09-04-2023, 06:05 PM | #1 |
Rep 77
Drives: Subaru WRX, BMW M4 Comp xdrive
Steering wheel vibration mystery
I had new PS4S's installed at the dealer. Got the car home and had been driving it to notice a minor vibration in the steering wheel and the floor. Noticed the front drivers side tire was running about 5-10 degrees F hotter than the rest of the tires. I was suspicious of a stuck brake caliber so I took it into the dealer. They ended up replacing one of the front tires under warranty, claiming it could not be balanced. After they replaced the tire they called back and said that it fixed most of the problem but there is still a minor vibration. They said they would need to keep the car to diagnose further.
I took the car back home for the weekend and can concur that the car still vibrates, however very mild. While I had it home I ran my own tests. First I swapped the front and rear wheels. When the rears were up front I did not experience any vibing. I swapped wheels back to original orientation and sure enough had the minor vibes again. With the wheels in the original orientation I also tested for vibrations in RWD mode vs 4WD, still getting the same thing but hopefully that rules out and drivetrain issue. I didn't have this problem for the first 8000miles with the pirellis. I only got the PS4S's because I had a flat in one of the Pirelli's and decided to replace all 4 since my rears were down the 3/32. This vibing only began after they put new tires on. Anyone else have a similar issue? |
09-05-2023, 02:52 AM | #2 |
Rep 321
If the tyres are not rotationally sensitive you could swap left right to see if it changes. Are your tyres also heating up differentially? Might tell you if toe/tracking is out?
Have you tried road force balancing in the fronts. I’ve found many tyre places inc BMW stick far too many weights on. … and they can come off. |
herbnlegend50.00 |
09-05-2023, 04:07 AM | #3 | |
Rep 13,008
09-05-2023, 06:12 AM | #4 | |
Rep 77
09-13-2023, 02:06 PM | #5 | |
Rep 104
I have a similar issue. I had a bad rear tire which was replaced (PS4) but still experience a high frequency vibe. It doesn't feel like an unbalanced tire. It feels like I'm holding a power sander albeit not as extreme. Very interestingly it will go away if I unlatch the steering wheel... My dealer opened a case and I havnt heard back from them yet.. my car has less than 2500 miles on it. Try unlatching (safely of course) on the highway and see if that helps? |
09-16-2023, 12:05 AM | #6 |
6920
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
Typical Michelins
09-16-2023, 08:54 AM | #7 |
Learning to drive again
720
Rep 324
Drives: M3CS
My car is 2 weeks old, has 400 miles now, and has PS4S. Since the first day, there was a very subtle vibration with the steering wheel. First, the tire pressures were too high, reduced them to recommended levels. This helped, but the vibration was still there. The car being new, I am not yet able to recognize if something is 'normal' or should be looked into. The vibration was not bothersome, it was very subtle at higher speeds.
Yesterday, I took the wheels off to check them out, and I found the wheel weights on one of the front ones were pretty messed up. Got it balanced, and now there are no vibrations.
Cheers,
BoB |
mathys202.50 |
01-07-2024, 02:48 AM | #8 | |
Rep 3
02-01-2024, 09:45 AM | #9 |
Rep 104
No unfortunately, It seems like it may be a characteristic of the PS4's or "feedback". I will probably try the all seasons ones when im due for tires.
02-01-2024, 09:55 AM | #10 |
Rep 372
I had PS4S on my last Mustang and currently have them on my GTi, no vibrations from either.
2015 VW GTI (446whp/414wtq)
2024 M3 Comp xDrive |
02-01-2024, 04:41 PM | #11 |
Rep 3,996
These cars are generally very sensitive to the front tires being out of balance. I have experienced this on my E90, F80, and G82.
If you have a discount tire nearby take it there. They have the highest end Hunter road force machines you can buy. Most dealers do not have the top tier model. I would also mention to them you are having issues with vibration and this usually ensures that one of the better techs handles it.
02-02-2024, 12:38 AM | #12 |
Rep 1
Had the same vibration issue on the PS4S on my GTR. Two tires were bad, had it replaced but still had minor issues afterwards. But not enough for me to go out of my way to replace them again. 90% sure it’s the tires.
03-11-2024, 07:52 PM | #13 |
Rep 346
03-12-2024, 11:20 AM | #14 |
Rep 104
Tags |
brake caliper, tire balance, vibration, wheel |
