02-02-2024, 08:53 PM | #1 |
Rep 5
Gear assist - lift throttle on upshift like normal?
M3 manual question: With the gear assistance (rev matching), on upshift do you lift throttle like you normally would or does it matter?
Cheers! |
02-02-2024, 09:21 PM | #2 |
Rep 264
The Rev matching function is only for downshift. For upshift is normal.
2019 X3
2011 135i Alpine White DCT N55 All Stock Built on 10/10 Proud owner since 12/12. |
02-02-2024, 09:36 PM | #3 |
Rep 5
02-02-2024, 10:02 PM | #4 | |
Rep 146
This is incorrect, the rev matching function is also for upshifting. What it does is when you shift into a higher gear with the clutch pushed in, the RPMs will drop until they are matched for that gear and the car will hold it at that RPM for like two seconds while you let the clutch out. I think what OP is asking about is”No Lift shift” which this car does not have. |
02-03-2024, 07:38 AM | #5 |
Rep 1,661
I haven’t tried it yet, but you should be able to speed shift - keep your foot on the throttle and shift. Not best for clutch longevity but it can make you grin when done right.
18' F80 6MT, 991.1s cab PDK, F83 6mt, 996 C4S cab 6mt, F30 328iM 6mt
E60 M5 SMG, E39 M5, E46 M3 cab 6mt, E36 M3 5mt |
02-03-2024, 07:59 AM | #6 | |
Rep 273
02-03-2024, 09:48 AM | #7 |
Rep 851
Just turn that junk off and learn to drive a manual normally. Lol
02-03-2024, 10:26 AM | #8 |
Rep 5,153
You must lift off the throttle during shifts.
02-03-2024, 12:36 PM | #10 | |
Rep 146
I'd always understood the rev-matching (gearshift assistant) only to apply in downshifting scenarios, so you can cheat on needing to do any heel-toeing. I had played with it a little out of curiosity, and it certainly didn't appear that there was any different or atypical behavior when depressing the clutch for an upshift and staying [partially] on throttle. Instead, the revs stayed exactly where they were (based on how much throttle I was giving it while in 'neutral'), and when the next highest gear was engaged, the revs simply settled in as you'd expect, without the car affecting throttle/RPM in any appreciable way. But we definitely don't have anything like true no-lift shift on these. (You can do as Adcampo suggested, which essentially is what I was playing around with when testing things out ... but you're definitely risking a shorter clutch life.) So now I'm really curious if I've just never noticed this upshift 'intervention' of the gearshift assist, but it actually exists? Could've sworn the Gearshift Assistant only functions in downshift situations.... |
02-03-2024, 12:57 PM | #11 | |
Rep 146
bimmerCHAOS172.50 SunKing101207.50 |
02-03-2024, 01:05 PM | #12 | |
Rep 146
Another excuse to get in the car today. |
02-03-2024, 03:07 PM | #13 | |
Rep 146
Guess I need to shut that off next time he's practicing, so he can learn to drive it the right way!! Thanks again for the info/insight. |
02-06-2024, 12:12 AM | #14 | |
Rep 146
02-19-2024, 09:55 PM | #15 | |
Rep 264
2019 X3
