03-24-2024, 10:52 AM | #1 |
Rep 857
Firestone Firehawk Indy500 vs Michelin and Pirelli OEs.
I’m sure some of you have seen me mention these tires in some posts, but if you haven’t, I decided to go ahead and post a quick TireRack comparison for you. The comparison is against the stock OE tires that BMW will usually stick on these cars. In terms of why I think the Firestones are a great tire in comparison and you guys should try them at least once, especially if you’re xdrive, is because I have run probably at least 5 sets of these in the past, including on my S4 and I know others who have moved to them from Michelins and love them. For the price vs performance, you can’t beat them. Also, for some of you older guys/gals that might think Firestone is shit because of past issues long ago, that’s all gone now. In actuality, these specific tires are only branded as Firestones in the US, everywhere else (eg Japan) they’re Bridgestone.
Anyway, take a look at the PDF and then do your own research, but these tires are really good! The sidewall is much better than the Michelins and there’s none of the bs chunking or bad wear the Michelins have. The treadware is also better than both the Michelins and Pirellis and you’ll get a bit more miles out of them, depending on how you drive. They’re also nice and quiet, all the way down even past the wear indicators. Very neutral control and limits and they don’t scream like crazy beyond the limit either, so if you wanna get a little squirrely, you won’t be calling out too much attention to yourself. About the only negative I’ve found for the sizes on this platform is that they’re a little bit heavier than the other two choices… and you will only have a W rating instead of Y, but most of you are limited to within the max speed of that spec anyway, so it won’t matter. For those of you who have run them on your past cars or new Ms, please share your thoughts on them so others have more than one person to believe. Lol |
03-24-2024, 04:27 PM | #3 |
Rep 3,963
Lol based on what? They absolutely are in the same class and many people swear by them. The ONLY downside to them is the weight. Please elaborate on why you think they're not in the same league? Just because of a name?
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5 |
03-24-2024, 04:49 PM | #4 |
Rep 616
This subject is almost like oil, red heads vs brunettes, etc.
There has been a lot made of the star spec tires being developed with BMW to exploit the maximum potential of the car. Like most things, the manufacturer is playing a balancing act of performance/comfort/longevity, etc. I think for specific use cases, there can be better tires than the OEM star spec. I think the majority of us fall outside those use cases but once you’ve gone through your original set, there’s no reason to exclude other options. Take how you drive your car, what’s important to you from a tire and go for it. |
BRJ1243336.50 Limegrntaln13475.00 |
03-24-2024, 05:21 PM | #5 |
Rep 857
Lol. They are actually better than the Pirellis and only marginally less and I mean by a little bit in terms of traction vs the Michelins. In all actuality, the soft ass sidewalls of the Michelins counter the traction limitations against the Indy500s. If you haven’t used them, you’re not speaking from experience. I’ve had Michelin PSS tires on my S4 and would NEVER run them again vs the Indy500. Considering these are made in the sizes for the M4, it was a no brainder. Will definitely be running these.
03-24-2024, 06:22 PM | #7 |
Rep 1,929
Had these on my previous car, will definitely be running them again. You also get more tread with these, 10/32nd compared to 8/32nd with oem pzeros.
03-24-2024, 06:29 PM | #9 |
Rep 3,963
Yes.
03-24-2024, 09:16 PM | #11 |
Rep 338
Drives: 2023 BMW M3 Competition xDrive
I had these on my RS after replacing the PSS with them. I noticed no difference in rain or dry in daily driving and spirited mountain drives. I’d definitely consider them again once it’s time for tires on the M3.
03-25-2024, 01:12 AM | #12 | |
Rep 590
03-25-2024, 03:16 AM | #14 | |
Rep 6,962
The Star PS4s is a Hybrid PS4s and Sport Cup 2, in the same tire. The PS4S star is tuned specifically for the G8X. The Firehawk is made for however many hundreds of models they can fit the tire on. The Star, is only made for one purpose, and thats specifically for the G8X.
YT: G Dubyou |
natmad667.00 |
03-25-2024, 06:55 AM | #15 | |
Rep 3,963
03-25-2024, 07:43 AM | #16 | |
Rep 6,962
The PS4S Star is 1/2 Cup 2 and half PS4s. Find an off the shelf tire that combines the best of both of those tires into one compound? I have the Yokohama V107 Star on my 1000M wheel set, and I think thats a better, newer design than the PS4S, but, its still a star, and BMW took the time to test compounds to come up with the tire that worked best with their wheel set. Porsche, Mercedes, Tesla, Audi, and others, have their own specific tires made for their cars. Do you think a standard off the shelf tire is going to perform the same on a 911, when the rear tires on the 911 are designed to spec to be able to perform with the weight of the engine on the rear axle? Do you mean to tell me that there should be no difference between a tire that goes on the rear axle of a 911 or one that goes on the front steering axle? That'll work for a Honda Civic, or a Toyota Tundra, but its not going to work for a 911, or an M3. The 275/35/19 star is designed for the G8X, where, in that specific size, it has a different outer tread wear compound, than the 285/30/20. The rear tires don't need a more wear resistant compound on the outer edge of the tire, because, its not getting plowed into a hard corner. The cup 2 rubber is on the outside edge of the front tire, for the weight of the car. To help stabilize the car in high speed corners. Both the front and rear star tires, the tire carcass and plies are laid in a different pattern, and laid tighter for quicker steering, alleviating the porposing affect, when you jerk the wheel back and forth, in a straight line. The front and rear tires feel connected, and you don't get the feeling where the rear tires are reacting slower, alleviating the feeling of body roll, or the rear fish tailing. Go with the off the shelf tires, all you want. Just know the tire is the same for a VW Golf as it is for a Corvette C8, as it is for a Honda Civic. All the while BMW spent millions of dollars over 2 and a half years, to develop a tire thats made for the weight, speed, and performance of the G80.
YT: G Dubyou |
03-25-2024, 08:00 AM | #17 |
Rep 238
The Michelin and Pirelli are max performance and the firestone's are ultra high performance. Again, they are probably not a bad tire, but not in the same category so you can't really compare. Also, you are looking at user reviews for tires in the same class from tire rack and not a comparison test as they won't typically compare tires in different classes.
03-25-2024, 08:07 AM | #18 | |
Rep 3,963
03-25-2024, 08:15 AM | #19 | |
Rep 3,963
03-25-2024, 08:56 AM | #20 |
Rep 308
Drives: ‘23 M3 Comp xDrive
I have no advice to add to the discussion that has risen from this post, but I just wanted to chime in and say thank you for posting your personal experience with this tire.
03-25-2024, 09:16 AM | #21 | |
Rep 6,701
BMW optimized the star spec tires for what THEY want to see out of a tire. Does that mean it's the best at anything? No. Does that mean it's the best for what I want to use it for? No. I appreciate the star spec tires are a better match for BMW's original set of parameters that they set the car up with. Also, here is TR's test for the Firehawk Indy. I'm not super impressed with what I see: https://www.tirerack.com/tires/tests...y.jsp?ttid=235 I'm more likely to go with the Conti's over the Michelin when I ditch the Pirelli. I may stick with the gold standard Michelins, but only if I went star spec as the generic version gets beat by the Contis here. Plus I have an exceptional history with Contis on other cars. https://www.tirerack.com/tires/tests...y.jsp?ttid=317 Last edited by Needsdecaf; 03-25-2024 at 09:22 AM.. |
03-25-2024, 09:24 AM | #22 | |
Rep 3,963
