BMW 3-Series (E90 E92) Forum
Follow Up for Alarm Coding
01-15-2012, 07:48 PM | #46 |
Rep 9
How do you enable the chirp on lock/unlock setting in the bc? I have tried to code the blank MAN in KOMBI as well as the check then uncheck through BC stalk method.
Also, my chirp is soft and after coding, the values keep going back to default values as in the OP... Anybody know what I'm doing wrong? Edit: figured it out Last edited by e90jd; 01-20-2012 at 01:47 AM.. |
01-24-2012, 05:50 PM | #47 | |
Rep 56
03-20-2012, 10:08 PM | #48 |
66
Rep 850
Mine was really soft to and everytime i tried to change it, it ended up going back to default sound. So i coded with a blank .man file in the DWAS and its nice and loud now. I tried after that to turn it up to wert_08 and it went back to being quiet. The blank .man file worked like a charm to make it loud again
04-30-2012, 07:59 PM | #49 | |
Legendary
14
Rep 227
'07 335i E90 Titanium Silver |
04-30-2012, 10:04 PM | #50 | |
Rep 629
Cheers,
2009 335i E93 /// BSM /// Sport /// Premium /// /// 19" M pack 225 wheels /// M6 wheels winter set /// 35% Tint /// Gloss Black Grills /// PE Exhaust /// Lux H8 V3 /// Interior LEDs /// JB4-DCI /// Combox & CIC Retrofit /// M3 side skirts /// M3 front bumper ///
05-02-2012, 12:48 AM | #51 |
Legendary
14
Rep 227
I just placed the order to get the correct cable sent to me so it looks like I'm delayed 2 weeks. I will definitely hit you up Moreno1 for some advice.
07-15-2012, 12:23 PM | #52 | |||
0000000
12
Rep 144
This thread was infinitely useful when coding my alarm yesterday. I have the motion sensor working, unlock/lock chirp, have the relevant menu items in IDrive, and double-locks came along for the ride. Thank you to everyone who contributed!
For completeness, I did the following. Quote:
At this point, I still had the clown nose blinking, but no PANIC button, and no menu items in IDrive. No chirps either. Curiously, holding the trunk unlock button on the fob didn't work as it used to. Instead I had to depress it once and the trunk would unlock. Holding the button did nothing. So I did the following Quote:
After this, everything seemed to work. I don't know how to test the tilt sensor (or if I even have one) or the hood latch yet, but will follow up when I do. Just for ha-has, I disabled the legal disclamer in Idrive while I was there. Also, I made the windows go up from the fob. This spreadsheet has lots of goodies. Thanks again to all who contributed. You saved me a few hundred bucks I can now put to good use (e.g. helping finance my LSD install!! Next week can't come soon enough!). |
07-19-2012, 03:55 AM | #53 | |
Rep 393
So to get your siren louder you have only wert-01 under buzzer high and buzzer low correct?
08-09-2012, 03:07 PM | #54 |
Rep 405
I've changed all the values but dont see any change in the car at all..
I've updated to the new V46.1 daten files so I can access CIC (Since CAPPL is for CCC/Older models), and none of those values are there But my clown nose stopped blinking I believe.. thats it! No chirp or anything.. I changed it all by accessing through CAS, or do I have to do it from NFRM? edit: So I posted this from when in my car.. I got out and it fkn chirps now lol.. and clown nose blinks. But still dont see the options in CIC, any idea there? And left windows down and motion doesnt seem to work.. Spent 3 hours in FL sun in that car so I'll try again tmrw/this weekend.. lol Thanks in advance! |
08-09-2012, 10:38 PM | #55 |
Rep 4,444
^You did it wrong because you are trying to do it line by line.
Add to VO in expert mode, write VO to CAS and NFRM Recode modules in expert mode. Prosper |
08-26-2012, 01:48 PM | #56 |
0000000
12
Rep 144
After coding, when the alarm is tripped via any of the sensors or the Panic button, are the headlights suppose to flash? I noticed mine don't. The siren goes nuts, but no headlight activity. Thanks in advance!
