05-11-2023, 10:20 PM | #46 |
Rep 724
https://g80.bimmerpost.com/forums/sh....php?t=1902502
https://g80.bimmerpost.com/forums/sh....php?t=1932771 Here are some other threads on the topic that have videos and discussion about needing to get the discs clean (including in the holes).
BMW M3 Competition xDrive, Dravit Grey over Tartufo
Aalfred2619.00 |
05-11-2023, 11:13 PM | #47 |
Rep 142
05-12-2023, 12:11 AM | #48 | |
Rep 735
05-12-2023, 11:42 AM | #49 | |
6918
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
You wouldn't have believed a fat guy in his moms basement if he just said "oh yeah its fine don't worry about that squeaking", now would you? I'm not sure why you are so angry when all I did was provide you with the most accurate, efficient (and ironically "useful") source to answer your question. Aalfred, please don't be angry with me, I love you. |
05-12-2023, 02:20 PM | #50 | |
Rep 2,021
Forzanerazzurri Stop with the fake stuff. You do this all the time in the other post too. Post some stupid snarky comments and then when called out pretend that "oh its a joke" or "I was just trying to be funny". So please stop. I would rather have taken the comment of "oh yeah its fine don't worry about that squeaking" well than yours coz all you try to do is to be a smart ass. So stop pretending and just call shit out like it is. One line zingers are for comedians and you sir are definitely not one. Good Bye !!! |
05-13-2023, 08:25 PM | #52 | |
1411
Rep 1,174
He gave the right answer. It didn’t sound rude at all. The pertinent info is in the manual. Brake squeal is normal. Incidentally, kinda find it funny that I have the CCB and they are whisper quiet. Never a squeal squealch or sound, nary a pip. I thought that was supposed to be the opposite, that the CCB’s were loud and the regular brakes were quiet? Oh well, it’s a non issue either way. Normal operation. |
Forzanerazzurri6918.00 |
05-14-2023, 09:13 AM | #53 |
Rep 265
I'm at 1000 kms and the brakes squeak under soft braking, slower city traffic or stopping for stop sign/red light. No squeak under harder braking so I guess drive in S+ mode all the time and stop hard to eliminate the squeaking
As for the poster being talked about in this thread, solution is simple, just ignore him. I've found he adds very little value.
2023 M3 Competition xDrive Edition 50 Jahre (Techno Violet Metallic) August 11, 2022 Production Date
Delivery Date - October 24, 2022 2021 M340i xDrive M Performance Edition 2017 340i xDrive |
Aalfred2619.00 |
05-25-2023, 09:23 PM | #54 |
Rep 724
Aalfred:
I gotcha. 1. Read your manual. 2. Then do this to fix the squeaky brakes (which is not in the manual). Take wheels off, spray wheel cleaner on the brake discs, and scrub discs with a nylon brush. Then -- and this is probably the most important thing -- use a pressure washer to rinse the brake discs. You have to get in between the inside and outside discs. Spray the pressure washer directly into the vanes between the disc surfaces. A lot of brake dust will be carried out of the discs (you will have to rinse your garage out after). I used an air compressor to blow the water out of the bolt holes before reinstalling the wheels. I went for a drive and ... no squeaking. It was perfectly quiet. Earlier today driving downtown I was next to a dump truck and I swear my M3 had brakes that squeaked louder than the truck! Now, silent. And I did not do any heavy driving to make it go away. It was all washing. From what others were saying about cleaning the drilled holes in the rotors, I surmise that after a while so much brake dust gets built up in the vanes in the center of the rotors the dust just constantly works its way between the pads and rotor. That contamination is likely what is causing the noise. I will give it a couple of days and report back. But our car was pretty much free of squeaks the first 7,000 miles or so. We have only been dealing with it the past 5K (and it is less apparent in the winter when it is wet or humid outside). I am hoping for the best!
Aalfred2619.00 |
05-27-2023, 03:11 PM | #55 |
Rep 200
Fwiw, all of the advice about aggressive driving, 150-30 stops, cleaning out the drilled holes in the rotors every x weeks, is total unnecessary work and frustration if you just want to drive the thing without neighborhood dogs howling at you from the high pitched squeal that will eventually, annoyingly, always come back. I have a G80 comp, with standard rotors, and 36K miles of driving since I took delivery in March of 2021. I’ve done all of the things suggested here, and the squealing always came back. 200-500 miles of bliss just to fool you into thinking you solved it, and then it’s back. Always. I’ve greased the stock pads. Nothing. Switched to the Carbotechs. Nothing, plus with those bad boys you have the joy of not stopping at all for a hot second after a rain or car wash. Unacceptable. I just want to drive and not be annoyed.
