04-03-2023, 09:16 AM | #1 |
Rep 16
Changing Engine Oil removes warranty?
Hello guys
I have bought a used G80 M3C, 2022 model at 10.000kms. In the service book, it had it's break-in service made at 2000kms (1200miles) My car shows me to change the oil at 25000 kms; i currently have 12000 kms and it is time for an oil change. Following BMW suggestions regarding fluid maintenance would be crazy. I want to ask you guys if I change the oil myself and filters, does that affect warranty (any marks, safety locks, etc)? I don't want the BMW service guys to notice that I have made the oil change myself when I will go at 25000 kms and have issues regarding the warranty. Also, if I just change the oil and filters, does the car reset automatically the distantance until the next oil change? Because I benefit of a free service maintenance up to 30k kms. I can also book an overpriced oil change at my dealership but i would rather do it myself. Also, what fluids do you recommend for oil, transmission etc? Thank you! |
04-03-2023, 11:27 AM | #2 |
Rep 984
No changing oil by yourself in between dealer service intervals will not void warranty if you use genuine or OE/OEM parts for the oil filter and drain plug. For the oil and if you planning to stay stock, stick with 0w30 BMW LL01FE certified oil.
I personally am changing with Shell Helix 5w40 every 7.5k kms because I am running on E40 mix and fuel dilution from ethanol thins out the oil considerably over time whereby 0w30 would be far too thin for spirited driving applications.
2022 M3 XDrive - Full Race Turbos - BMC Filters - MAD Catless downpipes - MAD single midpipe - BM3 Flex Fuel Kit - Paul Johnson Flex Fuel - XHP - MPHAS - EBC Bluestuff - PS4S
2023 IX M60 2018 Lotus Exige Sport 410 - Harrop TVS1900 Supercharger - HKS Intake - Larini Headers - Simply Sports Cars Custom Tune - Ohlins TTX - Ferodo DS3.12 - Yokohoma AD09 Last edited by SE7EN335; 04-08-2023 at 10:13 AM.. Reason: Added OE/OEM |
04-03-2023, 11:38 AM | #3 | |
Rep 16
If I only change, without messing with the service reset, the car will show up the same distance until next oil change? |
04-03-2023, 11:45 AM | #4 |
Rep 984
Yes correct
2023 IX M60 2018 Lotus Exige Sport 410 - Harrop TVS1900 Supercharger - HKS Intake - Larini Headers - Simply Sports Cars Custom Tune - Ohlins TTX - Ferodo DS3.12 - Yokohoma AD09 |
04-05-2023, 09:53 PM | #5 | |
Rep 739
04-06-2023, 11:24 AM | #6 | |
Rep 984
The oil I was advised by my tuner was any high quality 5w50 with a HTHS of above 4. I put in Mobil 1 5w50. After about 4.6k kms on the oil, the oil degraded in viscosity to between a 0w30 to 5w30. So because of this I would think that E30-E40 mix would degrade a 0w30 to about a 0w20 or less within a couple of thousands kms. Beating on a tuned car at that thin of an oil at high rpms is not healthy at all
mathys202.50 |
04-06-2023, 03:37 PM | #7 | |
WSB Ape
70
Rep 59
Gfit2721.50 |
04-06-2023, 04:04 PM | #8 |
1925
Rep 1,896
Drives: E92 M3
How many of you have actually checked the warranty requires and associated laws for Romania, where the OP is located?
Doing an oil change yourself while using an acceptable oil and without screwing anything up should be undetectable, so no need to worry about warranties.
DocWeatherington2941.50 |
04-08-2023, 10:11 AM | #9 | |
Rep 984
04-08-2023, 11:11 PM | #11 |
Rep 984
Yes they surely can void your warranty if you use aftermarket parts. Case in point earlier, aftermarket shocks have faster rebound and compression which accelerates wear on the factory top strut mounts. BMW can argue that the aftermarket shocks accelerates wear on the mount as those shocks are not intended for fit for purpose in combination with the factory top strut mounts. They take it to court, any decent magistrate would see the case as in BMW's favour and your warranty is void. This is the same with engine oil and oil filters, using an out of spec oil and/or aftermarket filter can be easily proved by BMW in not providing the right oil lubrication and filtration for the engine. Again, any decent magistrate will fall the case to BMW's favour and your warranty is void.
