I drove to and from track and worked ok. Due to softer compound prone to road hazard.
www.gowithaci.com
      12-21-2023, 10:34 PM   #16
ZPD
Great track tires but I wouldn't recommend them for a daily tire. They would be dangerous in the rain and you probably wouldn't even get 10,000 miles out of them.
As a side note- I got 7 track days out of them before I started to show cords on one tire. Two of those days were at COTA. COTA eats your tires for breakfast and brake pads for lunch
2022 M850i
      12-24-2023, 09:45 PM   #17
BulkBen
Drives: G80 M3, Mini x 2, Lotus x 4
That sounds very high to me, on lighter cars I’ve found the CRS’s to drop off much over 34psi or so.
