05-24-2022, 10:48 PM | #2 |
Rep 14,115
Drives: G82 M4C X-Drive
There is no stipulation against HPDEs. If it's the same warranty fine print as my F80, then you should have no problem so long as you are worn down to the last I think 1/8 in. of pad. Don't quote me on that number, I'm just going off memory. You can call your SA to get the right number.
However, if they see aftermarket track brake pads installed then they will NOT warranty your rotors. So make sure they are not installed when you bring your car in.
jocamero48.50 |
05-25-2022, 12:41 PM | #3 |
Rep 32
Any update on this? I'm in a similar position with a warranty concern, but also have BMW UC+ which covers pads. They told me they can't use UC+ until the pad wear light comes on. Well, after only 6k miles, the rear brake pad light came on.
Update: dealer replaced pads when they were worn, then replaced rotors+pads when the rotors were worn. Last edited by jocamero; 09-06-2022 at 09:40 PM.. Reason: Update |
06-20-2022, 08:01 AM | #4 |
Rep 1,209
I was shocked to see how fast the rear pads were wearing when I pulled my winter wheel set-up a couple of months ago, then I realized how many interstate on ramps I took at full blast. Stability control is always kicking in to keep me off the Armco. The cost of fast acceleration is accelerated rear pad wear. It looks like you don't need to be on track to need new rear pads pretty often.
2017 X5 35d (Performance Center delivery March 2017)
2019 230i X-drive 2022 M3 base 2000 328i sedan (UUC suspension - still the favorite), 2006 M3 slick top - Alpine White/Cinnamon SOLD! 2008 E90 M3 SOLD! 1991 325iX (both great), 2019 Miata RF - various others not as memorable but gone. |
BMWRacer5232519.00 Limegrntaln13472.00 |
06-27-2022, 10:54 PM | #5 | |
Rep 92
07-01-2022, 03:25 PM | #6 | |
Rep 383
09-29-2022, 10:51 AM | #7 |
Rep 83
To make sure I'm understanding - BMW will replace pads under the STANDARD warranty? (I did not purchase any kind of additional warranty/coverage)
Thanks in advance. |
inlinejunkie24.00 |