09-02-2012, 01:47 AM | #57 |
Rep 427
2006 330XI BSM, Terra Cotta Leather Interior, ZSP, ZPP, ZWP, ZCV, Comfort Access, Adaptive Xenon, Steptronic, Logic 7, Nav w/ IDrive
09-03-2012, 12:19 AM | #58 | |
Rep 427
I have three questions; 1. Can i use the NCS_Changing_the_Vehicle_Order_CAS.pdf for my E90 06 330XI? 2. Do i have to use my personal FSW PSW MAN profile instead of expertmode? 3. I read elsewhere, in addition to performing the FA change i will need to recode the car using a blank Man file. However this will erase all the other coding i have performed previously. Is this correct? Thanks in advance
09-07-2012, 10:55 PM | #59 |
Rep 427
Whats Up Guys,
First of all thank you for all your help. I attempted to the instructions listed in the "Using NCS to Change VO (external link) USING NCS TO CHANGE VO.pdf" found in the wiki section of *********. Once the job was execute i noticed none of my old codes were erased (as i was informed they would) and the lights on the dashboard did not flash like normally when a job is executed, although i did not receive any errors. Since the job was execute without any errors, i proceeded to install all the modules listed below; -DWAI: LAUTSTAERKE nicht_aktiv > aktiv ALARM_OPT_FERNLICHT nicht_aktiv > aktiv QUIT_AKUST_SCHAERF_KLAPPE nicht_aktiv > aktiv PANIK_ALARM nicht_aktiv > aktiv QUIT_AKUST_ENTSCH nicht_aktiv > aktiv DEF_QUIT_AKUST_ENTSCH nicht_aktiv > aktiv DEF_QUIT_OPT_ENTSCH nicht_aktiv > aktiv DEF_QUIT_AKUST_SCHAERF_KL nicht_aktiv > aktiv ANFRAGE_FENSTERPOSITIONEN nicht_aktiv > aktiv PIAU_AKUST_ENTSCH nicht_aktiv > aktiv PIAU_AKUST_SCHAERF_KLAPPE nicht_aktiv > aktiv SIGNAL_HK nicht_aktiv > aktiv CAS: SONDERTASTE_PANIKALARM nicht_aktiv > panikalarm MOTORHAUBENKONTAKT nicht_aktiv > aktiv CAPPL: QUITT_AKUST_SCHAERF fkt_gesperrt > fkt_frei Currently my Car chirps and the signal lights flash when the alarm is activated/disactivated and the motion sensor works. However, the panik alarm and hood switch do not work. In addition, I noticed my alarm sensor light still flashes a total of 21 times quickly before it begins flashing normally which i believe is a signal that the alarm is not programmed correctly. Does anyone have any idea why im having this issue?
09-08-2012, 05:07 AM | #61 |
Rep 427
Because, I'm a beginner and didn't know I could do it otherwise.
09-09-2012, 09:45 PM | #62 | |
Rep 427
Are all these codes compatible with an 06 E90?
06-15-2013, 08:35 AM | #63 |
I'd hit it
1066
Rep 1,107
The coding was way easier than I thought it would be... I was actually surprised everything worked. The one thing I don't see is the options in my iDrive or stalk... That would just be a nice to have.
Edit: I coded CAPPL but 'ACOUSTIC' just said nicht_aktiv as opposed to fkt_gesperrt... Wasn't sure if I should change that to aktiv or fkt_frei. I tried fkt_frei since that's what the post says but I got an error when it was coding. I just left it and shut down since it was late. Last edited by 2Times; 06-15-2013 at 08:40 AM.. |
06-20-2013, 01:07 AM | #64 |
Rep 198
Just did this on my E92.
A few issues - after the blanket coding: LAUTSTAERKE is defaulted as nicht_aktiv - any confirmation on what this code specifically does? 2Times - I checked my files and ACOUSTIC is set as aktiv - I'm guessing this might have been a typo in the original how-to as I got an error trying to code it as fkt_frei as well. I also had to re-enable the motion sensor, for some reason. At any rate, can anyone elaborate on how many blinks the clown nose should have when the alarm is functioning properly? I think I've finally got it, save for LAUTSTAERKE if I need to change that.... Props to everyone for all the research, it made the process not too bad once I got the whole coding thing figured out! |
06-20-2013, 08:36 AM | #65 | |
I'd hit it
1066
Rep 1,107
I was testing the flashes and I learned that you can't fool the alarm. I armed it while sitting still inside, it wasn't flashing and when I moved, I was a little bummed the motion sensor didn't activate it. I got out, tried again with the windows down and when I activated the alarm, the clown nose flashed either 5 or 10 times I believe then went to single flashes every ~20 seconds. I gave it a min then stuck my arm in and waved around. Worked, alarm went off. I disarmed it and when I went to get back in, I noticed the clown nose was flashing quickly until I armed/disarmed it again. That's how my flashes work |
06-20-2013, 04:11 PM | #66 | |
Rep 198
Interestingly enough, I no longer get the long sequence of flashes when arming the alarm. It goes right into blinking without the fast blink. I've also coded to enable the key fob to close the windows and moonroof - score! |
