10-02-2021, 03:35 PM | #89 |
Rep 15,858
Reference Honda... we had the Rover '400' versions of the Honda Concerto built in the UK. Both Rover/Honda RHD models had the indicator on the L/H side. I see even LHD models of the Concerto (circa 1990, as our Rover cars) also had the indicator on the L/H side of the wheel.
10-02-2021, 04:11 PM | #90 | |
Rep 1,343
You are sitting in an uncomfortable position (don't squeeze your rick ), your left foot tends to slide off the pedal (you are violating the design - being too smart isn't too smart, after all ) and why does your floor mat not fit properly? You are lucky your gas pedal is floor mounted, it could get stuck behind otherwise. To make a better driver you should make wise decisions about pedal priority: it's not about speed, it's about situation analysis. I mind most drivers behind don't match my M-Sport brakes and when a dog rushed under my car out of darkness/nowhere on a crosswalk it wasn't because I was going fast or had my foot on the gas (or didn't look: of course I did, just couldn't/failed to see it in time) that I hit it, it was just too close. The conclusion I made was being even more careful as a two legged dog/bitch would cause trouble , not reconsider my driving technique. Last edited by No one; 10-02-2021 at 04:36 PM.. |
10-02-2021, 05:08 PM | #91 | |
General
60083
Rep 19,556
10-02-2021, 05:39 PM | #92 |
Rep 1,343
That's the best you can do.
It doesn't look "elongated" enough (though the foot is "off" the stem, that doesn't look "convincing" anyway). It may. I did brake. It's just there are "laws of physics" mentioned in the manual : your advice can't beat them. This would lead to brakes overheating and subsequently failing: this is why engine braking is especially important when driving in mountains - to release the brakes' heat burden. Last edited by No one; 10-02-2021 at 05:59 PM.. Reason: Added another comment. |
10-02-2021, 06:07 PM | #93 | |
3216
Rep 2,385
In a LHD, when you tense up and yank at the gear lever for the fastest shift from 3 to 4, it's possible to go from 3-2 as you tense your shoulder and pull the gear lever towards yourself. Engine blows up. Money shift. In a RHD, if you tense up and yank the gear lever towards yourself, you're going to pull it from 3-6, which will not blow up the engine. Not a Money Shift. Make sense? |
10-02-2021, 06:44 PM | #94 | |
General
60083
Rep 19,556
10-02-2021, 08:21 PM | #96 | |
Rep 1,343
And no, it won't blow the engine once you've just misshifted: you need to engage the clutch for that to happen and here's the point when you can stop and recover if you are conscious of what you are doing (the revs go blasting up). I never drop the clutch and it saved me from a money shift. There was another dog who chose wisely and didn't try to be fast, it rather proved to be sensible. Living is something you might want to deserve. Pressing the pedal away from the stem is not particularly effective to move it forward, but yes, you are right: I am wrong mentioning that for you. |
10-02-2021, 08:29 PM | #97 | |
3216
Rep 2,385
10-02-2021, 09:32 PM | #98 | ||
Rep 1,343
This means you can accidentally choose the 3rd gear when trying to choose the 5th: . My understanding of What's a money shift?. In particular, I get "down-shift" as going from a higher (number ) gear to a lower while you start to seem meaning "pulling the gear lever backward (towards the rear end of the car)" which isn't exactly necessary to downshift in my understanding. |
10-03-2021, 12:29 AM | #99 | |
3216
Rep 2,385
Picture this scenario - you're in a race. First is already selected. You hit redline, and slam it into second. Redline and push it into third. Redline again, and as you yank it into forth, you tense up, pull towards you and end up yanking it into second by mistake. And in the heat of the moment, you release the clutch, the engine revs to about 50% over redline, breaks a lot of internals, and costs you a lot of money. That's a money shift. But that was described from a LHD perspective - "Redline again, and as you yank it into forth, you tense up, pull towards you and end up yanking it into second by mistake." meaning your right hand has instead of moving the gear lever straight towards the back of the car, it's pulled it also towards your body, hence selecting second. Now, imagine the same scenario in a RHD car - "Redline again, and as you yank it into forth, you tense up, pull towards you and end up yanking it into sixth by mistake.". In the heat of the moment, you release the clutch, engine revs drop, engine might bog down, you lose the race. But no money shift. That's the type of money shift I was meaning where LHD vs RHD make a difference - make sense? |
10-03-2021, 02:21 AM | #100 | |
General
60083
Rep 19,556
10-03-2021, 03:40 AM | #101 |
Rep 208
10-03-2021, 10:22 AM | #102 | ||
Rep 1,343
Your struggling to tear off the gear shift lever reminds me of a funny version of a (non-English) song: "I'll come back home and crush the door with my dick. I'll fuck the horse and then the wife.". Quote:
And for those who might still wonder, RHD comes from the convenience of having your "better" fist ready for the oncoming: https://www.worldstandards.eu/cars/driving-on-the-left/. |
10-09-2021, 06:05 AM | #103 | |
General
60083
Rep 19,556
10-09-2021, 10:22 AM | #104 | |
Rep 1,343
Yes, I was surprised to see both pedals in a two-pedal vehicle were for just one foot usage. But I think the designers gave that solution a proper consideration, like how much you are aware of which foot you are using ("in an emergency", in particular)... Regarding moving the foot, it's only the gas pedal your foot is supposed to rest on by design, unless you know better. I don't think I am "obviously" the smartest and everyone else is really as dumb as they seem. "Faster! Fast was his mistake.": . |
10-09-2021, 10:54 AM | #105 | |
General
60083
Rep 19,556
*Good film by the way. |
10-23-2021, 08:37 PM | #108 |
386
Rep 59
Drives: 2011 BWM E92 LCI+23 other cars
I’m most cases, there is no such thing as best or better. Everything is a compromise. What might be best or better to someone may not be best or better for someone else.
10-24-2021, 04:12 PM | #109 |
Rep 6
Probably(as specially EU brands) UX design studies done by car producers base on LHD due to higher ratio. There might be some differences due to cost challenges for LHD variants
10-25-2021, 02:58 AM | #110 |
Rep 16
After reading all this I realise I must have been a pretty shitty driver for money shifting my RHD Evo from 5th to 2nd. And boy did the money shift with the blown turbo and head gasket.
I don’t think there’s much pros and cons to either side of the road/dashboard. We all adapt pretty well. Having said that, some mods i.e. choices of turbo upgrades, shifter kits, ultimate clutch pedal, seem to be more available for LHD. Some manufacturers such as Skoda leave behind LHD elements in their RHD models such as keeping the Octavia III’s handbrake on the left of the center tunnel which made it awkward to pull. |
