03-08-2024, 06:36 PM | #1 |
Rep 50
Do Driver and Passenger Sides Valve Open equally
I just had my full Valvetronic exhaust installed and I have not installed the valve controller yet.
I did notice that when I go into M2 only the driver side flap opens up partially and the passenger side stays closed. Are both side supposed to operate equally (both close and open together)? |
03-08-2024, 11:56 PM | #4 | |
Rep 23
shundal64.50 |
03-09-2024, 09:17 AM | #5 |
Rep 50
Thanks for confirming that they should both me operating together (which I expected). I will get under the car and remove the actuator a check if there is any binding.
03-09-2024, 09:34 AM | #6 | |
Rep 50
03-09-2024, 12:40 PM | #8 |
Rep 1,935
Is the flap inside fully open or still partially closed? It should have 90 degrees of movement.
03-09-2024, 01:17 PM | #9 |
Rep 191,065
if it's installed correctly and not defective, it should open equally
shundal64.50 |
03-09-2024, 02:46 PM | #10 |
Rep 1,935
Pull the bolts out and see what's causing the interference.
03-09-2024, 07:03 PM | #11 |
Rep 50
Update: after unbolting and unplugging the oem valve actuator, I plugged it back it and it is now operating properly.
I double checked to make sure the valve springs were seated properly with lots of tension and no valve rattle etc. |
Sonic RR124.50 |
03-11-2024, 10:50 AM | #12 |
Rep 191,065
03-11-2024, 12:36 PM | #13 |
Rep 34
Since you just looked at this, which springs did you end up using? Is it the BMW style c-clips or the helical style provided by valvetronic? After switching my system back to the oem actuator, with sst valve controller, I haven’t been able to remove the rattle on my driver’s side valve. Thanks for any help.
03-11-2024, 06:25 PM | #14 | |
Rep 50
mephism49.50 |
