      07-05-2023, 08:16 AM   #1
2Times
I'd hit it
2Times's Avatar
Drives: G82
2023 BMW M4 xd  [10.00]
Project Gamma Intake Manifold pre-order
For $2k, seems like a really good deal. There doesn't seem to be any info on it though, still need injectors and a controller for port injection which I don't see as an option.
Anyone in on this yet or have info?
https://shopprojectgamma.com/collect...port-injection
2023 M4 xd BSM
IG: MFor_YourPleasure
TopJimmy5461.50
      07-05-2023, 08:45 AM   #2
TopJimmy
TopJimmy's Avatar
Drives: 2023 M3 Comp xDrive
Amazing price there!
For a controller you’ll need a Motiv.
      07-05-2023, 12:19 PM   #3
Tethys
Drives: BMW M4 Comp, 330i, Camaro SS
I plan on buying one when I go port injection.
      07-05-2023, 02:09 PM   #4
retroviol3t
retroviol3t's Avatar
516
Drives: 2023 Jahre - Techno Violet
I DM'd and asked them for information or technical data and they said they would give it when they actually release the product. I'll bite my tongue until I see the data.
      07-05-2023, 08:18 PM   #5
2Times
I'd hit it
2Times's Avatar
Drives: G82
I ordered one… they’re not far so asking if I can go there to pick up/install
2023 M4 xd BSM
TopJimmy5461.50
      07-06-2023, 01:24 AM   #6
myg80m3
myg80m3's Avatar
1135
Drives: BMW G80
To keep cost down I’m sure they used cheaper heatexchange core and aluminum material.
As far as cooling goes the factory plastic manifold with the smaller heatexchange core will run a-lot cooler because plastic does not retain heat like aluminum does. Of course you’ll need an aluminum manifold for higher boost levels and port injection but I would definitely not cut corners and buy a cheaper product specifically if the company doesn’t want to share any data until it’s released? But they are taking pre-orders? Doesn’t make sense.
      07-06-2023, 11:17 AM   #7
IronChad
Drives: 2022 M5 Comp
This isn’t a product I would cheap out on, not saying it’s cheap. But I can’t imagine it having the data that CSF has provided all of us.
      07-06-2023, 02:31 PM   #8
myg80m3
myg80m3's Avatar
1135
Drives: BMW G80
Correct. Not calling the product cheap but a proper manifold with integrated cooler and machining work is expensive. Specially if you use an efficient high end heat exchanger core. Size of the heat exchanger doesn’t mean it’ll be as efficient as the factory core. But again it is necessary to run a full aluminum intake manifold when running a lot of pressure
      07-12-2023, 04:28 PM   #9
hotsauce_bukkake
Drives: 2023 G80 6MT BG/FR
I would be cautious. I was dead set on some other Project Gamma pieces and after doing a little digging, I opted for another brand. Check some of the M5 forums. There are plenty of folks over there not too happy with the brand and some of their shady practices. Not a lot of reviews of them on here.
      07-13-2023, 11:11 AM   #10
Tethys
I had their intakes on my M8 and had zero issues with he intakes or the company.
      07-13-2023, 11:20 AM   #11
hotsauce_bukkake
I'm glad it worked out for you. There were enough complaints for me to cancel my order, though. So, I'm just passing along info I came across.
      07-13-2023, 11:22 AM   #12
Tethys
I understand, as was I so just take it with a grain of salt and do what you feel is best.
      07-19-2023, 06:02 PM   #13
myg80m3
myg80m3's Avatar
1135
Drives: BMW G80
You did the right thing.
