      03-18-2024, 05:25 PM   #1
jeegunkim
jeegunkim's Avatar
328
Drives: 2020 330i xDrive, 2023 M3CX
xDrive & Tire Size
I know there are threads on this but there seems to be a debate about what is proper tire size. I'm about to order a set of tires for my new wheels and am wondering what all you xDrive G8X's are running, I've ready some are 285/30 and 295/30 but it breaks the 1% threshold by 0.1%, there are others saying it should be 275/30 and 285/30 as it would be below the 1% threshold. I'm hoping the 285/295 setup will be fine to run. Any thoughts?
2020 MG 330i xDrive M Sport
2023 AR M3 Competition M xDrive
      03-18-2024, 06:50 PM   #2
JY01
JY01
JY01's Avatar
Drives: 2023 BMW M4 Competition xDrive
Running 285/30/20F 295/30/20R PS4S on my xDrive and it’s fine. The diameter only differs by 0.88% according to willtheyfit.com
      03-19-2024, 09:00 AM   #3
davidmct-M3
Drives: BMW 440i with MPSSK
Is it circumference or diameter that needs to be within 1%? I would have thought circumference as this causes the rotational distance difference though they are related of course. And is % calculated from smaller as increase?
      03-19-2024, 09:02 AM   #4
forcefed
forcefed's Avatar
Drives: .
Height.
      03-19-2024, 11:42 AM   #5
jeegunkim
jeegunkim's Avatar
328
Thanks for the input, man. Funny enough, I'm installing the same wheels, ha! How long have you been running this tire setup?
      03-19-2024, 12:25 PM   #6
JY01
JY01
JY01's Avatar
Only about a week. I do rub on the front fender liner fins, but plan on trimming those once I lower the car.
      03-19-2024, 01:05 PM   #7
jeegunkim
jeegunkim's Avatar
328
Gotcha, I'm already lowered and liners are trimmed so I should be good to go. Hopefully some other folks whos on xDrive with the same times can also chime in just to make sure. Last thing I want is transfer case issues because of the wrong tire sizes.
      03-19-2024, 01:22 PM   #8
JY01
JY01
JY01's Avatar
I put over 100 miles on my new setup and it’s been fine, no drivability issues or codes. To be specific here’s the tires I’m running:
F: Michelin PS4S Star BMW 285/30/20
R: Michelin PS4S N0 Porsche 295/30/20
I got this info from the TE37 thread, I think I saw a couple other xDrive owners on there running the same setup. Additionally, you can reference Apex fitment guides, they’ll tell you which setups are xDrive compatible: https://apexwheels.com/fitment-guide...-fitment-guide
Sp2pilot168.50
      03-20-2024, 11:15 AM   #9
jeegunkim
jeegunkim's Avatar
328
Thanks, appreciate it!
      03-20-2024, 12:48 PM   #10
to///m
to///m's Avatar
264
Drives: 2023 M3 CX
2023 BMW M3 CX  [9.50]
2018 BMW X5  [0.00]
2018 Ford Raptor  [0.00]
Have thousands of miles on my xdrive G80 with 285/30/20 front and 295/30/20 rear and 100% fine, you will be good
2023 BG G80 ///M3 COMP XDRIVE
Dinan CF Intake | Valvetronic SS Full Exhaust | AST Adjustable Springs | UNIT 17 Front Splitter | UNIT 17 Sideskirts | BC Forged HSC21 Wheels 20x10 et12 / 20x11 et12
      03-20-2024, 01:57 PM   #11
rak299
Drives: 2021 M3 6MT
Circumference is pi times diameter. If one is within 1%, so is the other one
      03-20-2024, 03:47 PM   #12
M3SQRD
M3SQRD's Avatar
2164
Drives: E92 M3,G20 330ix,F22 240iX,F82
Really?!?! How did you remember such a complex equation?
I ran into this problem on our g20 x-drive when buying winter tires. In my case, it was the front tire that was larger in diameter (front +0.8% wrt rear dia). Switched to a setup with the rear tire having a larger diameter (front -0.8% wrt rear dia) and it’s worked perfectly for the past 4 years.
I tried a few additional tire diameters and found for the g20 330ix with THP that front tires with diameters +0.5% to -1.00% wrt the rear diameter works perfectly. For some reason, the g20 330ix is slightly biased more towards a front tire that is smaller in diameter than the rear tire. I initially thought it was going to be +1.0% to -1.0% wrt rear tire. What is it for the g8x x-drive?
      03-20-2024, 07:25 PM   #13
fl1by
Drives: G80, Raptor, STI and C8
I'll have 285/35/19 295/30/20 Supercar3 on at the end of the month. I'll update when I get them mounted on Apex wheels. already cleaned up the fins in the front fender liner. G80 xDrive
DocMus0.00
jeegunkim327.50
      03-22-2024, 01:25 AM   #14
MartinS
MartinS's Avatar
Drives: G82 M4 x-drive
Car comes 0,4% off from factory. So I think you’re good if you are +/- 1% from the 0,4%.
http://www.niiice.dk/signatur_2010.jpg
435d xDrive & M5 F90 Frozen dark silver metallic
      03-27-2024, 10:13 PM   #15
G82 Jesse
G82 Jesse's Avatar
67
Drives: 2024 G82 M4 xDrive
https://tiresize.com/calculator/
Thought I'd share the link to this calculator on this thread. You can enter the specs for your front and rear setup. IIRC, official xDrive recommendations are 1.1% or less variance between the front and rear.
As tires are circles, your diameter and circumference will be the same ratio when comparing front to rears. I've got 275/30/20 in the front and 285/30/20 in the rear, at a 0.8% rotational difference, which appears to be just fine; for example.
      03-28-2024, 02:13 PM   #16
mjponti
Drives: 2019 McLaren 720S, 2021 X4MC
Looks great, are you also running spacers?
      03-28-2024, 07:09 PM   #17
to///m
to///m's Avatar
264
Drives: 2023 M3 CX
2018 BMW X5  [0.00]
Thanks man! Just 5mm up front, didn't need to, just wanted the front to be a little more aggressive
mjponti19.00
      03-29-2024, 05:20 AM   #18
phillychoi
Drives: 22 G80 M3, 19 488 Pista
Perfect stance! Great job.
to///m264.00
