04-12-2024, 03:09 PM | #1 |
sportscars only
3268
Rep 3,203
How best to peel a boiled egg
I don't wanna google and just want real life accounts from you guys. Don't wanna buy specialized equipment either. Tired of burning my fingers haha but I wanna eat them while still hot.
04-12-2024, 03:25 PM | #2 |
YNWA
1049
Rep 815
Saw a video of someone putting a hard boiled egg (with shell) into a jar with what I think was vinegar. Shook it well, and all the shell came right off in seconds.
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54 |
tranquility3267.50 |
04-12-2024, 03:27 PM | #3 |
Rep 537
We do a lot of deviled eggs for parties.
Eggs in room temp water, bring to boil in 15 mins, ice water, peel under running water. I've cleaned 30 or so at a time and it was not bad.
Pauly Wauly2306.00 tranquility3267.50 |
04-12-2024, 04:08 PM | #5 |
Rep 64
If I`m eating them right away, I peel them under the tap running cold water over them, or I put them in a bowl of cold water and they peel much easier.
Karma is real!!!....You keep doing people dirty and being a complete asshole and think God is going to bless you. It may not be today, or tomorrow, or next week, but what goes around comes back around. And when that bitch comes for you it`ll be tenfold!
04-12-2024, 04:51 PM | #6 |
Rep 817
Peel under water like mentioned above
-'24 X5MC,'22 430i
-'09 Busa,'05 GSXR-1K(GT28R turbo)'00 Busa(GT3582) Gone but not forgotten: -'22 X3MC,'20 M550i,'18 X2,F30 328xi,'07 E63 AMG (1st W211 63 in the 11s),997 C4S Cab,CLS55 AMG,E55 AMG,C55AMG |
04-12-2024, 05:15 PM | #7 |
Rep 537
Not related to eggs but having been kicked out of the house as a teenager, I was embarrassingly old when I learned instead of peeling a clove of garlic by hand just put it under the flat side of a chopping knife and smash it. Skin comes off quick that way. Wish boiled eggs had a trick like that.
04-12-2024, 10:12 PM | #8 |
Rep 1,078
Drives: Lots of BMWs
Garage List 2018 M4 Vert [0.00]
2006 Z4M Roadster [0.00] 1995 540i [0.00] 2008 BMW M5 [0.00] 2019 i3 Rex [0.00] 2021 X7 40i MSport [0.00] |
After boiling them put in a bowl with a lot of ice, after 5 mins you peel them. Its some 5-5-5 method wife uses weekly; 5 min in IP, 5 min pressure release, 5 min ice bath.
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX 2021 X7 40i MSport, 2006 Z4M 6spd |
04-13-2024, 12:48 AM | #9 | |
Rep 2,874
04-13-2024, 06:14 AM | #10 |
sportscars only
3268
Rep 3,203
04-13-2024, 10:00 AM | #11 | |
Rep 1,176
In a 1 cup (8 ounces) Pyrex measuring cup fill with 1 cup of cold (tap) water. Crack egg and gently let it slide into the water. I put nothing in the water. Put the cup in the microwave. I cover the cup with a paper towel. I set the timer to 60 seconds on full (950 watts) power. There can be some variability if one switches from a small egg size to a larger egg size. And the temperature of the tap water can play a role. Occasionally the egg will emit a "pop" signaling I used too much time given the size of the egg and the tap water temperature. You will probably need to do some experimentation on how long to let the egg sit in the hot water to ensure it is hard cooked to your satisfaction. When the egg is cooked I carefully pour the contents of the measuring cup into a large slotted spoon. After some bit of drain time I put the egg onto a plate. Added: For peeling pan cooked hard boiled eggs I use the technique I learned from my Mom. Pour off the water and then shake the pan hard enough the shells crack from the eggs hittihng each other and the side of the pan. The eggs are hot but the shells come off pretty easily. |
04-14-2024, 06:35 AM | #13 |
Not willing to take advice
4055
Rep 1,528
I tap the fat end of the egg lightly with a spoon before cooking, to crack the internal membrane. sometimes takes 3 or 4 hits to do it, but should sound like one of those snap dragons. Note this also make them easier if you're separating the egg yolks too.
Cook normal, peels much easier, but I do always do it under cold water.
Proud owner of 4 Turbos and 1 Supercharger
tranquility3267.50 Dochere227.50 |
04-14-2024, 09:04 AM | #14 |
Rep 1,176
Well, then peel the eggs the way it has been done for years.
Watched my Mom and she could have a pan of hard boiled eggs peeled in about as much time as it takes to type this. Not quite the same but you could try French Style eggs. In non stick skillet add butter then when melted add one or 2 or more eggs. Add a couple of tablespoons of tap water and cover the skillet with a tight fitting lid. Water steams the tops of the eggs and you can let them steam until they are hard cooked. |
04-15-2024, 01:35 PM | #16 | |
sportscars only
3268
Rep 3,203
Actually, I dunno why Rourke's character was so shocked by him biting into it, unless he felt his soul being consumed. I'd just be thinking 'ok weirdo' lol.
04-15-2024, 02:33 PM | #17 |
Rep 7,226
^ Good movie.
///MPhatic13915.00 |
04-16-2024, 03:50 PM | #18 |
Long Time Admirer, First Time Owner
18078
Rep 9,381
boil
cool by rinsing out hot water and dropping ice cubes in pan drop one or two into a plastic glass, shake a bit finish peeling, rinse in remaining cold water in pan
I have romped on her and I giggled like a drunk infant the entire time. - Sedan_Clan
