04-15-2024, 01:39 AM | #1 |
Rep 165
Slight drone with valvetronic midpipe?
Hey guys! I was wondering if ya’ll can give me some advice on this and what I should do
So I recently installed a valvetronic midpipe on my car(1st gen), as well as a dahler valve controller I noticed if i open the flaps and drive there is a decent amount of interior drone when driving in 2nd gear + in rpm ranges from 1.5-3k rpm’s, nobody I drive with really notices but it’s been getting on my nerves when I need to drive up a hill in 4th Anyone know is this a problem with all the mid pipes? Does the newer valvetronics midpipe fix this issue? Should I go the AA or IRL midpipe instead? What do you guys think I should do, this drone really kills the enjoyment of the car My car is the 6MT if that makes a difference Thanks in advance |
04-15-2024, 06:31 AM | #2 |
Rep 1,940
It's normal, pretty much every exhaust will have some drone.
04-15-2024, 06:38 AM | #3 |
Rep 348
This....I have the MAD non-resonated and hit drones at times in the 2k rpm range at time when the valves are at 100%. You eventually get use to it. You can also just put it in stock mode if you have a valve controller.
04-15-2024, 06:50 AM | #4 |
Rep 1,940
Yup the valve controller contributes to it, that's probably why the valves don't fully open at part throttle.
04-15-2024, 09:59 AM | #6 |
Rep 5,021
This^ Typically way more noticeable with a valve controller. This is the first bmw I have had that doesn't allow fully open valves in stock configuration.
04-16-2024, 01:29 AM | #7 |
Rep 165
Thanks for the reply guys! It all makes sense about the drone, when I default to the standard sport plus without activating my valve controller the drone is non existent, but once I open the flaps that’s when the drone appears, if there isn’t a fix then It is what it is! Thanks for the reassurance guys
Info@mad-us.com1969.50 |
04-16-2024, 07:59 AM | #8 |
Principle Over Feelings
289
Rep 98
Drives: BMW M4CX
Have you tried turning off the exhaust sound control button and opening the valves with your controller? Maybe the fake noise is causing part of the issue
'Life isn't about how you survive the storm, but how you dance in the rain'
04-16-2024, 09:52 AM | #9 | |
Rep 5,021
04-16-2024, 10:17 AM | #10 |
Rep 191,163
in my opinion, disabling the fake sound does help
LD289.00 |
04-16-2024, 05:34 PM | #11 |
Rep 228
Drives: 2024 PB M4 Comp xDrive
Just incase you happened to not know. I connected my mirror buttons to open / closed (stock) on Dahler controller. Easy as it gets to go stock efficient mode when I’m wanting 0 drone (EL Valvetronic v2 midpipe)
04-17-2024, 10:18 AM | #12 |
Rep 191,163
Thats the way to do it
ItsConnor234.50 |
04-17-2024, 03:53 PM | #13 |
Rep 22
I just did the valvetronic axle back with the valvetronic el mid pipe. What a difference. Mid pipe alone I never drove around with the valves open unless I was in sport/sport+ mode because it did drone a little bit. Once I put the axle back, the drone is not as apparent when driving in comfort modes and I tend to drive with the valves open a lot more. IMO the stock muffler holds a lot of noise in the cabin.
04-17-2024, 04:18 PM | #14 | |
Rep 18,849
If looking to switch midpipes, we like the Evolution Racewerks midpipes, they fit and sound great.
Chi5828.50 |
04-18-2024, 10:19 AM | #15 |
Rep 191,163
Correct, it muffles a lot of noise, and that could be good or bad depending on the person.
