12-23-2021, 09:12 AM | #244 | |
Rep 190,807
As long as you are using the correct octane, you can run any map as a daily driver. Just don't use a map higher than what's recommended for the octan you are using. There is a reason why BMS does not recommend map 3 for 91 octane for example
12-23-2021, 11:14 AM | #245 | ||
Rep 401
12-23-2021, 06:51 PM | #247 |
Rep 190,807
12-24-2021, 09:25 AM | #248 |
Rep 401
12-24-2021, 09:29 AM | #249 |
Rep 190,807
map 5 on a fully stock car made 609 whp, map 3 is 2 PSI less so somewhere in the high 500s.
note the BMS intake added 15whp on its own, consider getting it to get your car at 600 whp with map 3
12-24-2021, 10:08 AM | #250 | ||
Rep 541
Instagram - _MOWE_
12-24-2021, 11:11 AM | #251 | |
Rep 401
12-24-2021, 11:32 AM | #252 | ||
Rep 1,257
12-24-2021, 11:45 AM | #253 | |||
Rep 401
12-25-2021, 06:10 AM | #254 | |||
Rep 264
12-28-2021, 08:15 AM | #255 |
Rep 39
What Ethanol blends are you guys using with jb4? Currently mods are downpipes, valvetronic midpipe, bmc drop ins and flex fuel kit. I used E30 with VP but heard some people are using E35 -E40. Plannin on going to the dyno next week with a Ignite Red can.
12-29-2021, 09:34 AM | #256 |
Rep 51
Is there a way to open or close the valves in efficient mode? If so how?
I heard running the JB4 in efficient mode has been the best for maps but I want the valves open.
-2013 135IS-
JB4, 40% Ethanol, Cobb Charge Pipe, 4' Catless downpipe, Injen intake |
12-30-2021, 08:43 AM | #257 | |
Rep 190,807
Exhaust Valve Mode: '*************************************** Toggle between flap open, flap closed, and OEM operation, by pressing the button for 2 seconds and letting go. The left blinker will flash for valve open, right blinker for valve closed, and both blinkers for OEM operation. The valve setting is persistent and will remain in effect until you change it. If you hold the button too long you'll jump in to the in dash menu system below
12-30-2021, 08:46 AM | #258 |
Rep 1,257
ive never been able to get the valve control to work, it flashes the blinkers but doesn't actually seem to change the valve position.
01-05-2022, 01:19 PM | #260 |
Rep 638
this is my first time really looking into a jb4, i got a m3 comp on the boat right now, it will be my daily driver. question i have is how safe is the jb4. i understand tuning is always playing with fire but i would only want enough power to break 10s in the quarter mile while keeping the engine safe. can someone shine a little light.
01-05-2022, 06:02 PM | #262 |
Rep 14
01-05-2022, 08:39 PM | #264 |
Rep 17,386
Question to those who run jb4.
When service comes, are you or planning to remove it or eff it and leave it in. With some of the rumors saying BMW knows you had a piggyback even if it was removed, what are your thoughts? |
