02-09-2024, 01:49 PM | #23 | |
Rep 1,913
Drives: Here and There
02-09-2024, 02:14 PM | #24 |
Long Time Admirer, First Time Owner
18055
Rep 9,378
Your driller will also test the water once they hit it? I think I would want that done before they installed the pipe and well head. Certainly don't need to pump non-potable water out of the ground.
I have romped on her and I giggled like a drunk infant the entire time. - Sedan_Clan
Llarry16105.00 |
02-09-2024, 03:40 PM | #25 |
sportscars only
3259
Rep 3,199
Oh, it doesn't bode well for noobs like me when you have an expert at home and she's had enough of trying to purify the well.
02-09-2024, 06:35 PM | #27 |
Recovering Perfectionist
15367
Rep 942
Drives: 2015 BMW i3 BEV
Garage List 2014 Mighty Freight ... [0.00]
2015 BMW i3 BEV [0.00] 2000 Audi TT Quattro [0.00] 1967 Formula Vee [0.00] |
Key word is RETIREMENT house, and I don't blame her for not wanting to do one of her many former careers.....
2015 BMW i3 BEV, Giga World (Lodge interior), Tech/Driving Assist Packages, 30K miles
tranquility3259.00 |
02-16-2024, 05:08 PM | #29 |
15367
Rep 942
Out of curiosity, what was the total cost?????
02-16-2024, 05:20 PM | #30 |
Rep 396
160 feet down for my well, going on 23 years. Replaced pump once. Make sure you get a big enough pump to support lawn irrigation. I have a big yard with 22 zones and have run a 1 HP pump since the get go. My water is iron free, but I do have manganese that has to be run through a softener designed for it. I also use a regular salt-based softener. If the well hits water shallow that has bad iron, they can keep drilling and often find better water deeper. Make sure you use a good-sized pressure tank, it helps with the softening. Good luck!
02-16-2024, 05:53 PM | #31 |
Rep 1,913
vreihen1615366.50 tranquility3259.00 |
02-20-2024, 11:26 AM | #32 |
18055
Rep 9,378
Cost me ~$60 to re-cover the abandoned well at my dad's cabin this past weekend. 1/2 sheet of plywood, some deck screws, and a pint of mis-mixed leftover paint at the hardware store. I DID have to shovel a metric-fak-tonne of roof slide snow that fell on the old cover and broke it. I've seen wood that came off a 17th century galleon that was in better shape than that previous cover.
Our shared home well is at ~45 feet right now, with all the rain SoCal has been getting. Pressure tanks need care, painting/inspection about every 5 years.
vreihen1615366.50 |
04-12-2024, 06:19 PM | #33 |
Rep 1,913
Curious on best approach here. New well has been doing great. Sediment filter has been getting worked out with my third one about to go in. Cool water seems to be where we need it. Hot water is still coming in brown, telling me we’ve got it in the two hot water tanks.
Is there a best practice to flush? Just keep running water? We’re a couple weeks being into the new house. |
04-12-2024, 07:15 PM | #34 |
15367
Rep 942
Is your sediment filter in front of the hot water heater(s)? If so, the hot water should be as clear as the cold water.....
spazzyfry1234361.00 |
04-12-2024, 07:48 PM | #35 | |
Rep 1,913
My assumption is that the hot tanks are holding sediment that made it past the filter whereas just constant use flushed anything out of the cold lines. We've got two 50gal tanks. We've certainly ran enough to get it out, so something is just "stuck" in there. Wondering if there's a flush option. Brand new everything. |
04-12-2024, 07:59 PM | #36 |
15367
Rep 942
I would stop after the quick flush if both tanks are new and the water runs clean out of the drain hose:
https://www.thespruce.com/how-to-dra...heater-2719055
04-14-2024, 02:29 PM | #37 | |
Rep 1,913
Drained the second, drained the first. Filled them both back up. Drained the second and flushed the second. Drained the first and flushed the first. Both showed clear water. Filled back up and turned the heaters back on. Back to brown hot water again. Cold is still clear. I’m lost. Calling well dudes tomorrow. |
vreihen1615366.50 |
