03-15-2024, 10:14 AM | #1 |
Rep 250
Custom Wheel Specs for G80 X-Drive (HELP!)
Hey everyone.
I'm having a set custom forged wheels made and I'm just trying to confirm specs before i pull the trigger. Front - 20x9.5 et 7mm Rear - 20x10.5 et 10mm and for tires planning on running (Keep in mind car is X-drive) Front: 285/30/20 Rear: 295/30/20 inputs & recommendations would be appreciated ! i am also running KW HAS. thank you in advance! Last edited by TselaG80; 03-15-2024 at 01:06 PM.. |
03-15-2024, 11:55 AM | #2 |
Rep 1,929
You need to keep the height of the tires identical, less than 1% or so for xdrive. You're at 2% now front to back.
03-15-2024, 12:41 PM | #3 |
Rep 37
The wheel spec can get you close to a flush fitment. The tire spec however would not work if you have a X Drive car. With those tire specs, you have a 1.1% difference in the circumference front and rear and it will cause issues with your X Drive as the tolerance is 1% meaning your traction control is going to think the car is consistently losing traction and potentially damage the drivetrain. We'd recommend 275/30/20 front and 285/30/20 rear to keep the difference under 1%.
03-15-2024, 01:05 PM | #5 |
Rep 2,319
03-15-2024, 01:10 PM | #7 |
Rep 1,929
Oops for some reason I was seeing 1.9%.
03-15-2024, 01:10 PM | #8 |
Rep 250
03-15-2024, 01:13 PM | #9 |
Rep 2,319
Yes. The tire size dictates what will work with X drive and not the wheel size. For example you can have a 15 inch wheel and still match the size of a 20 inch wheel by putting a fat tire with a huge sidewall on it lol.
03-15-2024, 02:10 PM | #12 |
Rep 250
03-17-2024, 09:48 PM | #13 |
Rep 342
285/30/20
295/30/20 Seems to be commonly run on Xdrive - but there are always comments that pop up suggesting it’s out of spec (1.1% vs 1). Have not seen or heard of anyone actually reporting a problem tho or any increased traction control lights coming on etc. |
03-18-2024, 02:40 AM | #14 |
Rep 6,962
You're only looking at going 10mm wider. You're almost wasting your time, going to a non BMW Star tire, because you're losing the performance associated with the stock BMW tires. The BMW tires, are not off the shelf PS4S, its actually a 1/2 PS4S and half Sport Cup 2.
Its worth watching this video.
YT: G Dubyou |
03-18-2024, 06:38 AM | #15 | |
Rep 342
Limegrntaln13473.50 |
03-18-2024, 11:55 AM | #16 |
Rep 6,962
BMW makes a winter set for the G8X but it’s not really worth it, because it comes as a wheel and tire assembly.
YT: G Dubyou |
03-22-2024, 01:24 AM | #18 |
Rep 587
X-drive comes with 0,4% difference from factory. So that probably calculated into the speed the wheels are running. So that the 0,4% is actually 0%. If you know what I mean.
435d xDrive & M5 F90 Frozen dark silver metallic |
03-22-2024, 09:24 AM | #19 |
Rep 13,780
After having done a few sets for Xdrive cars... You can go an inch wider front and rear and adjust the offsets a little for much better fitment w/ those tire sizes. If you want the tires to look a bit beefy then you can stick with your current widths. No issues with those tire sizes & rolling rate.
03-22-2024, 05:16 PM | #20 |
Rep 191
I run a -1.9% difference on my x-drive when it has the rear bead locks on. 285/35/19 up front and a 305/35/18 rear.
The real threshold is actually around the 3% mark. It's mainly how far do you want to take it to find out haha. |
03-23-2024, 11:45 AM | #21 | |
Rep 250
03-25-2024, 03:17 PM | #22 |
Rep 13,780
