07-31-2023, 07:57 AM | #1 |
Rep 6,749
Drive Recorder - How is it?
I searched and didn't really find many threads on the built-in drive recorder. Trying to see how it is? I opted for it just because it was super cheap in the grand scheme of things and I had similar functionality on my Tesla. The Tesla was buggy. It would often stop recording right when you needed it; recordings would jump; the cameras were not optimized for it so everything was grainy, poor color, etc. There was no hope of reading a plate or a face just basically a "what happened" (which is better than nothing of course).
Does the drive recorder work when you are parked? Like Tesla's Sentry Mode? Or only when driving? Anyone liking it enough to feel like you don't need a dashcam? Thanks. |
07-31-2023, 08:16 AM | #2 |
Rep 694
I posted somewhere the other day these same questions (great minds!).
I’ll find the thread and bump it, but if memory serves correctly from all of the previous searches and replies, the consensus was drive recorder works okay, but not great. It pales in comparison to Sentry mode. It does work while parked, but don’t hold your breath because *I was told or read* it was not reliable. There were been members that noted it didn’t record when it should have and/or the files were lost. I asked about ACE 3.0 (a port add-on) and the answer was that money was better spent on other aftermarket systems. I did a bunch of research on those based on the suggestions I got, and a few themes were FixcamX, Blackvue and others, but either they required significant installation efforts (IMO) or they didn’t function when the car was turned off and required additional installation (ie hardwired) to remain always “on.” To me, FitCamX was the best option for looks and functionality, but I still have time to mull it over. |
Needsdecaf6724.50 dini_g80188.00 |
07-31-2023, 08:43 AM | #3 | |
Rep 6,749
Chapter2099851.00 |
08-02-2023, 09:44 AM | #4 |
Rep 118
No sentry, no constant record but it does offer multiple views when it is used. It doesn't hurt to have some extra information if there is an incident.
I have it and I also have a 3 channel BlackVue DR770X Box Series. It does monitor when the car is off with a backup battery and I can remotely live view from my phone or PC. Nothing is perfect, and I am impressed with Tesla's Sentry mode but they seem to be the leaders on that front. What I have seems to be the best aftermarket option to get similar coverage. |
Needsdecaf6724.50 |
08-02-2023, 10:51 AM | #5 | |
Rep 133
08-02-2023, 01:56 PM | #6 |
Rep 6,749
The worst part was...you programmed the clock. You programmed the start time. You had cable, so the channel had to be set to "3".....
....and you forgot to change the channel on the cable box. You came home and instead of the movie you wanted, you had recorded reruns of The Love Boat. The youngins will never know the struggle. In the late '90's or maybe 2000, my friend got a TiVo. He was cutting edge. CNN actually featured him on a segment. It lead off with a clip of him sitting in his black recliner, TiVo remote in hand with a booming voiceover that said "IN HIS RIGHT HAND, KEN S**** HOLDS THE FUTURE OF TELEVISION". How right they were. They could never have known just how right they were. |
08-02-2023, 07:41 PM | #7 | |
Rep 694
Dumb question because I’m ignorant when it comes to this stuff but if I install the wiring is it also easy to uninstall? For some reason, I had a fear of messing something up that’s unreversible. Also, which Blackvue model do you prefer? |
OtoPA383.50 |
08-02-2023, 08:07 PM | #8 |
Rep 167
The video is slightly low res and low framerate if you use all cameras (4 camera views are fitted into a single 1280x960ish ~15fps video file).
It randomly reset at some point and when I went to use it I realized I had to go through the consent form again and completely missed the chance to record; the video I had previously saved was gone for whatever reason. Another time I am fairly sure I triggered the record function < 20 seconds after an event occurred, but it still completely missed what I was trying to save. So all in all I'm going to install a Blackvue whenever I get around to it |
08-02-2023, 09:35 PM | #9 | |
Rep 133
I chose the 970x 2 channel. It would be easy to uninstall as I did not take off any pillar covers to route cable. I simple tucked it a few mm into the space at trim edges and used the existing 'natural' junctions to make the turns and transitions. The fuse taps would be easy to remove in 5 min. I did not opt for the battery pack. I initially got 'battery management' errors on my dash as I had the parking monitor time maxed and I did not drive the car frequently enough. I'm sure BMW was sensing a parasite current draw against battery storage. I have since reduced my parking monitor time to about 6 hours...I'm retired and don't need 'parking mode' monitoring that long despite dinner, movie, casino and whatnot.. and no longer see any errors, despite not driving for a couple of days. It (BVue) starts normally, records front and back and the video is good quality (when downloaded). Viewed on the phone, it is lower quality. software is good and many options to play with. I chose BVue as I have it on my F150 for a year now...and I'd rather go S.Korean than Chinese as to brand. |
Chapter2099851.00 |
08-02-2023, 11:11 PM | #10 |
Rep 25
My experience with driver recorder: About a year ago someone rear ended me while I was stopped at a red light, he wasn't going crazy fast but he did enough damage that the electronics in the car locked the car down and I had to get a new bumper from the hole he put into it. Drive recorder never recorded anything from that event, and I double checked it was setup properly where it should have.
That being said, using it to make manual recordings while you're driving is pretty cool, getting all 4 angles at once. I wouldn't rely on it for anything where you can't manually hold the record button down, thankfully in my situation I also had a Thinkware U1000 installed in the front and rear that works great.
2021 BMW M3 6MT - Black Sapphire Metallic
Chapter2099851.00 TopJimmy5491.00 |
08-02-2023, 11:35 PM | #11 | |
Rep 694
08-03-2023, 10:10 AM | #12 |
Rep 2,305
I feel like BMW missed an opportunity here. Why does it only record 20 secs before and after? Storage is so cheap. They could have charged more for it. I would have paid $100 to give an hour each. Gives you time after an incident to press the button.
2001 330Ci (sold)
01-22-2024, 03:49 PM | #13 |
Rep 193
Sorry to revive this old thread……but I’ve recently been regretting just not clicking the $100 add on of the drive recorder. Does anyone know if that can be added at/as a port option?
01-22-2024, 04:16 PM | #14 | |
You got my money?
3186
Rep 4,664
Drives: Ice Cream Truck
I think you are SO much better off buying a garmin mini 2 dash cam. Small as a keyfob. No one see its. It can record full time (if you hardwire it) and run off USB or cig port power. Plus you get sound recorded too. The drive recorder missed the mark IMO. Get a Garmin Mini 2. 130 bucks. You can add 4 together for a full 360 view too. I personally only have one facing forward right now,but plan to add a rear one sooner than later. https://www.bestbuy.com/site/garmin-...B&gclsrc=aw.ds
01-22-2024, 04:59 PM | #15 | |
Rep 6,749
https://www.vortexradar.com/best-dashcams/ |
01-22-2024, 05:01 PM | #16 |
Rep 707
I watched the vortex YouTube video comparing the top video recorders. I believe he picked the vantrue n4 pro. There is a n5 pro available now.
01-22-2024, 06:58 PM | #17 | |
Rep 2,670
It lacks wifi but I don't think that's a useful feature. If I need footage I'll pull the mSD card. I don't think any dash cam is worth $400+. A $100 camera can use the same sensor and do just as well. |
Needsdecaf6724.50 |
01-22-2024, 07:37 PM | #18 | |
Rep 6,749
All depends on what yup want to (over)pay for. |
01-22-2024, 09:23 PM | #19 |
Rep 2,670
