03-19-2023, 03:05 PM | #23 |
Rep 13,011
03-19-2023, 03:24 PM | #24 | |
Rep 13,011
The 0.1" over the OEM tire diameter is what is rubbing the liner. |
03-20-2023, 10:34 AM | #25 |
Rep 8,067
Drives: 2024 X5 M60i
I have 5mm spacers all around with my 1000M wheels and still have rubbing up front at full lock.
Honestly, BMW just did not do a good job of testing these in full with a stock setup…or at the very least they did proper testing but just didn’t give a fuck and is selling them anyways. I don’t regret getting these wheels in the least bit as they look killer but given the quality control issues in paint I’ve experienced and the fact that they rub on a stock setup just leaves me a bit disappointed since these are OEM and they should be perfect.
04-17-2023, 01:35 PM | #26 |
Rep 52
Any updates with this? I am considering adding the 1000m wheels to my build. The only thing holding me back was really the look of such a small sidewall but now this rubbing issue seems to be a bit of a problem.
04-17-2023, 02:19 PM | #27 |
Rep 16
Drives: 2021 M3 Competition IOMG
The dealership changed the fender liner but they can’t seem to give me a proper reason for the issue in the first place.
Lemongrease101.50 |
04-17-2023, 06:54 PM | #28 |
Rep 13,011
04-17-2023, 10:28 PM | #29 | |
Rep 8,067
These are the correct tire sizes as sold by BMW themselves for the G8x. I do have 5mm spacers all around so that could possibly account for no rubbing in the rear on my G80. However, it still stands that these are the tire sizes sold directly by BMW specifically for the G8x cars.
Lemongrease101.50 |
04-17-2023, 11:12 PM | #30 |
Rep 52
04-29-2023, 10:33 AM | #31 |
Rep 153
Hello
i installed the 1000M wheels with my 15mm spacers in the front. They rub... I removed the spacers, and they dont rub anymore. but it looks like shit now I want to try 10mm spacers, but on the r44 website i read this: "Please note: 10mm spacers SHOULD NOT be used on any G8X vehicles." why would that be? Last edited by dieter09; 04-29-2023 at 12:09 PM.. |
04-29-2023, 02:05 PM | #32 | |
Rep 311
It is DANGEROUS to have those 10mm spacers on (the Bimecc ones).
Current: 2023 ///M3 Competition xDrive - SSG
dieter09116.50 |
05-01-2023, 06:35 AM | #33 | |
Rep 272
Valvetronic V2 Cat Back, CS Flash. -VPC Delivery Day. |
05-02-2023, 09:29 AM | #34 | |
Rep 311
I don't have them with me (I'm at the office) but let me explain with numbers (false ones) The total height of the spacer is 27mm so including the part that goes inside the wheel). And that 27mm height is the same for the 10 and 12 ones. So for the 10mm spacer, you have 17 mm of material going inside the wheel. For the 12mm spacer, you only have 15mm going inside. And here is the point : inside the OEM wheels (I have both 826 and 827m) there is not enough length to accomodate 17mm but only 16.5. So the thin aluminium edge of the spacer is bent inside the wheel ! And you only discover it when you take your wheel off ! Spacers screwed ! So you can fit 12mm spacers because only 13mm goes inside. I did two pics when I had the problem then you understand. First pic is the new spacer (12 mm). Less height. Second pic is the 10 mm spacer and you can see it is bent on the edges. It was very hard to get off the wheels !
Allerum315.50 |
05-09-2023, 03:49 PM | #35 |
You got my money?
3188
Rep 4,665
Drives: Ice Cream Truck
Updates on this OP?
06-04-2023, 10:37 AM | #36 |
Rep 6,729
I have a recent 2023 build with 1000M from factory with no rub, running Yoko’s
Not sure if BMW corrected anything with their supplier |
08-03-2023, 12:59 AM | #37 |
Rep 75