Finally, at 33,000 squeaky miles, I solved it, this time I believe for good. EBC red stuff for the rear pads, and iSweep IS2000 for the front. I would have done EBC for both, but EBC doesn’t actually make the fronts. That would be too easy, and they would probably sell a ton of them and make too much money, and then who knows what would happen? So this is it - the secret formula for a factory-like stopping experience without the factory-like crusting of brake dust every 6 or 7 miles, and the sweet, sweet bliss of SILENCE when you stop. For the rear pads, EBC Redstuff (or iSweep IS2000 if you prefer to spend a lot more money). For the front, iSweep IS2000. I’ve logged 2,000 commuting miles on this setup, with no attention paid to the wheels other than a weekly touch less car wash, and the wheels are clean, and the silence is, well, pure joy. Good luck, and Godspeed. This, my friends, is the answer. If anyone wants proof, I can send you a recording of the silence. You could also replicate it yourself. Just sit in your car and don’t move or say anything for a second. Windows down, car running, no radio. Listen to the nature, the birds, the Jimmy John’s drive thru cashier admiring your sweet ride. Do you hear it? Coming from your brakes? The silence? Enjoy it. I will too. Oh, and Aalfred, my man. Love you like a brother, but I don’t have time in my life for all of that. Also, none of of it actually works. Not for very long anyway. Change the pads. Drive the thing. Enjoy your life. You’re welcome. |
05-27-2023, 04:52 PM | #56 |
Rep 6,962
CCBs 14,541 miles, and I'm a late braker. I've heard the train sound, twice in those miles. I usually try to keep the brakes clean, but, even if I forget, the brakes are 99% silent.
YT: G Dubyou |
Aalfred2619.00 |
05-27-2023, 04:58 PM | #57 | |
Rep 2,022
05-28-2023, 12:00 AM | #58 | |
Rep 2,021
05-28-2023, 12:03 AM | #59 | |
Rep 2,021
spridge646.00 |
05-28-2023, 12:05 AM | #60 |
Rep 2,021
Dang Im jealous. I always thought CCB were for those who track or drive their cars hard but had I known they would be quiet, it would be well worth the 8K upcharge !!!
Limegrntaln13475.00 |
05-28-2023, 07:20 AM | #61 | |
Rep 724
My pressuring washing of the discs substantially reduced the squealing, but it is is still there just a bit on occasion. Still it was worth the little extra effort when detailing or changing the wheels. With the factory warranty extended to 75K miles, which covers brake pads and rotors, I am reluctant to change pads. I am less concerned with the covered pad replacement, and more about then having the dealership deny my warranty claim and having to buy the discs too when needed. Are you all just punting on the brake pad and disc warranty and accepting that you will be paying for pads and discs?
Aalfred2619.00 |
07-10-2023, 12:02 PM | #63 |
Rep 724
I have good news, and bad news.
The good news is that I have a 100% fix for squeaky brakes. The bad news is that it only lasts for several days of DD before it starts to return (albeit at a much reduced level). The fix: 25 laps of Road America. 😎
Aalfred2619.00 |
07-10-2023, 03:53 PM | #64 |
Rep 1,929
I haven't heard a peep out of my ebc reds, did maybe 500km already. There was some brake dust over that 500km but it could be that material that they put on the top of the pad, washed them the other day and will monitor the dust, today there's nothing after 30km.
Aalfred2619.00 |
07-11-2023, 12:37 PM | #65 |
Rep 584
Drives: 2023 M3 CX
I have used EBC pads on multiple cars in the past and loved them. I saw someone mentioned that EBC doesn't make the front in Red Stuff but it looks like they do now correct?
https://www.kiesmotorsports.com/prod...f05561f1&_ss=c https://www.kiesmotorsports.com/prod...f05561f1&_ss=c
2023 BG G80 ///M3 COMP XDRIVE Dinan CF Intake | Valvetronic SS Full Exhaust | AST Adjustable Springs | UNIT 17 Front Splitter | UNIT 17 Sideskirts | BC Forged HSC21 Wheels 20x10 et12 / 20x11 et12 |
Aalfred2619.00 |
07-11-2023, 02:38 PM | #66 | |
Rep 229
to///m264.00 |
