      03-15-2023, 11:13 AM   #45
papadick
papadick's Avatar
152
Drives: M4 competition
Yes I have the sport
chujk1985542.50
      03-15-2023, 12:38 PM   #46
chujk1985
Drives: 2023 G80 M3 X Comp
Dang, I rub with 12mm spacers in front without being lowered haha
      03-15-2023, 02:12 PM   #47
ItaliaM3
Drives: 2023 G80 MT
On my 23 M3 6spd: I have 13F / 10R, front only lowered on Eibach springs with PZeros and no rubbing. I have an extra 15mm set of spacers and thinking of going 15F and 13R since the front could be pushed out a bit more.
Bstr3d183.00
      03-18-2023, 05:43 AM   #48
Ram_Rx
Legal Drug Dealer
Ram_Rx's Avatar
Drives: IG @ Ram.Rx_
Anyone running KW HAS Kit with P-Zero and 12mm Front / 15mm Rear spacers? Have any issues rubbing?
I'm installing my KW HAS Kit sometime next week and can't decide on which setup to go with lol
Options:
1. 12mm Front / 15mm Rear
2. 12mm Front / 12mm Rear
3. 13mm Front / 13mm Rear
Any input would be greatly appreciated! So many mix reviews on which size spacers to go with.
      03-18-2023, 06:35 AM   #49
Barrie@MSS
R&D/Senior engineer & test driver at MSS automotive
Barrie@MSS's Avatar
United Kingdom
15
Drives: M3 G80
Options:
It will depend on how much you’re lowering by, most go for 12mm front / 15mm rear. You might get some rubbing on the rear if you go to low. But if you do get any rubbing front or rear you can just raise the car slightly.
https://youtu.be/M9B2PZW9Q_Y
These guys normally give some good information out. Not fitting KW in this video but they fit the spacers with the MSS kit.
Ram_Rx165.50
      03-18-2023, 04:08 PM   #50
Ram_Rx
Legal Drug Dealer
Ram_Rx's Avatar
Thanks, I'll def check out the video. I've been debating between KW HAS Kit and MSS. I think MSS you drop a bit lower than HAS.
Do you have the product number for the updated MSS Kit?
      03-18-2023, 05:08 PM   #51
Barrie@MSS
Barrie@MSS's Avatar
United Kingdom
15
Drives: M3 G80
The product code is MSS.02bBMWMG28 in the US.
You’ll see mixed reviews between MSS and other brands. You’ll find in the aftermarket industry that customers are very loyal to the brand they know.
Suspension is very subjective and we all like a different set up to others, it also depends where you mainly drive. I’ve always preferred a softer setup as my local roads are very poor. But some like a stiffer setup as it adds drama and feels sportier.
Check out our instagram if you want to learn more about us, I also have an MMS account and do behind the scenes bits and bobs if you’re interested in that. barrie_mssautomotive
Good luck with your install
Ram_Rx165.50
      04-04-2023, 10:13 AM   #52
Ventura24G20
Ventura24G20's Avatar
Drives: 23 BMW G80 M3
Will I experience any rubbing running a 12mm Front and 15mm Rear on H&R Springs (Non-Super Sport) on PZeros? ... Or Should I Switch over to 10mm on the Front?
      04-04-2023, 11:45 AM   #53
chris3g
Drives: 2023 M3 xdrive
this is a complete non-issue IMO, the pirellis rub on a plastic vent fin in the wheel well, all you need to do is slightly trim or bend it and the problem is solved. You don't need to go with a smaller spacer due to this.
TypeDre111.00
      04-04-2023, 12:34 PM   #54
Anderson11
Anderson11's Avatar
458
Drives: 2023 BMW M4 Comp
Agreed. A total non issue. Installed 12.5mm spacers in the front and the left wheel was slightly rubbing the fins. My car is not lowered. Used a heat gun and a 2x4 wedge to push the fins back. Works great....
Procedure starts at 6m 50 seconds
2023 M4 Comp
Dravit Grey Metallic
      01-01-2024, 10:56 AM   #55
AiBiasEdi
Drives: BMW M3
Where did you get the springs and spacers from?
      03-10-2024, 08:09 PM   #56
FrozenBlueG82
Drives: 2024 BMW M4 Comp xdrive
15mm spacers front and rear, lowered on H&R springs and I cut all the outermost fins off. I get no rubbing.
      03-10-2024, 10:49 PM   #57
Wtfitzvi
Wtfitzvi's Avatar
Drives: ...
Originally Posted by Boostin335 View Post
12mm will rub with Pirellis?
Also, is there more likelihood of rubbing with a G80 or G82 and does xDrive add to that further? - Anyone can answer this one and chime in
Following to see the answer for these. I ended up getting 12mm all around
CURRENT: 97 E36 | 15 Huracan 610-4 | 18 F80 Competition | 22 F95 Competition | 24 G80 Competition | 23 Escalade | 24 Civic Type R
      03-11-2024, 02:39 PM   #58
Berzerker
Anything higher than 10mm on fronts will rub with the pirellis without any fender modifications.
Wtfitzvi794.50
