04-14-2022, 08:28 AM | #1 |
Rep 7
window streaking from lubricant on inside of door?
I have a 2022 M4 xdrive, anyone have issue with the windows streaking every time you roll them down? it's like there is a lubricant or something on the inside, really annoying. I also noticed that after I wash the car, when I roll the windows down (days later) the windows still get wet from the moisture that's inside the door.
thoughts? |
04-14-2022, 10:37 AM | #2 | |
///M ♥ Recycled Dinosaurs
3203
Rep 1,777
Drives: BMW M4, BMW X5 45e
Water and soap basically penetrates the seal and gets inside. This may include some dirt too, so you have a water, soap, dirt mix in there that feels like ‘lubricant’ to you. And if you lower your window soon after a wash, or sometimes even a long time later, it leaves vertical streaks on the inside and the outside. You can clean this by holding a microfiber cloth against the window and lowering and raising the window until it stops appearing. It may help to clean the seals with the window fully down first tooz This is not a G82 special, all BMWs with frameless windows exhibit this if you have high pressure water/soap push in at an angle. You will not see this if you do a gentle spray around the seals when you hand wash yourself. |
05-04-2022, 06:43 PM | #3 | ||
Rep 262
Drives: 2022 M3 6MT
2022 M3 G80 6MT
Portimao Blue/Full Fiona Red Carbon Buckets Squad |
