      03-26-2024, 06:49 AM   #1
vasillalov
Mad Linux Guru On The Loose
vasillalov's Avatar
1121
Drives: 2008 335i Sedan, 2023 M3
2023 BMW M3  [0.00]
2008 335i E90  [8.00]
Aftermarket 6MT mounts
Hi everyone,
What vendors are selling high durometer mounts for the 6MT transmission in our cars?
There is significant driveline flex which I would like to reduce or eliminate if possible.
6MT | COBB | AR | AE | Forge DV | HPF | P3 Gauge | Hybrid Intake | O.S.Giken TCD | All M3 bits | TCKLine | StopTech | UUC | ER | SPEC
      03-26-2024, 09:16 PM   #2
B_davis
Drives: M4
IND carries the Rogue Engineering Rear Carrier Bushing Mount
      03-27-2024, 07:10 AM   #3
vasillalov
vasillalov's Avatar
1121
2023 BMW M3  [0.00]
I already have that. That's not what I am asking. I am talking about the rear of the actual transmission.
      03-31-2024, 03:43 PM   #4
G80_253
Drives: BMW G80 M3
I've been looking for the same thing. I emailed Rogue Engineering and VTT asking if they had any plans for mounts or inserts and both said no. Looking like we may be out of luck unless we can come up with more interest for it.
      03-31-2024, 06:34 PM   #5
vasillalov
vasillalov's Avatar
1121
2023 BMW M3  [0.00]
Ughhh, that's discouraging. I will investigate the rear transmission mounts when I get under the carvto replace the shifter carrier bushings, hopefully soon.
      04-01-2024, 09:47 AM   #6
testing02hwr
Drives: 340i
I wanted to do an Autosolutions SSK later this year and also noticed the flex when under acceleration. It sometimes won't even let me shift 1->2 with this flex. Searched the forums and someone asked Ron about it...
Originally Posted by evidence View Post
Forgot to mention, I asked Ron about the rear bushing upgrade some vendors sell. He said he would keep the OEM rear bushing, which allows the shifter/carrier to move with the transmission. This is most important for precise shifting. Replacing the rear bushing means the shifter might feel a bit more solid when wiggling it, but it will be more locked in with the body, and the transmission can 'move away' from the shifter under load.
He said the only time you'd want to replace the rear bushing is if you went w a hard transmission mount, limiting its movement from the body. Then you could do the rear carrier bushing also to tie all 3 shifter/body/transmission together in a solid way.
I don't plan to upgrade until end of year but I will ask about it when I do order.
      04-01-2024, 10:27 PM   #7
G80_253
Drives: BMW G80 M3
Yeah, I may end up buying a spare mount and filling it with polyurethane just to see how it goes. I have VTT rear diff and engine mount inserts that I’m waiting to install as well.
