      02-13-2024, 02:35 PM   #1
jetblackcoupe
jetblackcoupe's Avatar
153
Drives: 2008 e92 335i 6MT
Single midpipe questions
No car yet but planning ahead. I’m coming from a catless n54 which is now way too loud. I hate drone and rasp. 2 questions:
1) when compared to stock, how much louder (percent wise) would a resonated single midpipe be (with a valve controller)? Leaving everything else stock.
2) if leaving remainder stock, is there a significant difference in volume/rasp between a resonated and non-resonated single midpipe? For those who have heard/had both.
Thanks.
      02-13-2024, 03:44 PM   #2
Info@mad-us.com
Info@mad-us.com's Avatar
1924
Drives: bmw
I'd say its around 40-50% louder to my ears with a midpipe and valve controller set at 100%.
With a midpipe as your only mod rasp won't be much of an issue with either the resonated or non resonated.
- Click Here
Performance Parts For Your Bmw At Crazy Low Prices!
Email: info@mad-us.com
      02-13-2024, 04:03 PM   #3
Info@mad-us.com
1924
Drives: bmw
End of this video has some before and after without a valve controller.
Another showing stock vs midpipe vs midpipe and valve controller.
- Click Here
      02-14-2024, 11:12 AM   #4
mike@x-ph.com
mike@x-ph.com's Avatar
giving a number on how loud it is is inaccurate because the sound characteristics change, not just the volume.
The single midpipe will change how the car sounds in all RPM ranges for the better. It's got a deeper mid-range tone, with a clean rasp-free high RPM. It's noticeably louder than stock and sounds so much better.
I agree with MAD that adding the controller to the midpipe is the way to go.
https://x-ph.com/sale/
Phone number 702-494-9435
      02-14-2024, 05:48 PM   #5
jetblackcoupe
153
thanks guys.
i am curious if there is any difference whatsoever between resonated and non-resonated if all else stock. there are some videos on youtube of non res with stock otherwise and occasionally sounds raspy, but could be the sound quality of the video.
      02-14-2024, 05:53 PM   #6
Berzerker
Originally Posted by jetblackcoupe View Post
thanks guys.
I have a non-res AA single with stock downpipes and muffler and it's only every so slightly raspy if you're revving it at stock and only at super high RPMs. Other RPMs and if you're actually ripping it, it's not raspy at all.
      02-14-2024, 07:41 PM   #7
Skyscraper
Skyscraper's Avatar
2202
thanks guys.
I called AA direct and talked to them.
The guy I spoke with recommended the resonated single mid for me. I don’t want any rasp or droning. Just a little more volume.
      02-15-2024, 09:37 AM   #8
Info@mad-us.com
1924
Drives: bmw
You can go with a resonated it will smooth out the tone slightly and wont change the volume much.
Keep in mind cars revving will have a slightly different sound than a car under actual load and boost. So unless you want a certain tone revving I would base it off a driving video.
- Click Here
      02-15-2024, 11:50 AM   #9
mike@x-ph.com
The resonated single midpipe offers the cleanest setup. i think that's what you should get
Tobster3635.50
      02-15-2024, 03:51 PM   #10
Skyscraper
Skyscraper's Avatar
2202
If you're talking to me; I did. It showed up yesterday.
This weekends project.
      02-15-2024, 04:25 PM   #11
mike@x-ph.com
      02-16-2024, 05:29 AM   #12
GT_Juls
GT_Juls's Avatar
Drives: G82 M4
Resonated midpipe and rest stock will be perfect for you with zero drone.
A lot of people get the rear section but that oem muffler is basically a straight pipe sound when opened fully with a valve controller.
Ive had numerous setups and was amazed how much open sound the oem muffler allows.
//M is awesome
      02-16-2024, 10:54 AM   #13
mike@x-ph.com
Resonated midpipe with everything else stock will sound like the car was supposed to come from the factory. It's got a nice sound without being too aggressive.
