      05-06-2024, 11:01 PM   #1
Nado
Drives: 2023 G80 M3X
Stance Wheels
Hello,
I recently ran across a wheel that struck my eye. Wheel is made by Stance Wheels. Has anyone run across this company before?
They offer a 20x9 +15 front with a 20x10.5 +21 setup for the g80 that should sit pretty flush. Front wheel weighs in at 25lbs and the rear at 26lbs. Which I believe is only around 1lb or so heavier than the stock 826 M setup.
Wanted to check here first to see if anyone has ever ran across this company?
Thanks!
      05-07-2024, 06:27 AM   #2
markoz28
Drives: BMW 2017 340i, BMW 2020 M340i,
The front wheel will be pushed in 1.3mm more.
The rear wheel will push in 1mm more.
These will not sit flush. They will look worse. Obviously looks is a matter of ones opinion but the going consensus is to move the wheel out more than OEM. The sizes you have make the wheels go in more. That and adding more weight, I see no benefit. MHO
mirob3251.00
Nado231.50
Sp2pilot171.50
      05-07-2024, 07:57 AM   #3
phillychoi
Drives: 22 G80 M3, 19 488 Pista
I had a bad experience with the Stance wheels. Wheels are very weak and easy to bend and crack. I repaired 3 times(2 bends, 1 crack) while I had them on my old Audi within less than 2 years. They are absolutely trash.
Nado231.50
      05-09-2024, 12:55 AM   #4
babino
Drives: 2021 G80 M3 Comp
I have Stance SF10 20" wheels on my 21 M3 that came with the car I bought used (also included original wheels which I use for a winter setup). They look good to me and have been fine since I’ve owned the car about 6 months now. They do worry me a bit because of limited information about them and what I’ve seen aren’t glowing reviews. I may try and sell and find something else when I buy new tires. This is all just my opinion. Ymmv.
Nado231.50
      05-09-2024, 09:20 AM   #5
Nado
Appreciate the feedback gang. They had a model that would look killer on the M3. But couldnt find much about them.
Im just trying to find some alternatives then spending 4 to 5k on wheels. I always thought that was silly for daily drivers as the wheel is going to get beat up.
The search is back on...
