      08-03-2022, 04:41 PM   #89
Steveo
Steveo's Avatar
152
Drives: M4
That’s the JB4 reading the car’s fault codes…
      08-03-2022, 04:53 PM   #90
AKSteve
Drives: G82 M4 Competition Convertible
So maybe the car is sensing that too much air is flowing through the downpipes, but the CEL isn't coming on because the air coming through is "clean." I've driven the car a bit today and haven't had a repeat of those codes.
      08-03-2022, 05:09 PM   #91
Nicklv_m3
Nicklv_m3's Avatar
196
Drives: 22' M3 Comp, 21' X3 M40i
More than likely just soft codes.
Typical Cat related codes are P0420 usually. Which throws a CEL.
So I’d say you’re good right now!
      08-03-2022, 06:20 PM   #92
RideFAST
RideFAST's Avatar
123
Drives: 22 G82 6MT
This is a question for Nicklv_m3, in regards to your valve controller, can you control the valves before startup? Say I want to start the car up in efficient with valves closed (I too plan on going full catback with apexbuilt catted DP), is that possible with your valve controller?
      08-03-2022, 06:25 PM   #93
Nicklv_m3
Nicklv_m3's Avatar
196
I have my VSC2 setup as-
Default: Auto/OEM (so I can keep valves closed on loud cold starts) and control the valves on start up myself.
ON: valves fully open.
I have the controller programmed to my home link buttons also.
So if I wanted a loud start up, I’ll use my M button setting for sport+, start the car and just immediately press my home link button to open valves fully.
IG: @nicklv_m3h
RideFAST123.00
      08-03-2022, 07:04 PM   #94
RideFAST
RideFAST's Avatar
123
Drives: 22 G82 6MT
Awesome, thanks for the quick reply and helpful insight. Your car sounds phenomenal! Well done with your setup
      08-03-2022, 07:27 PM   #95
Nicklv_m3
Nicklv_m3's Avatar
196
Thanks man! And NP
IG: @nicklv_m3h
      08-03-2022, 07:55 PM   #96
AKSteve
I guess it was only a matter of time before one thing led to another....
But I'm still just getting the same two fault codes about catted downpipes being detected. Nothing else. The car is driving great though. No weird smells and the power is amazing.
      08-03-2022, 09:39 PM   #97
Asmooth0101
Drives: Lexus rx350
Damn… that didn't take long. Keep us posted on if the light stays on permanently
      08-04-2022, 08:20 AM   #98
Allerum
Allerum's Avatar
316
Drives: 23 M3C X-Drive
You could add a spacer to the 2nd 02 and it might go away. like 30$
Valvetronic V2 Cat Back, CS Flash.
-VPC Delivery Day.
      08-04-2022, 11:49 AM   #99
Asmooth0101
Drives: Lexus rx350
Is that the same as the big daddy thing? Or something different?
Fugazii234.50
      08-04-2022, 12:38 PM   #100
Allerum
Allerum's Avatar
316
https://www.walmart.com/ip/Vibrant-P...ERTS/170667126
So its nothing special, it depends on your space available for what kind of design you can use. Amazon and other sites are getting rid of listing these though, because EPA has a hard-on for anything involving exhaust.
-VPC Delivery Day.
      08-04-2022, 08:47 PM   #101
Nicklv_m3
Nicklv_m3's Avatar
196
Get the bigdaddygarage mini cat spacers. theyre the best.
IG: @nicklv_m3h
      08-04-2022, 10:14 PM   #102
Asmooth0101
Drives: Lexus rx350
This one? http://www.bigdaddiesgarage.com/mini-cat-cel-fix.html
      08-05-2022, 01:44 AM   #103
AKSteve
Just to point out again, I haven't gotten any P0420, P0430 Error Codes or anything like that. Just these:
180101 catless downpipe detected bank2
180001 catless downpipe detected
Even when the CEL light came on, I still only had just those fault codes. I cleared the CEL and drove around all day today and it didn't come back on again. As long as no damage is being done to my car or the O2 sensors, I don't mind having to clear some fault codes once in a while.
      08-05-2022, 07:34 AM   #104
RideFAST
RideFAST's Avatar
123
Drives: 22 G82 6MT
Anyone know what cell count the stock cats are?
      08-05-2022, 07:39 AM   #105
BMWM4CX
Drives: M4C
Stock are 800cpsi
RideFAST123.00
      08-06-2022, 12:20 AM   #106
Southern
Southern's Avatar
327
Drives: G80 M3
2022 BMW M3  [0.00]
Just ordered the Apexbuilt catted downpipes. Will report back after installed. FYI you get another 10% discount if you have a Govx affiliation via law enforcement or medical.
https://www.shopapexbuilt.com/collec...-hfc-downpipes
      08-06-2022, 07:01 AM   #107
Asmooth0101
Drives: Lexus rx350
https://www.shopapexbuilt.com/collections/bmw-g8x-m3-m4-2021/products/g8x-hfc-downpipes
Did you call in to order or did it online and were able to get that discount?
      08-06-2022, 02:21 PM   #108
LifesAnesthesia
Drives: M4 G82, 911 992
If you’re going to spend that much, get the same DP’s as me. ApexBuilt 300 Cell GESI Catted Downpipes. No CEL guarantee w/ GESI cats.
Top notch quality and perfect fitment. And $2500 normal cost.
I got mine for $400 off at ECS.
No need to spend $3500-$3800 on DP’s.
with a completely stock setup, how much sound will catted downpipes add?
      08-06-2022, 03:50 PM   #109
Southern
Southern's Avatar
327
Drives: G80 M3
2022 BMW M3  [0.00]
I logged into Govx to get the discount code, then used the code when ordering online directly through Apexbuilt
      08-06-2022, 05:33 PM   #110
Nicklv_m3
Nicklv_m3's Avatar
196
Think I’m one of the first few to have these installed already. Unless someone else out there has them.
They been on my car for over a week so far now and very happy so far.
IG: @nicklv_m3h
Southern327.00
