01-20-2024, 08:46 AM | #89 | |
Rep 4,931
dj_intrinsic330.00 |
01-20-2024, 02:54 PM | #90 |
Rep 234
I’m also assuming that if I decide to get an axle back down the road that most mfg would fit?
2023 G80 MT / AW / Fjord Blue/Black | KW HAS | Apex VS5RS F:20x10+8 285/30-20 R:20x11+18 305/30-20 | Maxton Street Pro Splitter | OEM M3CS Grille | SST Valve Controller | CS Style Yellow DRL | MAD Non-Res Single Midpipe
Past: 2018 X3 M40i | 2016 M-Sport X1 | 2013 MT M-Sport 328i | 2021 Audi A6 Allroad |
01-20-2024, 08:26 PM | #91 |
Rep 4,931
If you are going with our axle back 100% fitment! If choosing another brand I would always double check that it connects at the middle dimple cut points. Anyone making an exhaust for this model should be utilizing the dimple cut points.
Sonic RR118.50 |
01-20-2024, 09:44 PM | #92 |
Rep 234
Perfect, Thank you!
01-22-2024, 09:39 AM | #95 |
Rep 4,931
What are your mods? Sure it's not rubbing on the brace?
01-22-2024, 10:28 AM | #96 |
Rep 190,829
I have had/seen many drone issues with single midpipes (MAD and other brands), it's 99.99% an install issue with the brace rubbing against the midpipe.
Sonic RR118.50 |
01-23-2024, 10:02 AM | #98 |
Rep 4,931
While it does eliminate the Secondary Catalytics, making it questionable whether it can be considered fully compliant, it will pass an emissions OBD2 test. Specifically, in the USA, there are no monitoring sensors in place to check the rear O2 sensors.
01-23-2024, 10:50 AM | #99 | |
Rep 190,829
If your state does physical checks, it might not pass.
Info@mad-us.com1928.00 |
01-23-2024, 11:20 AM | #100 |
Rep 1,064
cool. Illinois is an ODB state...
01-24-2024, 11:27 AM | #101 |
Rep 190,829
01-24-2024, 01:10 PM | #102 |
Rep 590
Volume-wise, that's where it definitely wakes up for me (only mod is single resonated mid). But I wouldn't call it drone.
01-24-2024, 01:42 PM | #103 |
Rep 4,931
Yeah, Its gotta be touching somthing.
01-24-2024, 08:03 PM | #104 |
Rep 227
Drives: 2024 PB M4 Comp xDrive
01-25-2024, 01:18 AM | #105 |
Rep 590
Not calling it drone, what I meant was peak volume of the exhaust to my ears inside the car. I have no complaints or drone to be clear.
ItsConnor232.00 Info@mad-us.com1928.00 |
02-11-2024, 12:22 PM | #106 |
Rep 2,463
Did you ever get this sorted? I’m in the market for a mid pipe and want to avoid any rattling/drone (unwanted noises) with the mid pipe hitting the brace etc
02-11-2024, 03:45 PM | #107 | |
Rep 148
I have a valve controller, and with the valves forced 100% open you feel the exhaust note inside the car between 2500-4000 rpm. Nothing is touching on my car and it still does it. I just think it’s something to do with the engine harmonics at that rpm. If I put the valves back into stock control (open 70%) it does go away, so it’s something with the harmonics of the remaining 30% the valve controller opens up. |
02-11-2024, 06:32 PM | #108 | |
Rep 336
02-12-2024, 09:06 AM | #109 |
Rep 477
Are there any videos that shows the difference in Sound level during a cold start up, with the only exhaust modification being the Mad single midpipe or has anyone measured it?
Or is there anyone who can measure the current sound level who has only that Mod? I'm looking to compare start up compared to stock. |
02-12-2024, 11:55 AM | #110 | |
Rep 1,929
https://youtu.be/98STwtKipCY
Tobster3635.50 |
