09-07-2022, 07:34 AM | #1 |
Rep 401
Rubbing with pirelli's and spacers
Anyone else figure out a way to get rid of the rubbing at full lock in reverse? I expected it with running 15mm front with pirelli's, so I shaved off half of the 3 fins that everyone says needs to be modified and it still rubs on both sides on full lock reverse. The fitment is exactly what I wanted, but it's annoying when reversing out of a parking spot. Pics of the car lowered on ast springs and bms 15mm spacers front, and 13mm back. Also pics of the cut fins.
09-07-2022, 08:50 AM | #2 |
Rep 190,807
i had the same issue with 13mm spacers and Michelin. I had to go back to 10mm spacers to resolve it.
09-07-2022, 08:55 AM | #3 |
Rep 18,718
Best way is to have a buddy to drive the car while you are keeping an eye to see where it still rub.
From there, shave it where it rubs.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
MIM5219.50 Limegrntaln13477.50 |
09-07-2022, 11:08 AM | #4 |
Rep 6,589
This has been documented in SEVERAL threads. P0's are fat and they rub with spacers. End of story.
Limegrntaln13477.50 hotsauce_bukkake119.50 |
09-07-2022, 07:55 PM | #5 |
Rep 1,682
I'm running 18mm with Pirellis. After cutting the fins in the pic below, noise was gone.
09-08-2022, 10:22 AM | #6 |
Rep 401
I didn't fully cut them off, so maybe I'll try that. I figured if I shaved them down half way it was better then nothing to have some protection of rocks and such coming up and hitting those coolers.
09-08-2022, 11:14 AM | #7 |
Rep 179
Have you tried heating up and pushed back this part? This could also be an area that rubs.
2023 Brooklyn Grey Metallic M3 Competition xDrive
Build Progress IG: @g80_arie |
09-08-2022, 03:32 PM | #8 |
Rep 679
I have 15mm with pzero up front with zero rubbing. It depends on how low your car is. Not everyone is at the same height. It might still be rubbing the upper one. Trim those down and go from there. Also turn your wheel full lock and see where the closest contact point is.
You also did not shave it all across, try that. |
09-08-2022, 03:58 PM | #9 |
Rep 328
Pretty interesting way to increase clearance. Starts at 6 minutes 50 seconds.
Heat first, cut/shave later?
2023 M4 Comp
Dravit Grey Metallic |
09-08-2022, 10:01 PM | #10 | |
Rep 401
09-09-2022, 03:15 PM | #11 |
Rep 543
Drives: 2022 G83 M4
Well if it matters it seems like the folks at iND are reading our minds. If you don't want to cut fins and have cash to blow.
https://ind-distribution.com/collect...nder-liner-set
09-18-2022, 10:24 PM | #12 | |
Rep 710
09-18-2022, 11:06 PM | #13 |
Rep 543
Drives: 2022 G83 M4
From the looks of the part diagram you're looking for parts 51718070503 and 51718070504 respectively. MSRP is under $100 a piece.
Item #2 in the link https://parts.bmwnorthwest.com/a/BMW...m/51_Z243.html
yousefnjr6159.00 |
09-25-2022, 01:56 PM | #14 | |
Rep 710
Limegrntaln13477.50 Poffman493.00 |
12-13-2022, 09:40 AM | #15 |
Rep 113
Drives: 2023 BMW M3 Competition
Sorry to bring this back from the dead, but installing some springs and spacers next week and wanted to see if you had found your rubbing point. Have PZeros as well.
12-13-2022, 11:10 AM | #16 | |
salty cowboys fan
6159
Rep 3,408
shes home! '22 M4 Comp xDrive
12-14-2022, 10:06 AM | #17 | |
Rep 357
Im thinking about just getting 11mm all around and going from there. |
12-14-2022, 06:42 PM | #18 |
Rep 113
I have the MSS spring kit. Took it off my 2022 so everything is settled. I had the PS4S on that car but didn't get them this time around. I had 15 and 12 mm spacers for that car and was really hoping I can use them again here. If I have to modify the fender liners so be it. Rather do that than have to buy all new spacers. Just need to know what I need modify at this point. Was going to shave down all three columns of the fins. Hoping I don't have to remove them completely but sounds like I may have to if I want to prevent rubbing. Wanted to make sure there weren't other rubbing points to consider too.
12-15-2022, 08:40 AM | #19 |
Rep 190,807
I'm getting it soon; the car will look much better with the bigger spacers in the front.
12-15-2022, 08:41 AM | #20 | |
Rep 357
01-05-2023, 04:39 PM | #22 | |
Rep 1,723
Also, is there more likelihood of rubbing with a G80 or G82 and does xDrive add to that further? - Anyone can answer this one and chime in |
