02-01-2024, 08:01 AM | #1 |
Rep 241
19" square setup
I'm kicking around going with 19x10.5 square lightweight mono-block setup with 285/35 or 285/30. I've only seen one or two setups on here. Currently on 20x10 & 11 3-piece Forgelines with KW V3's, Millway monoballs, and SPL tie rods. Anyone have any feedback for proper 19" setup and pics? Thanks
02-01-2024, 08:50 AM | #2 |
///M driver
16032
Rep 499
Drives: 2022 M3 6-speed
I'm running a 19-inch "almost square" setup on an unmodified suspension:
Front 19 x 9.5 ET22 with 275/35R-19 (779 revs per mile) Rear 19 x 11 ET25 with 285/35R-19 (774 revs per miles) Not really what you're after, but a data point.
Schulminator476.00 |
02-02-2024, 12:32 PM | #3 |
Rep 56
Drives: BMW G82 M4
For 10.5J at front with KW v3 , you might need a pair of spacers to have enough clearance. I am thinking about this setup as well, please update if you got them installed
02-02-2024, 12:35 PM | #4 |
Rep 168
Drives: G80 M3 GTP 6MT
19x10.5 GS1R with 285/35/19 RE71RS square offset setup!
02-02-2024, 02:55 PM | #5 |
Rep 241
Awesome, those look like a great track setup. Thank you for sharing. What offsets and suspension setup are you running? I would maybe go a little bit more aggressive on the offsets, as mine will be a weekend street and some roll races.
02-02-2024, 03:00 PM | #6 |
Rep 168
The offset on my current set of forgelines are quite conservative, not sure about the exact offset since my shop spec it for me (Racewerkz here in LA) but it’s more or less in the +10 range. I also have a 5mm spacer up front. Around -3.5+ front camber and -3+ rear camber. I think I might pull the trigger on a set of 19x11 +9 titan7 by Jackie Ding. It all depends on how much camber you have! Jackie said his wheels should fit no problem with front camber plate and -3+ camber, not sure if it’ll clear the strut though. At +9 it seems like no problem. I also have the full SPL catalog, running Vorshlag camber plates and MCS 2W remotes with shorter springs for max clearance haha
02-02-2024, 03:13 PM | #7 | |
Rep 241
02-05-2024, 06:07 AM | #8 |
Rep 6
BrendanZ0402 thanks for sharing your square setup.
Couple of questions. Is there any sort of ribbing at the front using 285? Secondly, I am not sure if yours is x-drive, if it is, how is x-drive handling a square setup instead of staggered? Thanks |
02-05-2024, 02:57 PM | #9 | |
Rep 168
I know a guy that’s running a square setup on his xdrive and have no problems. He told me xdrive even prefer a square setup. 285/35/19 RE71RS as well. Note that xdrive have a bit less clearance up front than the rwd models though so you might need to tweak the offset a little bit |
apz0.00 |
02-05-2024, 04:16 PM | #10 |
Rep 706
I am waiting on my wheels to come back from getting ceramic coat.
I will be running 19x10.5 et 14 19x11 et 22 295-30-19 Conti extreme contact sport 7 (Europe). Square. I hope I will be ok with this set up on an Xdrive. Lowered on MP HAS.
03-14-2024, 01:34 PM | #11 |
Rep 168
03-14-2024, 07:29 PM | #12 |
Rep 424
I ordered the 19x11 Square set up from PHD Racing and ordered 305/30/19 SC3R. I have the full SPL package, ohlins, chamber plates and fender liner mod. I hope i can get it to fit
Currently:
2022 M4 Comp xDrive 2022 M5 Comp Past: 2019 M5 Comp 2015 M4 |
04-04-2024, 03:40 AM | #13 |
Rep 706
19x10.5 19x11 Continental sc7 295-30-19. You can run the front without spacers, but I used a 3mm for piece of mind. I am on MP HAS.
