10-25-2021, 12:50 PM | #45 |
Rep 1,075
10-25-2021, 12:55 PM | #46 | |
Rep 10,168
Ive put on about 275 miles now since the drop.
r33_RGSport12973.50 |
10-25-2021, 03:14 PM | #47 |
Rep 1,075
This is where mine sits |
10-25-2021, 04:10 PM | #48 |
Rep 10,168
Looks good to me--the M4 starts off higher in the rear as you well know
@r33_rg
10-26-2021, 12:56 PM | #50 |
Rep 10,168
Of course they wont--- not sure where you reside but there are alot of good indy shops that we can use in CA.
10-30-2021, 07:11 PM | #51 |
Rep 116
How are you getting the spring out on the front with AWD cars. On the RWD, I just undo the shock from the top hat, leaving the top hat attached to the car, then lean the strut forward and remove the spring. On the AWD I can't get the strut/knuckle low enough to clear the strut tower. I tried removing the axle bolt for extra room and still no luck.
Looked at TIS and they're saying to remove the entire knuckle, so upper/lower control arms, tie rods, brakes,rotors,sensors etc and pull the knuckle and shock out together. Seems crazy |
10-30-2021, 10:37 PM | #52 | |
Rep 10,168
r33_RGSport
marauder138.00 r33_RGSport12973.50 |
11-01-2021, 12:21 PM | #53 | |
Rep 10,168
Adding him again to see if his lazy ass will read r33_RGSport
11-01-2021, 12:57 PM | #54 | |
Rep 18,718
The next sequence it what I don't remember exactly. It is either swing the whole shock assembly out with the hub-carrier or remove the shock from the hub carrier while top mount still attached. But, one of those 2. I wonder why other shops that has done many lowering spring didn't chime in.
marauder138.00 |
11-01-2021, 01:15 PM | #55 | |
Rep 116
11-06-2021, 12:54 AM | #56 |
Rep 39
@r33_RGSport what's your mss secret because the mss front height on my g82 is not it an needs more low 😬
11-06-2021, 08:51 AM | #57 |
Rep 18,718
PM me your email address and I'll send you the detail.
11-06-2021, 10:33 AM | #58 |
Rep 10,168
because I dont drive it everyday, I forget its dropped and I truly dont even realize it with this setup... the linear spring setup is really a game changer
11-06-2021, 11:03 AM | #59 | |
Rep 190,821
We're installing the MSS kit on the shop's M4 this month
11-07-2021, 08:56 AM | #61 |
Rep 190,821
per another thread he created, he states that the car has 15mm spacers all around and is experience slight rubbing
11-07-2021, 09:31 AM | #62 | |
Rep 10,168
Right and wrong 15x4 is correct and rubbing too but that was on my Portimao G80 with Pirellis and this car with the PS4 does NOT rub at all.
11-08-2021, 03:55 AM | #63 | |
Rep 137
11-08-2021, 07:56 AM | #64 | |
Rep 10,168
r33_RGSport
11-08-2021, 07:58 AM | #65 |
Rep 137
11-08-2021, 08:48 AM | #66 | |
Rep 190,821
On the G82, 12mm in the front is too aggressive. I had to switch to 10mm.
