      07-14-2023, 08:19 AM   #1
PMW0801
Drives: BMW M4
Active Autowerke GESI catted down pipes
I am considering doing down pipes on my G82. Really don't want to deal with CEL and I see that Active Autowerke is the only one that guarantees no CEL. Their GESI catted DP's are 400. I see other companies have 200 and 300. Really want to add more sound to my current setup (Active Autowerke non resonated single midpipe and Valvetronic axle back with Dahler valve controller). Don't want to spend over $2000 and be disappointed with these down pipes. Any suggestions? Any body have the AA down pipes that can shed some light on how they sound? Thanks for any help.
      07-14-2023, 08:41 AM   #2
misterpiz
Drives: BMW M3
Much cheaper option would of course be 200CELL and o2 spacers
I hear mixed reviews though on CEL, common consensus is no CEL with that setup installed correctly but some cases of still getting a light.
With a $1500ish price difference it’s definitely something to consider
Daily Driven did a full video review on their GESI pipes though and should give some good insight
Either way good luck!
      07-14-2023, 08:57 AM   #3
CMW33
CMW33's Avatar
312
Drives: 2024 G80 Comp
AA's stuff is very high quality and you will not get a CEL with their catted downpipes. I have had their downpipes on my other cars for thousands of miles with no CEL. I can't speak to sound differences for G80 though. There was only a mild increase in sound on my other cars. Biggest difference was at startup, mainly.
Do you have to worry about passing smog in NJ?
      07-14-2023, 09:23 AM   #4
Rodizzle
Rodizzle's Avatar
397
Drives: Bmw M3
You get a CEL “P013x - 02 Sensor Delayed
Response” . I’m going from catted to catless DP cause of that . The car sounds great tho.
I’d recommend $500 catless Dp with spacers .
      07-14-2023, 10:08 AM   #5
PMW0801
Drives: BMW M4
Why are you going catless DP with spacers? You wont get the CEL you are talking about? I really don't want any CEL. I also don't want to spend over $2000 on AA DP's if I'm not going to get that much of increased sound.
      07-14-2023, 10:14 AM   #6
Rodizzle
Rodizzle's Avatar
397
Drives: Bmw M3
I don’t mind the CEL, but unfortunately, remote start doesn’t work if the CEL is on. The CEL comes and goes; approximately 80% of the time, it’s on.
Currently, I have MAD’s catted DP with Daddy’s catted spacers. However, I just received a catless Fatboy DP. I’m going that route with my Daddy spacers. The spacers work 100% with the catless DP.
I really don’t see the point of spending over 1k on the DP itself. Save yourself some money, go catless with Daddy’s spacers, and you’ll be fine.
      07-14-2023, 10:20 AM   #7
PMW0801
Drives: BMW M4
Thanks for the information. Just wanna make sure I understand this correctly. So the O2 spacers with catted DP's I'll get the CEL 80% of the time. If I go catless with the O2 spacers no CEL? I'll get the smell with the catless though right?
      07-14-2023, 10:40 AM   #8
Info@mad-us.com
Info@mad-us.com's Avatar
1925
Drives: bmw
Once someone finds the right combo of spacer to go with the catted it should work just as well.
- Click Here
Performance Parts For Your Bmw At Crazy Low Prices!
Email: info@mad-us.com
      07-20-2023, 08:37 AM   #9
Jims M3
Drives: F95 X5M, F80 M3, C7 Z51
I have GESI pipes on my F80 no compromises and no smell.
Bostro530.00
      07-20-2023, 10:39 AM   #10
Info@mad-us.com
1925
Drives: bmw
They work great no doubt. I think people are struggling with the cost vs performance benefit compared to staying with the factory downpipes.
- Click Here
      07-21-2023, 07:18 AM   #11
L33t
Drives: 18 M3 F80
So is this confirmed now?
      07-21-2023, 11:30 AM   #12
anakratis
Drives: '24 X3M Comp
On a car that's nearly 100k, 2-3k is little money to spend for peace of mind IMO, if you really want upgraded downpipes
2024 F97 ///X3M COMP [AW/SO]
Active Autowerke EL Mid Pipe + Axle-back | H&R Sport Springs
Bostro530.00
10SecGG504.00
      07-21-2023, 02:44 PM   #13
Info@mad-us.com
1925
Drives: bmw
I was referring more to the Dollar to Hp cost which is undeniably high. Like I said they work as advertised and it's a excellent product however, they flow closer to the stock downpipes than they do a catless setup which can make it a hard pill to swallow for most especially for those in the quest for horsepower.
- Click Here
      07-21-2023, 07:34 PM   #14
anakratis
Yeah if you're going on a quest for horsepower you're likely tuning and can therefore tune out the CEL haha...at which point it doesn't matter which way you go. I don't like catless personally because I can't stand the smell but even then a 200 cell cat is good enough.
      07-24-2023, 09:35 AM   #15
mike@x-ph.com
mike@x-ph.com's Avatar
I used this on my M4 and ultimately had to uninstall it due to a considerable increase in exhaust noise. If you're concerned about the system not providing enough sound, I can assure you it's unlikely to disappoint.
https://x-ph.com/sale/
Phone number 702-494-9435
      08-07-2023, 04:11 PM   #16
fpgg80
Drives: 2023 M3 Competition
do you think the awe switchpath with non res midpipes and the gesi downpipes will be too loud?
      08-07-2023, 04:23 PM   #17
mike@x-ph.com
Which midpipe?
      08-08-2023, 02:46 PM   #18
ONLYACTIVE
Drives: RAPTOR
I understand your dilemma and that's why we offer the GESI catted DP's. No smell, improved sound and performance but most of all not having to remove them every time you need to pass smog. The labor alone on and off each time makes up the difference. Buy the other DP's and run the risk whether the spacer works or not, and if you will pass smog.
      08-09-2023, 12:25 PM   #19
fpgg80
Which midpipe?
i have the awe non res midpipes rn
      08-09-2023, 02:29 PM   #20
ONLYACTIVE
Drives: RAPTOR
The GESI DP's are just a bit louder than stock, catless is extremely loud, sounds very unrefined for a BMW, 200 cel not sure as never heard them in person, but can only assume they are between catless and GESI. Adding MP and rear exhaust will also get louder.
      08-09-2023, 03:50 PM   #21
tom @ eas
tom @ eas's Avatar
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
IMHO, putting that $$ towards unlocking/flash tune will yield much more power and better driving experience than what downpipes-only can provide.
      08-09-2023, 04:13 PM   #22
PMW0801
Drives: BMW M4
Here's an update: So I pulled the trigger on a set of Evolution Racewerks catted down pipes. Had them installed last week along with just spacers. Crossing my fingers no CEL yet. As far as sound goes: HOLY S**T!!!! Sounds AMAZING!!! Cold start is loud but after the warm up isn't too crazy. Car on normal driving sounds great. Enough pops and burbles when you let off the gas which was decreased after I added the Valvetronic axle back to my AA single non resonated mid pipe. When you get on it is sounds like an ANIMAL!!! Absolutely love this set up now. Thanks for all your help and replies to this thread. It's really appreciated!!!
