11-22-2023, 03:26 AM | #1 |
Rep 278
Rear Axle Differential Lock Limited
A few hours ago I got in my 2022 M3CX (with 8500 miles) to drive home and as soon as I turned the car on, I got a bunch of back to back errors and warnings. All the errors were gone once I shut off the car and then turned it back on.
The BMW app currently says:
I've seen posts from others who have had similar errors, but I am not sure if anyone knows what exactly the issue is. Is this a case of bad sensor data, software glitch, etc or is this a more serious issue that the dealer needs to deal with it? With the Thanksgiving holiday upon us, I have quite a bit of driving to do and not sure if I can get any of the local dealers to take the car in on short notice. I've had a few issues with the car that may or may not be related:
Any ideas?
2022 M3 Competition xDrive
2022 M340i 2018 M3 Competition 2015 335i |
11-28-2023, 11:56 PM | #2 | |
2022 M4 Comp Xdrive
1021
Rep 1,538
Not sure but one of your symptoms "At low speeds when I turn the wheel all the way to the left or right I feel\hear something engaging or disengaging from the wheels or the 4x4 system. It's tough to explain." That sounds like something with the transfer case. Does the car jerk when doing this? |
11-29-2023, 01:22 AM | #3 | |
Rep 278
11-29-2023, 12:37 PM | #4 |
Rep 627
Some of that is normal, particularly when turning tightly at low speeds. It's called the Ackermann effect and it's common on many AWD systems, like BMW and Audi.
PVC162.00 |
11-30-2023, 12:46 PM | #5 |
2022 M4 Comp Xdrive
1021
Rep 1,538
12-01-2023, 11:10 PM | #6 |
Rep 65
Drives: BMW M4 Competition
Strange but I get similar feeling in rwd car, in low speed, let’s say pulling out of parking spot, before wheel turns further to max angle, there is faint feel that something engages. Since it’s my first m car I was thinking that it’s just what it does. Would be great if some one could shed more light on what is going on mechanically. Btw got it new, currently 1.5 k miles, I noticed this behavior from brand new.
12-13-2023, 02:38 PM | #7 | |
Rep 269
12-22-2023, 11:59 AM | #8 |
2022 M4 Comp Xdrive
1021
Rep 1,538
So SA got me an update.
1) the CF5573 code/fault is for communication. They are updating the software for it which should resolve it. 2) the binding effect, the SA said that X5 and some other models have a service bulletin that requests to use a different type of Tcase fluid. Although that SB doesnt call out the M3 or M4..... they have done this fix on other M3/M4 and it has fixed the issue. SA told me to drive it for 300 miles or so, if it still happens then they will contact BMW NA to look at it further. He said several cars have come in for this and they have only had to replace ONE Tcase; Others have had resolution with the SB fix. SIB 20 02 20 Calls out several cars, including the M5 which uses the same Tcase so makes sense. https://static.nhtsa.gov/odi/tsbs/20...76367-9999.pdf SITUATION There is a jerking or shuddering during either or both of the following: Cornering or accelerating from low speeds Driving with low to medium loads There are no warning lights or Check Control messages. CAUSE Unevenly worn or incorrect fitment tires are installed on the vehicle, or the factory-filled transfer case oil does not meet BMW specifications. Last edited by Dawgz; 12-22-2023 at 06:28 PM.. |
PVC162.00 |
12-23-2023, 08:05 PM | #9 |
2022 M4 Comp Xdrive
1021
Rep 1,538
Picked up the car from the dealership yesterday, drove it for 150 miles so far and have had tried to replicate the issue again and I cannot. Even on when the car is cold.
Hopefully this is also the fix for everyone else! |
TorontoRedCoastie116.00 docjavier1111.00 |
03-06-2024, 04:24 PM | #10 | |
Rep 269
Tags |
4x4, driving dynamics, rear differential lock |
