03-23-2023, 08:03 AM | #1 |
I'd hit it
1065
Rep 1,106
O2 sensor spacers (CEL Eliminators) - bad for tuning?
Is there any disadvantage to leaving them in when getting a custom tune? I heard they can make the readings inaccurate towards the lean side but wasn't sure if that was some mythbusters stuff. Currently have the bigdaddies with mini-cat inline spacer.
2023 M4 xd BSM IG: MFor_YourPleasure |
03-23-2023, 10:34 AM | #2 |
Rep 735
AFR readings are from the pre cat sensors. Are post cat sensors actually used for anything other than emissions monitoring? I honestly don't know. I wouldn't think so, but maybe someone more knowledgeable knows for sure?
Regardless, if you are getting a custom tune then you have your ECU unlocked, so you have no reason to keep the spacers installed. Just remove them and turn off the CEL in the flash. |
03-23-2023, 10:40 AM | #3 | |
Rep 48
2Times1064.50 |
03-23-2023, 12:07 PM | #5 |
I'd hit it
1065
Rep 1,106
Thank you crew. I'll go ahead and do that.
03-23-2023, 12:49 PM | #6 |
Rep 42
https://youtu.be/bmWjoudIOCk
This video helps explain it but It seems like the secondary o2s do more than just check cat efficiency. |
2Times1064.50 |