04-10-2023, 07:21 AM | #12 |
Rep 16
So I have searched EVERYWHERE in Romania for the stock 0w30 LL01FE oil and i could not find it.
However I have found the versions of 0w30 LL04FE and LL12FE available. What is the difference between them? They noth appear as recommended by the manufacturer for the S58 engine |
04-11-2023, 04:52 AM | #13 | |
Rep 984
I believe LL04FE is strictly for the EU but isn't allowed in the US and some other parts of the world. Anyways, LL01FE is superior to the LL04FE as it has a higher TBN and higher SAPS content. I would go with LL01FE over LL04FE if you can get it.
04-11-2023, 08:00 AM | #14 | |
Rep 16
So I have done some research on the subject and aparently 01 is better if you use gasoline with lower octane number than E95. In Romania I run my M3 on E95 and E98 so LL04FE or LL12FE should be fine. I will change it in the next 7500 miles anyway. I have also spoke to BMW service guys and some of them told me they replace the stock oil with 0w30 and others replace with 5w30. What s your opinion on 5w30 for the B58 engine? Thank you man! |
04-11-2023, 03:19 PM | #15 | |
WSB Ape
70
Rep 59
SE7EN335330.00 |
04-14-2023, 07:33 AM | #16 | |
Rep 984
05-14-2023, 07:35 AM | #17 |
Rep 477
You can change your oil but make sure you have proper documentation. Id buy the filter from the dealership and keep the receipt for the oil.
Mines included, but Ive been getting coupons for $150 at my local dealer. Filter, oil, mess.. I'll pay the $50 extra then subtract a free coffee, couple snacks and change of scenery. $40 extra lol Money well spent. |
09-11-2023, 03:14 AM | #18 |
Rep 321
Had an interesting challenge in the uk. Phoned a number of dealers to get the oil changed at 9k miles (CBS is 18k miles in EU). All but one said not possible and would reset the service interval. I wanted it done off cycle as I have the service plan.
After being reassured several times that changing the oil wouldn’t impact the CBS I arrived at the garage to be told that it would not be possible. They said all changes would have to be registered in the system for warranty purposes. Not only that, I would have to pay for it and lose the 18k oil service. My choices are now 1. Use my indi who probably has never done an M car before 2. Do it myself but would be a first and no way of getting car raised and level high enough to do it. 3. Leave it to CBS. Any other suggestions welcome. |
09-12-2023, 10:49 PM | #19 | |
In the Details
1810
Rep 867
Drives: Yes
Garage List 2020 AMG GTR [0.00]
2022 R8 Quattro Spyder [0.00] 2023 X5M50 [0.00] 2023 718 Spyder [0.00] 2024 Silverado [0.00] 2024 Civic Type R [0.00] |
The MM Act was written to keep a manufacturer from voiding the warranty on your car if you got the oil changed somewhere else or used an aftermarket oil filter. It was not written to allow people to modify their cars willy nilly (even though that's my preferred method). A manufacturers warranty, which by the way is not required / they can all just say, no warranties anymore on any cars and there's nothing anyone can do about it, is specifically designed to cover DEFECTS in MATERIALS and WORKMANSHIP. That means if a part installed at the factory goes bad then they will put on a new one or if they screwed the car together wrong they will screw it together correctly, within the stated time and mileage. That's all it covers. So if you change shocks to Ohlins, they are not covered under the factory warranty anymore, but of course the manufacturer cannot deny your warranty claim on your air conditioning because you changed your shocks, in other words, they can't prove (a better word today is associate) that shocks would affect AC failure. The issue today is one that didn't exist in the 70s. Oil specs are not just 30 weight or 10-30 anymore. Now they are LL01, Dexos, and all the other 10's or 100's of very specific molecular structures. So yes, that is the new OEM spec and if you decide to run 15-50 Shell Rotella and they figure that out, you won't have an approved warranty claim when your rod bearing seizes. Of course, if you are only running a different oil to accomodate E85 usage, I am sure you have already come to terms with having no powertrain warranty considering the tune already has the engine (and rest of the powertrain) operating outside its designated parameters and handling more torque than the engineers designed it to handle. As soon as my 1200 miles is up, I will get the break in service done, I'll drive it home, pull the ECM and send it to FEMTO and the car will not see the dealership again as long as I own it unless the radio goes out. The difference is I won't be calling BMW in denial pretending my car is stock hoping they fix the powertrain I blew up for free. |
