05-23-2023, 05:01 PM | #133 | |
The Ben Shapiro of this place. I never lose! LOL
2330
Rep 3,021
Drives: 12 plaids on order
For street driving, he won't tell the difference. And we'll probably see a competition with x-drive only in the next generation. Either pick your purist variant in the RWD manual. Or get the best of all worlds with the x-drive comp.
2035 on the move!!! lmaooooooooo
05-23-2023, 05:38 PM | #134 | |
Rep 14,141
Drives: G82 M4C X-Drive
reNT265.50 |
05-23-2023, 05:41 PM | #135 | |
Rep 14,141
stormlv935.00 |
05-24-2023, 10:02 AM | #136 | |
Rep 110
If you want to exploit the cars limits on the street, you need to look for a completely different type of car. Forget the new BMWs altogether. You need something like the GR86, or maybe a Cayman if you want to stick with the germans. The new lotus Emira is also a good option if you don't mind waiting twenty years for the brits to build you one. The G80 either in the RWD or the AWD trim has very high limits on a dry surface. If you want a squarely car, get the F80 then. That car is notorious for being a loose cannon. The moral of the story is, there is no new BMW that feels engaging to drive like the old cars did. Maybe the M4 CSL comes close, that's about it. Doesn't matter if it's RWD or AWD, both cars have the same level of isolation. |
05-24-2023, 10:13 AM | #137 | |
Rep 8,652
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
05-24-2023, 01:07 PM | #138 | |
2330
Rep 3,021
He wants an out of control rwd car then there you go. Xdrive m cars are meant to be planted and taken off like a missile.
05-24-2023, 03:53 PM | #139 |
Rep 1,943
I vote for a mustang, that gets out of control very quickly
05-24-2023, 06:21 PM | #140 |
Rep 340
Interesting thread!
I just got in line for an allocation for an M3 Competition RWD to replace my M2 Competition. I read every article I could find on the G80, and the following Motor Trend article and quote was one of the best I found. The quote relates well to both the AWD and RWD M3C, I thought, considering this thread. Article… https://www.motortrend.com/news/2022...-pvoty-review/ Quote… As features editor Christian Seabaugh summed things up, "It's just hilariously unhinged." There exists a drive mode where power is only sent to the rear axle, with predictable results. But you needn't activate the RWD setting for lurid oversteer. Forget chucking the M3 into a corner; you can just as easily induce drifts by pressing harder on the gas with the steering wheel turned. BMW's xDrive seamlessly sends so much engine torque to the rear wheels that you'd swear the car is rear drive. Speaking of, compared to the rear-drive M3 Comp he'd driven previously, senior features editor Jonny Lieberman bemoaned the heft, which he swore he could feel the M3's AWD gear added to the front axle. Indeed, some judges found it was often necessary to briefly lift off the gas or dab the brakes to get the M3's mass to transfer to the front for optimal turn-in, especially on the Streets of Willow Springs—a behavior Lieberman insisted was the result of the hundred or so extra pounds the AWD M3 Competition carries up front. But without a rear-drive M3 Comp on hand for comparison, most didn't find it disqualifying. Seems you can have some RWD fun in both versions! |
kgelfen3602271.00 |
05-24-2023, 06:25 PM | #141 |
Rep 2,071
This thread continues to be just reminiscing about the past. How great things used to be….
Whatever… we just keep driving xdrive happily. |
05-25-2023, 07:52 AM | #142 | |
Rep 8,652
05-25-2023, 08:38 AM | #143 |
2330
Rep 3,021
Lmao he wouldn’t be able to handle it.
Not many can. I have a c7z. It’s a monster. He’s better off with the x drive.
05-25-2023, 09:02 AM | #144 | |
Rep 8,652
The C6 Z06 is on the other hand a different monster... i presume most Xdrive folks here would be looking for a new car within a week after this one was in a ditch,
KevinGS3375.50 |
05-25-2023, 10:07 AM | #145 | |
2330
Rep 3,021
It’s a bigger monster than the c6z just for the mere fact of how torque is delivered. The ls7 torque figures don’t come close to the LT4. It makes like 425ft lbs of torque at idle. Auto c7z is far easier to drive than a manual c7z. That’s why more people build the autos over the manual. Easier to control when you approach 1000hp.
05-25-2023, 11:34 AM | #146 | |
Rep 340
I am sure this car is going to be very satisfying for me. I have thoroughly enjoyed driving the M2C spiritedly, and at the same time I have really missed my last high performance car, a Chevy SS! If the M2 Competition and the Chevy SS had a baby…! |
05-26-2023, 04:37 AM | #147 |
Rep 375
Drives: 2022 M4 Convertible
I have little experience driving the rear-wheel drive, but it was at the Spartanburg Performance Center. I own a G83, the heaviest of the bunch, and have 15000 miles on it. I think my observations are already mentioned in one of the 146 posts.
Can you feel the weight difference? Yes, but again with the convertible, you would expect that. Plus, with convertibles, you get more body roll and sometimes shimmy. So my observation is the weight difference is low between the G82 and G83, and I have yet to experience any shimmy effects. My point is the convertible is remarkable in how little of a compromise between the convertible and lighter variants are. I have to surmise then the differences between the RWD and X-Drive will be even less from a purist standpoint. Is the RWD car wilder, twitchier, and feels more alive? As many have stated, by putting the car in RWD-only mode (mandatory DSC off in X-Drive), the car easily be thrown around. It's as easy as turning the wheel and surging the throttle. Personally, when I want to get a little squirrely, I will put the car in MDM mode instead of DSC off. It is just a personal thing, as DSC off and 4WD Sport, can still spin out on you. The car has be in a compromised position before hand, e.g., carrying too much speed into the corner when flooring it, so it is not as snappy as the F87, which seemed to want to get tail happy at any opportunity. Are there any traction issues from a launch with the RWD model on warm days and good pavement? Can't really answer this question. I have used LC half a dozen times in the convertible. I have not read any forum posts about the manual not launching well. However, if you want the best launch and quarter-mile times, the X-Drive has been proven to be the quickest. Your observations the X-Drive seems "safer". I would agree with that observation. In MDM mode, I feel very comfortable engaging in wheel spin and not do not fear losing control. For street driving, I love this! If I tracked the car, then I might have a different opinion on it, but I could also switch to DSC off / 4WD Sport for the extra speed coming out of a corner. I will say that during the time I spent at Spartanburg with the RWD variant and at my limits, I never felt like I was going to lose the backend, and the stability of the car was night and day compared to the previous generation M2. |
