03-27-2021, 11:47 PM | #1 |
Rep 35
Strange front end vibration/resonance
My G80 M3 has a strange vibration that happens sometimes at low speeds, low RPMs (usually happens in between 1200-2200 RPMs), and specifically when the car is warming up. Anyone else experiencing a similar issue?
06-20-2022, 03:50 AM | #2 |
Rep 77
I have the same issue. Did you already find a solution. It sound like humming and is very sporadically.
06-20-2022, 10:44 AM | #3 |
Rep 14,115
Drives: G82 M4C X-Drive
Without more details this sounds normal. Your engine is working up to operating temps.
09-02-2022, 08:44 PM | #4 | |
Rep 11
Bmw431188.00 |
10-10-2022, 11:37 PM | #5 |
Rep 124
subbing. i have the same under light acceleration at about 1800 rpm. do you guys have any mods?
i have bms intake, ast lowering springs and as single mid pipe. |
10-11-2022, 09:01 AM | #7 |
Rep 364
Drives: 2022 M4 Convertible
Happens to me also, I always thought it was exhaust drone associated with a cold start while applying a slight engine load.
11-17-2022, 08:29 PM | #8 |
Rep 301
I'm having the same issue I noticed today 11/17/2022 in Neutral when I hold the idle at 1,800 RPM or gently rev the motor up below 3,000 RPM I can feel the vibration from the motor. It's an obvious vibration just like a phone vibrating
11-24-2022, 12:58 AM | #11 |
6918
Rep 3,277
Drives: E46 M3 Coupe/G80 M3CX
Yep I made a thread about this too
11-24-2022, 11:48 AM | #12 |
BMW forever!
1389
Rep 2,418
I've noticed this even in my X5. I think it's a normal artifact of G series cars. But I don't have in my M2C.
2020 BMW X5
2019 BMW M2C 2014 BMW 335i 2009 BMW 328i |
11-24-2022, 10:56 PM | #13 |
Rep 301
As long as it is not harmonic vibration through the crank, flywheel or anything internal from the motor. That can easily damage bearings and cause wear. When you gently rev the motor at low RPM or hold the throttle between 1,700 RPM up to 2,800 you can obviously notice it.
Any type of vibration is definitely not a normal thing unless BMW give us a Legitimate explanation Hopping it's something normal specially on cold starts. |
11-25-2022, 12:07 AM | #14 | |
6918
Rep 3,277
bwoodahl235.00 |
11-25-2022, 02:02 AM | #15 | ||
Rep 301
It has to do something with the motor. I've been building cars for a very long time and understand the technical aspects of it. I just wonder what would cause the vibration at any RPM range. |
11-25-2022, 12:00 PM | #16 |
Rep 3,403
I had a bad front end vibration when coming to a stop, only in sport brake and my sport plus engine and chassis settings, but it disappeared after 3k miles. No explanation from my service visit other than "might be the brakes." A few times the brakes did make a sound like a bicycle with rim brakes pushed hard or wet disc brakes. But that's gone, too. So it's a mystery, but if it was the brakes it makes sense that once broken in the sound disappears.
11-25-2022, 02:38 PM | #17 | |
Rep 301
11-25-2022, 05:04 PM | #18 |
Rep 3,403
Ah, so for me it was less than 5 mph, almost like the transmission was hesitating. I was worried it was the AWD system. Should have read the issue more carefully, but in case anyone has THIS issue of vibration...
11-25-2022, 06:57 PM | #19 | |
Rep 301
12-12-2022, 10:59 AM | #20 |
Rep 30
Is there any solution here?
I have had my M3 for a few days and am also affected by it. I also feel these vibrations in the range of about 1800 rpm. |
