      03-27-2024, 06:43 AM   #1
RichardGM4
RichardGM4's Avatar
527
Drives: 2024 G80 M3 CS
Change drop in filters without removing strut brace
I've seen a couple of vids where the guy removes the front part of the G8x strut brace prior to removing the OEM air box covers, so that he can replace the drop in filters with aftermarket ones (as well as removing the charcoal filters)
Does anyone know if it's possible to access the air box sufficiently to change the filters (and remove the charcoal filters), without removing the strut brace?
Reason I ask is I'm trying to see if I can change them without removing it on my CS, as I don't currently have a torque wrench, so doing it without removing it will save me some hassle (or re-installing it without the correct torque)
Thanks
Current: BMW G80 M3 CS (2024 BSM w/ Bronze/Gold 827M wheels)
- BMW G82 M4 Competition xDrive (2022 TBII w/ Silverstone/Black & M Carbon Pack)
- BMW F82 M4 Competition (2019 BSM w/ Silverstone)
      03-27-2024, 09:40 AM   #2
Drives: S4
It can be done. With the CSL brace in place, you’ll have even less wiggle room, but loosen the clamp on the hose and work the top of the air box out carefully. Biggest thing to pay close attention to is seating it properly after the fact.
      03-27-2024, 11:58 AM   #3
Boomer 2019
Track Rat
Boomer 2019's Avatar
Drives: 2023 M4 Comp
You can install them without removing the strut brace on the G80 & G82 as well. It's fiddly as Hell but it can be done. I did it a few days ago. Beats removing the brace.
      03-27-2024, 01:27 PM   #4
markoz28
Drives: BMW 2017 340i, BMW 2020 M340i,
The brace on the G80 comps are easy to take off and put on. I can remove both in 2 min. Is it that difficult in the CSL?
      03-27-2024, 01:48 PM   #5
christianb5s4
Drives: Built 2001 Audi S4
Did the install of filters and removal of the charcoal filters without removing the brace. There's just enough space to squeeze the original ones out and install the new ones.
Took about 15 minutes total.
2019 G05 X5 x40i, built 2001 600whp B5 S4.
      03-27-2024, 01:52 PM   #6
Drives: S4
He’s just being overly anal about torque specs and not having a torque wrench. That’s why he asked.
      03-27-2024, 02:22 PM   #7
markoz28
Oh I got you. I would just torque them to (goodandtight). If I was tracking the car then I would spend the cash on a torque wrench to put to spec.
All the bolts are roughly 20ft lbs and the center is roughly 42ft lbs. So not very tight at all. Hand tight on all of them and then a bit of added muscle to the center bolt. No biggie
      03-27-2024, 04:09 PM   #8
Drives: S4
Some people on here don’t believe in the old “how much power did it take to undo the bolt by hand tools?” and to basically use that same amount putting it back on. I think because people don’t use hand tools anymore, it’s become a lost art.
      03-27-2024, 05:07 PM   #9
christianb5s4
The torque specs are a bit unique, as I learned through installing the CSL brace. Torque specs of 26nm plus another 120 degree turn.
      03-28-2024, 05:26 AM   #10
RichardGM4
RichardGM4's Avatar
527
Thanks Christian - is 26nm used on all the bolts on the CSL/CS brace?
      03-28-2024, 07:55 AM   #11
Needsdecaf
Needsdecaf's Avatar
6608
Drives: 2024 G80 Comp xDrive
It's a little more fiddly since it mounts at more points and is all once piece so you have to take the whole thing out. Not a PITA by any means but still if you want to do it right you've got a bunch of bolts to torque. .
      03-29-2024, 02:04 AM   #12
RichardGM4
RichardGM4's Avatar
527
Yeah that occurred to me - the whole strut brace will have to come off, not just the front “V”
      03-29-2024, 07:27 AM   #13
Drives: S4
Just take the hose clamp off and wiggle the box tops off. Get in there and put your eyes on it… it’s not that much of a job.
forcefed2567.00
