04-27-2024, 05:20 PM | #1 |
Rep 55
Drives: BMW G80 M3 RWD
Setup Recommendations for KW V4 for 2022 xDrive G82 M4
Recently got KW V4 for my 2022 G82 V4, and has accompanied wheels with 19 inch 9.5J ET-5 in the front, 20 inch 10.5J ET7 in the rear. My friend who also owns a G82 M4 says that there’s a height difference of 15mm between the front and the rear at stock.
Does anyone have any recommendations on how to set up their KW V4s? |
04-28-2024, 01:55 AM | #2 |
Rep 17,397
the difference is between the front and rear fender. The front fender is higher so if you drop the car evenly f/r, the front will have more fender gap. If you want a visually even height, then you'd want 1/4 - 1/5 inch lower in the front than the rear.
04-29-2024, 04:59 PM | #3 |
Rep 55
Thank you so much for the clarification! Now everything makes sense.