It's too quiet for my taste, I prefer the resonated midpipe with an axle back or high-flow catted downpipes.
      02-16-2024, 11:47 AM   #14
dtronics
dtronics's Avatar
412
Drives: G80 /// M50i /// 964 C2
Any comments on how much louder the non-res AA midpipe is compared to the resonated version with everything else stock? I'm debating options between the single versions and EL.
      02-16-2024, 02:45 PM   #15
Info@mad-us.com
1924
Drives: bmw
It would be very similar to ours and the answer is not that much. You would probably need a decibel meter to see the difference.
It will be a slightly smoother and refined tone though.
- Click Here
dtronics412.00
      02-16-2024, 03:43 PM   #16
mike@x-ph.com
Tough to say without measurements but its cleaner and noticeably quieter with the resonated version but i would not consider it a huge difference
dtronics412.00
      02-16-2024, 05:22 PM   #17
Berzerker
I will say, as an owner of a non-resonated AA single...even if it's louder when wide open, with the valves closed and in comfort it's still equally as silent as stock. If you're afraid it'll be too loud when you *don't* want it to be, don't be worried. I can go from 100% comfort silent to decently loud (sport+ with valves OEM) to 100% full volume (sport+ and valves fully open all the time) with the help of the SST valve controller.
I think the perfect setup for those who want a really nice middle-ground is a non-resonated single midpipe with stock downpipes and the stock axleback. You have the comfort of keeping stock downpipes to not affect warranty, not deal with any CELs, and no smell, and the stock axleback (muffler) is really good at removing drone and rasp. I do get a *bit* of drone at 1700-2000RPM but *only* if I have the valves fully open. If I want the drone to go away, valves back to OEM control and it's nice and compliant. Zero drone after that.
I'm happier than I even expected to be with this setup. I feel the resonated version without any other modifications would be too quiet to be worth the price for the pipe.
dtronics412.00
forcefed2567.00
HDEddie1121.00
      02-16-2024, 05:55 PM   #18
dtronics
dtronics's Avatar
412
Thanks for the well thought out response, it's greatly appreciated. I'm going to switch up my order based on your feedback. Thanks man!
mike@x-ph.com I DM'd you my order number. Can you switch mine from resonated to non-res? It's probably the only order you had today going to Rhode Island... haha.
Berzerker2889.50
      02-16-2024, 09:19 PM   #19
Berzerker
Make sure to add that SST valve controller if you don't have it on there already!
dtronics412.00
      02-16-2024, 10:01 PM   #20
dtronics
dtronics's Avatar
412
I want to but i'm waiting. I had the OBDII CAN Module on my F82 and I loved being able to control the valves from the stalk on the wheel. It plugged right into the OBD port and it was tucked away.
I need to have two dedicated HomeLink buttons for two houses and I hate having the garage remotes in my car. I'm waiting for the plug and play AWRON option so I can use the existing M1 M2 buttons. I saw this option that another member mentioned:
https://modeautoconcepts.com/en-us/p...g83-inc-xdrive
I reached out to them but they gave me no information in their reply. I'm in a holding pattern until EAS provides a plug and play option for the AWRON unit.
Thanks again for your feedback on the midpipe. I spent literally hours researching and you gave me the exact feedback I needed on the "res vs non-res" question. Much appreciated.
      02-17-2024, 12:21 AM   #21
Berzerker
I mounted my remote to the under the middle tray so I don't even use any of the homelink buttons. It's out of the way and easy to hit, so idk I don't think it's an issue tbh.
      02-17-2024, 12:44 AM   #22
dtronics
dtronics's Avatar
412
I'm just so used to having the buttons close or on the wheel. I can't go back. The only way I can compare it is moving from a Mac to a PC.
Thank you for all you do for the community. After a couple years removed from a M car, I love that the enthusiasts are still here.
P.S. It's your fault if I don't like my midpipe.
Berzerker2889.50
