01-26-2023, 10:37 PM | #1 |
Rep 35
G80 Aftermarket Clutch Options
I have a 2022 G80 MT with Clutch Masters FX 400. I have had nothing but trouble with this upgrade and I am looking for suggestions and alternatives. The clutch does not fully disengage at the stop. I tried replacing slave and had tranny dropped 4 times already.
Are there alternatives? Does anyone have experience with this clutch? |
01-26-2023, 11:05 PM | #2 |
Rep 1,367
Watching...
That's a bummer man :/. I haven't heard much from folks with this upgrade but I'm very interested. Manufacturer say anything? |
mark_g80_mt42.50 |
01-26-2023, 11:24 PM | #3 | |
Rep 35
So 4 x 1000 for the labour and 2 x 2200USD for the parts. Not counting the slaves I went through thinking that the slave was the issue. I’m totally lost for words and I’m back to square one where I was about 6m ago when i originally installed FX 400 We have a big group of MT G80 but I’m not finding any luck with solutions… Online, I can’t find anything compatible so I am reaching out for the first time to see if anyone out there has any info. |
01-26-2023, 11:36 PM | #5 |
Rep 7,008
I would hit up G80_Soom he has a working FX400 in his car. Maybe he can provide some insight? As to how well it works, I have no idea. Check this thread, it may help.
https://g80.bimmerpost.com/forums/sh....php?t=1916513
YT: G Dubyou |
01-26-2023, 11:49 PM | #6 | |
Rep 35
1- (original) cdv delete 2- second original cdv delete 3- F80 slave with no CDV 4- back to G80 with CDV untouched The second clutch kit I bought (in the car now) is feeling best ever but the shop told me that it will eventually go to the point it was with the previous clutch kit because there is resistance going into first gear because there clutch is not coming apparat far enough, at the point of resistance tou can feel the car etching forward slightly which was the issue with the previous. They are saying the slave is maxing out and working property but it’s not enough to push the disks apart. |
Limegrntaln13596.50 |
01-27-2023, 12:06 AM | #7 | |
Rep 7,008
The next thing was manual pedal adjustment. Does the clutch pedal manually adjust from under the dash? Like I said, I’m not sure how this system works. But I know we had some issues with clutch drag and adjusting the pedal, which changed the bite point, helped. Third, we stacked washers between the bell housing mount point and the slave cylinder. Meaning, remove the two slave bolts and get a washer that would fit bellhousing, washer, slave cylinder, then slave bolt. This moved the slave cylinder forward 2-3mm and would release the clutch. It sounds like if the manufacturer can’t provide anymore info, and that you’re stuck looking for solutions to their problem. Which always sucks. Im going to reach out to my buddy Norris in Virginia, he owns P2uned and Prayontoo Racing. They have some 8-9 sec Supras. I know hes starting to deal with manual Supras. One of his biggest race sponsors, is also Clutch Masters, and Driveshaft Shop. He also has a tuned G82.
YT: G Dubyou Last edited by Limegrntaln; 01-27-2023 at 12:15 AM.. |
ChrisM41656.00 mark_g80_mt42.50 |
01-27-2023, 07:13 AM | #8 | |
Rep 995
Drives: 2024 M4 Comp X-Drive
01-27-2023, 07:17 AM | #9 | |
Rep 35
The way that the slave cylinder is designed is to be put up right against the transmission, there is no way to make it go deeper. That would be a perfect solution. Plz touch base with me once you hear back from P2, the manual is B58 but I’m sure it’s very similar |
01-27-2023, 07:22 AM | #10 | |
Rep 35
01-27-2023, 01:06 PM | #11 |
Rep 7,008
Unfortunately, I think the manual just came out for 2022.
YT: G Dubyou |
M_Torx335.50 |
01-27-2023, 01:14 PM | #12 |
Rep 35
01-27-2023, 01:25 PM | #13 | |
Rep 7,008
Pulling the rubber boot off, and the pushrod falls out, because all it does, is just push on the face of the slave cylinder hydraulic plunger. If that’s the case, get a slave extension custom milled out of billet. Try a few different lengths. Like this. https://www.rtmracing.com/xcart/prod...roductid=18900
YT: G Dubyou |
ChrisM41656.00 DocWeatherington2943.50 |
01-27-2023, 05:42 PM | #14 | |
Rep 35
Initial communication was with L***, he sent me the clutch disk and pressure plate only. K**** asked me to send the kit back or to just buy one at at a better price, I went with the new kit because rental alone would have cost me the price of the clutch. I haven’t reached back to him to let him know that the second kit is flawed🤷🏻‍♂️ I am waiting for rhe shop to send me a detailed email with the findings. Let’s put it this way, when I’m pull up to the light and let the clutch out, going back into first, there is resistance and the car starts moving forward on flat ground. That’s with the brand new clutch I hope this answered your question. I also took the slave apart and I don’t think I can do anything with it… push rod is fixed and if I pop it open I can’t put it back to original. Push rod is fixed to the piston. I also tried slave extension and it didn’t help I am not sure why, maybe it’s maxing out… I made a little condom looking thing to put over the end of the push rod which killed some of the pedal which I thought was because the extension +rod is maxing out. |
01-27-2023, 07:36 PM | #15 |
Rep 382
Following
01-27-2023, 08:57 PM | #16 | |
Rep 7,008
I shot him the reply. Let’s see what he says.
YT: G Dubyou |
mark_g80_mt42.50 mattssi880.50 |
02-05-2023, 10:31 PM | #17 | |
Vitipr
171
Rep 352
Edit: Shout out to Luis at Clutch Master for never returning my clutch back, and money 😂. |
02-06-2023, 11:13 AM | #18 | |
Rep 35
I did as he suggested and yeah, wasted money as we expected |
vitipr171.00 |
02-06-2023, 08:00 PM | #19 |
Vitipr
171
Rep 352
Yup. Similar situation. He also suggested a few things and nothing. $5k later car was put to stock and sold. They dont care about your money and/or time. Lesson learned! Hopefully you can somve your situation I know it can be very frustrating.
02-08-2023, 03:33 AM | #20 |
Car'a'carn
473
Rep 751
Well this sucks considerkng this was my go to for when I mod the G87
Limegrntaln13596.50 LuckyBrand1416.00 |
02-08-2023, 03:48 AM | #21 | |
Rep 7,008
Spec, Tilton, ACT, Exedy, Sachs, Southbend, Xtreme, QuarterMaster. Etc. I would think QM, and Tilton would be most interested. They make twin disks for just about everything.
YT: G Dubyou |
02-08-2023, 10:25 AM | #22 | |
Car'a'carn
473
Rep 751
The post said only 15 were sold. That's not a lot of demand |
