08-19-2022, 04:18 PM | #67 |
@OrlandoAUTOwerks @OrlandoPerformance
42
Rep 43
7-8 days max is what we're seeing when we send Femto the ECU's (Just had 3 customers from Florida, 2 from North East) sent and received 7 days
If they say not to expect your ECU until 9/1/22 are they doing it for free? That's like 3 weeks wait time. |
StockM4170.50 |
08-20-2022, 08:32 AM | #70 | |
Rep 608
G80 Comp, Hcp custom e50, 9.69@141
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53 F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml. Ig @mcc420 |
08-20-2022, 09:50 AM | #71 | ||
Rep 458
But no i will not be tuning with them. Im doing BM3. |
08-20-2022, 07:55 PM | #72 |
Rep 608
When I sent mine out I needed to send them a special code that bm3 sent me.
08-21-2022, 12:13 PM | #74 |
Rep 608
* Please consult with each of the flashers support will they work for you or not *
Unlocking options: 1. Regular unlock - you can upload calibration (ONLY!) area using femto obd flasher beta, mgflasher, mhd and bm3 2. Custom unlock - requires preloading of custom code for each of the flashers (if applicable, such as torque limiter removal, map switching etc). Currently we can preload mgflasher custom code (app adjustable torque limiter patch) and mhd (torque limiter removal patch), bm3 ( torque limiter removal). 3. Remote engine start fix (EUR 100 extra) - remote engine start feature will work after tuning as usual ONLY if it was enabled and working before. For option *2* you need to decide which flasher are you going to use, because their custom code can't be re-used for each other and can be uploaded only while your ECU is at our labs. Please consult with flasher of your choice about your exact VIN support and their custom code availability, since we can't track their changes.
08-22-2022, 04:06 PM | #75 | |
Rep 458
08-22-2022, 04:10 PM | #76 |
Rep 375
Just got my ecu back and flash bm3. My m1 and m2 buttons not working and remote start. Anyone have these issue and re-enable them. I requested to maintain my remote start so wondering if I have to enable it.
08-22-2022, 04:25 PM | #78 |
Rep 764
08-22-2022, 04:53 PM | #79 |
Rep 374
That happened to me. Have a bit of a drive around and then try reprogramming them.
08-22-2022, 04:54 PM | #80 |
Rep 375
08-22-2022, 04:55 PM | #81 |
Rep 458
08-22-2022, 05:39 PM | #83 | ||
Rep 608
08-22-2022, 06:33 PM | #84 |
Rep 375
My issue has been solved. The problem was plug 4 going into the ecu wasn't seated properly. This took some hassle to try and seat it until it clips in. Had to wiggle it and push down hard until it clicked. All my settings are working now. Hope this helps anyone in the future.
BTW it has been great working directly with Femto and if anyone has questions you can message me. Turn around time was 12 days for me but I'm guessing it would be alot quicker for someone else if you mail it on Monday you most likely wait less. I waited longer because DHL does not work on the weekends so your package will just sit until the following Monday. |
Neophyte158.00 |
08-22-2022, 10:40 PM | #85 |
Rep 458
08-23-2022, 08:53 AM | #86 |
bmw tech
473
Rep 365
I can vouch for using jairo at orlando autowerks. We have sent 4 ecu's out now to be unlocked via him and its been a 7-8 day process every time.
Lehigh Valley Motors
193 Front Street Hellertown, PA 18055 484.214.6464 Mainentance-Repair-Performance |
08-23-2022, 10:54 AM | #88 |
Chief Petty Officer
647
Rep 520
I have no horse in this race, but from what I'm reading you started blowing them up within 72 hours of them receiving your ECU. Patience is a virtue.
