      04-16-2024, 06:36 PM   #1
wtwo3
wtwo3's Avatar
17982
Drives: 23 X7 40i; 23 M3; 24 cooper s
Valvetronic exhaust with different tips
Has anyone with the valvetronic exhaust installed different tips? I have the standard 3.5" chrome tips that came with the system - and they're pretty sad - single walled and narrower than OEM. I'm hoping to install some thicker tips with a bezel similar to the OEM ones, but unsure of fitment and if I'm stuck with proprietary Valvetronic tips.
2023 BMW X7 xDrive40i
2023 BMW M3 6MT
2024 Mini Cooper S Convertible
'20 BMW m340i... '20 BMW X5 40i... '16 Infiniti Q50 RS 400... '10 Lexus RX 350... '08 Lexus IS 350... '00 Nissan Maxima... '93 Nissan Maxima
      04-16-2024, 07:06 PM   #2
chris3g
Drives: 2023 M3 xdrive
Any tips with a 2.5” inlet diameter can work, there’s nothing proprietary it’s just clamps on a pipe. If you’re interested in carbon tips I have a set that I bought but ended up not using that i can sell you.
wtwo317981.50
      04-16-2024, 07:52 PM   #3
wtwo3
wtwo3's Avatar
17982
Thanks for the info. I'm actually looking for something chrome/brushed aluminum. I really wanted the arm motorsports tips since they're a beefy 112mm, but the inlet is also quite large at 82mm (3.2") so didn't think it would work.
2023 BMW M3 6MT
      04-16-2024, 10:29 PM   #4
BMW Bold
Drives: 2023 G80 M3 6sp
Bump
      04-16-2024, 11:04 PM   #5
wtwo3
wtwo3's Avatar
17982
Ended up ordering Active autowerks tips. 100mm outer diameter (close to stock 4") with 70mm inlet, so they SHOULD just be able to clamp onto the Valvetronic axleback pipes. I'll report back when I receive them and try to install them.
https://store.activeautowerke.com/pr...ctive-exhausts
2023 BMW M3 6MT
      04-17-2024, 10:17 AM   #6
mike@x-ph.com
mike@x-ph.com's Avatar
Looking forward for your feedback
https://x-ph.com/sale/
Phone number 702-494-9435
wtwo317981.50
      04-20-2024, 11:02 AM   #7
wtwo3
wtwo3's Avatar
17982
These just arrived in the mail. Will try and get out to put them on today and report back.
2023 BMW M3 6MT
      04-20-2024, 11:11 AM   #8
mike@x-ph.com
Good luck
wtwo317981.50
      04-21-2024, 04:46 PM   #9
wtwo3
wtwo3's Avatar
17982
So things did not go very smoothly. The Valvetronic exhaust pipe is 63.5mm in diameter. The inlet diameter for these tips ranges from 68-73mm. So there was a good 4.5mm+ gap.
I've done a very temporary fix - I wedged some screws between the exhaust pipe and the tip inlet and then clamped down on that hard. They're on there sturdy, but eventually I'll need to do something more permanent like weld some metal to the exhaust pipes to increase the diameter a bit.
BEFORE: these are the 3.5" chrome tips that come with the Valvetronic exhaust:
AFTER: The AA 4" tips. Still need to align them better but will do so when I get the permanent fix in place.
2023 BMW M3 6MT
      04-22-2024, 11:38 AM   #10
mike@x-ph.com
looks great, the AA look better in that picture
      04-22-2024, 02:25 PM   #11
Info@mad-us.com
Info@mad-us.com's Avatar
1933
Drives: bmw
Attachment 3440013
Attachment 3440012
I would try a metal sleeve of some kind. Careful you don't lose them with all the vibrations back there.
- Click Here
Performance Parts For Your Bmw At Crazy Low Prices!
Email: info@mad-us.com
wtwo317981.50
      04-22-2024, 05:54 PM   #12
wtwo3
wtwo3's Avatar
17982
yeah while they're on there pretty tight and secure, it's a very temporary solution. Going to get some sort of metal piece welded to the exhaust pipe to increase the diameter to clamp the tips on to.
2023 BMW M3 6MT
      04-23-2024, 01:43 PM   #13
mike@x-ph.com
let us know how it goes
